GCC 14: nios2
Sun Apr 28 20:16:40 UTC 2024
On Sun, Apr 28, 2024 at 6:13 AM Sebastian Huber <
> Hello,
> in order to build the nios2 GCC 14, you have to add --enable-obsolete to
> the configure command line. With this option, it builds fine. I am not
> sure how this option can be added to the RSB just for this target.
This is an example from when I was experimenting with changing the multilib
set.
%define  gcc_configure_extra_options --with-multilib-list=rmprofile
> embedded brains GmbH & Co. KG
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240428/23aa215e/attachment.htm>
