[PATCH] improved error checking in ticks per timeslice
Wed Feb 14 14:28:47 UTC 2024
On 14.02.24 15:18, Joel Sherrill wrote:
> I'm cc'ing Sebastian because you edited the text in a generated file. He
> should be able to point us to the right place to fix it.
> On Mon, Feb 12, 2024 at 8:26 PM <zakthertemsdev at gmail.com
> <mailto:zakthertemsdev at gmail.com>> wrote:
>     From: Zack leung <z.liang111 at gmail.com <mailto:z.liang111 at gmail.com>>
>     diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
>     index bd7cde628f..d480eb3971 100644
>     --- a/cpukit/doxygen/appl-config.h
>     +++ b/cpukit/doxygen/appl-config.h
>     @@ -3312,7 +3312,7 @@
>        * @parblock
>        * The following constraints apply to this configuration option:
>     - * * The value of the configuration option shall be greater than or
>     equal to
>     + * * The value of the configuration option shall be greater than
>        *   zero.
> This file is generated from something in rtems-central. This was at the
> top of the file:
>   * This file is part of the RTEMS quality process and was automatically
>   * generated.  If you find something that needs to be fixed or
>   * worded better please post a report or patch to an RTEMS mailing list
No, problem. I can fix this before I check in the patch.
>        * * The value of the configuration option shall be less than or
>     equal to <a
>     diff --git a/cpukit/include/rtems/confdefs/clock.h
>     b/cpukit/include/rtems/confdefs/clock.h
>     index 26519cc70b..d0d7c453bc 100644
>     --- a/cpukit/include/rtems/confdefs/clock.h
>     +++ b/cpukit/include/rtems/confdefs/clock.h
>     @@ -74,6 +74,10 @@
>         #error "CONFIGURE_MICROSECONDS_PER_TICK must be positive"
>       #endif
>     +#if CONFIGURE_TICKS_PER_TIMESLICE <= 0 &&
>     defined(CONFIGURE_TICKS_PER_TIMESLICE)
>     +  #error "CONFIGURE_TICKS_PER_TIMESLICE shall be greater than zero"
>     +#endif
> This is modifying the right file but I think it is safer to check that
> it is defined
> before checking its value.
Yes, the defined() check should be first.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
