[PATCH rtems-tools v5] tester/rtemstoolkit: add renode implementation
Muhammad Sulthan Mazaya msulthanmazaya at gmail.com
Mon Apr 29 04:35:20 UTC 2024
Bumping last update of last year's renode porting result. Rebased to
most recent commit on master.
Fixing typo on renode_script/ folder that is changed to be renode/ in v4
 .../testing/bsps/kendrytek210-renode.ini      |  38 ++++
 tester/rtems/testing/bsps/leon3-renode.ini    |  37 ++++
 tester/rtems/testing/renode.cfg               |  64 ++++++
 tester/rtems/testing/renode/kendrytek210.resc |  86 ++++++++
 tester/rtems/testing/renode/leon3-prom-gpl.S  | 205 ++++++++++++++++++
 .../rtems/testing/renode/leon3-prom-gpl.bin   | Bin 0 -> 529 bytes
 tester/rtems/testing/renode/leon3.resc        |  82 +++++++
 7 files changed, 512 insertions(+)
 create mode 100644 tester/rtems/testing/bsps/kendrytek210-renode.ini
 create mode 100644 tester/rtems/testing/bsps/leon3-renode.ini
 create mode 100644 tester/rtems/testing/renode.cfg
 create mode 100644 tester/rtems/testing/renode/kendrytek210.resc
 create mode 100644 tester/rtems/testing/renode/leon3-prom-gpl.S
 create mode 100755 tester/rtems/testing/renode/leon3-prom-gpl.bin
 create mode 100644 tester/rtems/testing/renode/leon3.resc
diff --git a/tester/rtems/testing/bsps/kendrytek210-renode.ini b/tester/rtems/testing/bsps/kendrytek210-renode.ini
new file mode 100644
index 0000000..0cc48ae
--- /dev/null
+++ b/tester/rtems/testing/bsps/kendrytek210-renode.ini
@@ -0,0 +1,38 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright (C) 2023, 2023 Muhammad Sulthan Mazaya (msulthanmazaya at gmail.com)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The Kendrytek210 Renode BSP
+[kendrytek210-renode]
+bsp             = kendrytek210-renode
+arch            = riscv
+tester          = %{_rtscripts}/renode.cfg
+bsp_resc_script = %{_rtscripts}/renode/kendrytek210.resc
diff --git a/tester/rtems/testing/bsps/leon3-renode.ini b/tester/rtems/testing/bsps/leon3-renode.ini
index 0000000..4ab013d
--- /dev/null
+++ b/tester/rtems/testing/bsps/leon3-renode.ini
@@ -0,0 +1,37 @@
+# # 1. Redistributions of source code must retain the above copyright notice,
+# The Leon3 Renode BSP
+[leon3-renode]
+bsp             = leon3-renode
+arch            = sparc
+bsp_resc_script = %{_rtscripts}/renode/leon3.resc
diff --git a/tester/rtems/testing/renode.cfg b/tester/rtems/testing/renode.cfg
index 0000000..c7fee25
--- /dev/null
+++ b/tester/rtems/testing/renode.cfg
@@ -0,0 +1,64 @@
+# Renode
+# Use a renode command to run the executable in the renode simulator.
+%include %{_configdir}/base.cfg
+%include %{_configdir}/checks.cfg
+# Console.
+%define console_telnet
+%include %{_configdir}/console.cfg
+# RTEMS version
+%include %{_rtdir}/rtems/version.cfg
+# Renode executable
+%define renode_cmd renode --hide-monitor
+%define binary_opts -e $bin?=@%{test_executable}
+%define start_opts -e "s @%{bsp_resc_script}"
+%define add_path -e "path add @%{_rttesting}/renode"
+%define trim_command sed 's/.*\[output\] //'
+# Executable
+%execute %{renode_cmd} %{binary_opts} %{add_path} %{start_opts} | %{trim_command}
