[PATCH] cpukit/jffs2: Handle used empty file system
Kinsey Moore kinsey.moore at oarcorp.com
Tue Feb 6 02:28:21 UTC 2024
On Mon, Feb 5, 2024 at 2:36 AM Sebastian Huber <
> Hello Kinsey,
> On 02.02.24 23:03, Kinsey Moore wrote:
> > On JFFS2 file systems on NOR flash or dataflash that does not have spare
> > area for metadata and thus does not invoke delayed writes, it is
> > possible to put the file system into a state where all blocks have been
> > written to and all files have been deleted from the filesystem. There is
> > a bug in the JFFS2 file system scan routine that detects this situation
> > as a corrupted file system since the scan routine relies on "used" space
> > to discriminate a valid file system when there are blocks that need to
> > be erased. The correct fix would require a partial rewrite of the scan
> > routine, so instead this patch tracks the space marked as obsolete along
> > with space at the end of each block that is otherwise too small to
> > contain a JFFS2 node so that it can me compared with the dirty space.
> > Corrupted data (or otherwise non-JFFS2 blocks) will still cause this
> > check to fail as corrupted data isn't recognized as obsoleted (deleted)
> > nodes.
> this should be reported to the Linux JFFS2 maintainers. A test case
> would be also nice.
I'm already communicating with the Linux MTD group over IRC and provided
them an example FS image that reproduces the problem along with this patch
that works around it. I should be able to get this into a test case.
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240205/3f0d15ba/attachment.htm>
