[PATCH] improved error checking in ticks per timeslice
zakthertemsdev at gmail.com zakthertemsdev at gmail.com
Tue Feb 13 02:23:05 UTC 2024
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index bd7cde628f..d480eb3971 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -3312,7 +3312,7 @@
  * @parblock
  * The following constraints apply to this configuration option:
- * * The value of the configuration option shall be greater than or equal to
+ * * The value of the configuration option shall be greater than
  *   zero.
  * * The value of the configuration option shall be less than or equal to <a
diff --git a/cpukit/include/rtems/confdefs/clock.h b/cpukit/include/rtems/confdefs/clock.h
index 26519cc70b..d0d7c453bc 100644
--- a/cpukit/include/rtems/confdefs/clock.h
+++ b/cpukit/include/rtems/confdefs/clock.h
@@ -74,6 +74,10 @@
   #error "CONFIGURE_MICROSECONDS_PER_TICK must be positive"
 #endif
+#if CONFIGURE_TICKS_PER_TIMESLICE <= 0 && defined(CONFIGURE_TICKS_PER_TIMESLICE)
+  #error "CONFIGURE_TICKS_PER_TIMESLICE shall be greater than zero"
+#endif
 #ifdef __cplusplus
 extern "C" {
 #endif
2.43.0