diff --git a/tester/rtems/testing/renode/kendrytek210.resc b/tester/rtems/testing/renode/kendrytek210.resc
index 0000000..e214aec
--- /dev/null
+++ b/tester/rtems/testing/renode/kendrytek210.resc
@@ -0,0 +1,86 @@
+using sysbus
+using monitor
+mach create "K210"
+machine LoadPlatformDescription @platforms/cpus/kendryte_k210.repl
+path add @/
+showAnalyzer "uartAnalyzer" uart Antmicro.Renode.Analyzers.LoggingUartAnalyzer
+uartAnalyzer TimestampFormat None
+set report_repeating_line """
+from Antmicro.Renode.Logging import ConsoleBackend
+ConsoleBackend.Instance.ReportRepeatingLines = True
+set add_hook """
+def match(line):
+    ok_to_kill_lines = [
+        '*** TEST STATE: USER_INPUT',
+        '*** TEST STATE: BENCHMARK',
+        '*** END OF TEST ',
+        '*** FATAL ***'
+    return any(l in line for l in ok_to_kill_lines)
+def hook(line):
+    monitor.Parse("q")
+Antmicro.Renode.Hooks.UartHooksExtensions.AddLineHook(monitor.Machine["sysbus.uart"], match, hook)
+python $add_hook
+python $report_repeating_line
+sysbus Tag <0x50440000 0x10000> "SYSCTL"
+sysbus Tag <0x50440018 0x4> "pll_lock" 0xFFFFFFFF
+sysbus Tag <0x5044000C 0x4> "pll1"
+sysbus Tag <0x50440008 0x4> "pll0"
+sysbus Tag <0x50440020 0x4> "clk_sel0"
+sysbus Tag <0x50440028 0x4> "clk_en_cent"
+sysbus Tag <0x5044002c 0x4> "clk_en_peri"
+# enable uart tx
+uart WriteDoubleWord 0x8 0x1
+machine StartGdbServer 3333
+macro reset
+    sysbus LoadELF $bin
+# runMacro $reset
diff --git a/tester/rtems/testing/renode/leon3-prom-gpl.S b/tester/rtems/testing/renode/leon3-prom-gpl.S
index 0000000..91dc3bc
--- /dev/null
+++ b/tester/rtems/testing/renode/leon3-prom-gpl.S
@@ -0,0 +1,205 @@
+ * From https://github.com/TUT-ASI/leon3-grlib-gpl-mirror/blob/master/software/leon3/prom.S
+ * GPL license, version unknown
+/* Template boot-code for LEON3 test benches */
+#include "prom.h"
+#ifndef STACKSIZE
+#define STACKSIZE 0x00020000
+#endif
+	.seg	"text"
+	.proc	0
+	.align	4
+	.global start
+start:
+	flush
+	set 0x10e0, %g1		! init IU
+	mov %g1, %psr
+	mov %g0, %wim
+	mov %g0, %tbr
+	mov %g0, %y
+	mov %g0, %asr16
+	nop
+	set  0x81000f, %g1
+	sta %g1, [%g0] 2
+	mov %g0, %g2
+	nop
+	nop
+	nop
+	nop
+	nop
+	or %g2, %g2, %g0
+	nop
+	nop
+	nop
+	nop
+	nop
+#ifdef DSUADDR
+	set	DSUADDR, %g2
+	st	%g0, [%g2]
+	st	%g0, [%g2+0x08]
+	st	%g0, [%g2+0x20]
+	st	%g0, [%g2+0x24]
+	st	%g0, [%g2+0x40]
+	st	%g0, [%g2+0x44]
+	st	%g0, [%g2+0x50]
+	st	%g0, [%g2+0x54]
+	st	%g0, [%g2+0x58]
+	st	%g0, [%g2+0x5C]
+#endif
+2:
+	mov %asr17, %g3
+	and %g3, 0x1f, %g3
+	mov %g0, %g4
+	mov %g0, %g5
+	mov %g0, %g6
+	mov %g0, %g7
+1:
+	mov %g0, %l0
+	mov %g0, %l1
+	mov %g0, %l2
+	mov %g0, %l3
+	mov %g0, %l4
+	mov %g0, %l5
+	mov %g0, %l6
+	mov %g0, %l7
+	mov %g0, %o0
+	mov %g0, %o1
+	mov %g0, %o2
+	mov %g0, %o3
+	mov %g0, %o4
+	mov %g0, %o5
+	mov %g0, %o6
+	mov %g0, %o7
+	subcc %g3, 1, %g3
+	bge 1b
+	save
+	mov	2, %g1
+	mov	%g1, %wim
+	set 0x10e0, %g1		! enable traps
+	mov %g1, %psr
+	nop; nop; nop;
+	mov %psr, %g1
+	srl %g1, 12, %g1
+	andcc %g1, 1, %g0
+	be 1f
+	nop
+	set _fsrxx, %g3
+	ld [%g3], %fsr
+	ldd [%g3], %f0
+	ldd [%g3], %f2
+	ldd [%g3], %f4
+	ldd [%g3], %f6
+	ldd [%g3], %f8
+	ldd [%g3], %f10
+	ldd [%g3], %f12
+	ldd [%g3], %f14
+	ldd [%g3], %f16
+	ldd [%g3], %f18
+	ldd [%g3], %f20
+	ldd [%g3], %f22
+	ldd [%g3], %f24
+	ldd [%g3], %f26
+	ldd [%g3], %f28
+	ldd [%g3], %f30
+	nop
+	nop
+	nop
+	nop
+	nop
+	faddd %f0, %f2, %f4
+	nop
+	nop
+	nop
+	nop
+	ba  1f
+	nop
+.align	8
+_fsrxx:
+	.word 0
+	.word 0
+1:
+	mov %asr17, %g3
+	srl %g3, 28, %g3
+	andcc %g3, 0x0f, %g3
+	bne 1f
+	 nop
+#ifdef L2MCTRLIO
+	set L2MCTRLIO, %g1
+	set MCFG1, %g2
+	st  %g2, [%g1]
+	set MCFG2, %g2
+	st  %g2, [%g1+4]
+	set MCFG3, %g2
+	st  %g2, [%g1+8]
+#endif
+!	set IRQCTRL, %g1
+!	set 0x0ffff, %g2
+!	st  %g2, [%g1+0x10]
+#ifdef UARTADDR
+        set UARTADDR, %g1
+        st  %g0, [%g1+0xC]
+        set 3, %g2
+        st %g2,  [%g1+0x8]
+#endif
+#ifdef DDR2CTRLIO
+	set DDR2CTRLIO, %g1
+	set DDR2CFG4, %g2
+	st  %g2, [%g1+12]
+#endif
+#ifdef ASDCFG
+#ifndef SDCTRLPNP
+#define SDCTRLPNP 0xFFFFF860
+#endif
+	set SDCTRLPNP, %g1
+	ld  [%g1], %g2
+	srl %g2, 12, %g2
+	set 0x01009, %g1
+	subcc %g1, %g2, %g0
+	bne 1f
+	set ASDCFG, %g1
+	set DSDCFG, %g2
+	st  %g2, [%g1]
+#endif
+	! %g3 = cpu index
+1:	set STACKSIZE, %g2
+        mov %g0, %g1
+2:	subcc %g3, 0, %g0
+	be 3f
+	nop
+	add %g1, %g2, %g1
+	ba 2b
+	sub %g3, 1, %g3
+3:	set RAMSTART+ RAMSIZE-32, %fp
+	sub %fp, %g1, %fp
+	sub %fp, 96, %sp
+	set RAMSTART, %g1
+	jmp %g1
+	nop
+.align	32
diff --git a/tester/rtems/testing/renode/leon3-prom-gpl.bin b/tester/rtems/testing/renode/leon3-prom-gpl.bin
new file mode 100755
index 0000000000000000000000000000000000000000..a42628906b6915c589f6be96fe5de82a940c6529
GIT binary patch
literal 529
zcmYk&F-yZh6bJBsQma+O9uC$)FhikhM;GxB2R}yq7LJ!#(<mZEM2ZwSt%!*D2?}kc
z4h|h01RaFy;NT$Q;2>1uKedqte%#A at 3Gco0o*blrF<-dG3t at Q`z^jr1PRRmTcO>iC
zTMbzff4Mk6N(p6;z9(^cO(Mvc#gPB)(jM)TrZYOH3%aB$x~3bd&;cFN5mo7!YIH(@
zHr8A-`tS_k3&-Z%*61Ed|M=Wmr=mNpLf5ht@^Nm00 at 2%SXIf~_w{S=I)TIY{q-T1e
z9=*~Vz0)Us(Kr3jXs;yR(V5jGPEMhaPGYtnJn{XMi)JARO?FmcCa(Kp$?ZU5yQrs!
zJ54GrZPv$AD}B~Ckj{rrNz}U?M<NX<pLe3P0rwm9 at F8u{jQW9NtmRx3HF9;+C at 8B|
S&~A#~dM!DadpO4bG4%^DAaPm%
literal 0
HcmV?d00001
diff --git a/tester/rtems/testing/renode/leon3.resc b/tester/rtems/testing/renode/leon3.resc
index 0000000..3196775
--- /dev/null
+++ b/tester/rtems/testing/renode/leon3.resc
@@ -0,0 +1,82 @@
+using sysbus
+using monitor
+mach create "leon3"
+machine LoadPlatformDescription @platforms/boards/leon3.repl
+path add @/
+set add_hook """
+def my_match(line):
+        '*** FATAL ***'
+def my_hook(line):
+    print line
+Antmicro.Renode.Hooks.UartHooksExtensions.AddLineHook(monitor.Machine["sysbus.uart"], my_match, my_hook)
+python $add_hook
+macro reset
+    # The leon3-prom-gpl.bin is built using Antmicro's script from their
+    # example of how to use renode to test rtems leon3 using renode-test
+    # https://github.com/antmicro/renode-rtems-leon3/blob/main/build-prom.sh
+    # The source of the assembly file itself is from Gaisler
+    # https://github.com/TUT-ASI/leon3-grlib-gpl-mirror/blob/master/software/leon3/prom.S
+    sysbus LoadBinary @leon3-prom-gpl.bin 0x0
+    cpu PC 0
+runMacro $reset
2.34.1
