[PATCH rtems-source-builder 2/2] devel/qemu-xilinx: Fix build on GCC 13.2.0
Fri Feb 16 22:20:52 UTC 2024
On Wed, Feb 14, 2024 at 1:37 PM Kinsey Moore <kinsey.moore at oarcorp.com>
wrote:
> On Wed, Feb 14, 2024 at 9:14 AM Sam Price <thesamprice at gmail.com> wrote:
>> I was wondering if you had any notes on your process of working with
>> qemu in the rtems builder.
>> I imagine you have your own xilinx qemu forked to work on, and then
>> take the patches and integrate them into the rsb builder?
> Nothing so fancy. Here's my current setup for this:
> * have a checkout of the qemu-xilinx repo to generate patches
> * copy generated patches into the rsb/rtems/patches directory
> * set up the RSB recipe to pull in the patch with appropriate SHA512
> * attempt build
> This lets me pull in a custom patch for testing without actually hosting
> it somewhere. I've been wanting an easier way to do this since it's a pain
> to push patches elsewhere for test hosting before actually pushing it to
> the ticket, but this is the compromise I've settled on that smooths out the
> workflow just enough. Ideally, I'd be able to specify a local file path for
> a patch for test purposes, but that would necessitate some very verbose
> flag to sb-set-builder like
> --really-allow-local-patches-just-for-test-purposes because we really don't
> want to host these patches within RSB.
This is essentially what I have done when generating patches for newlib,
gcc, etc. For some packages, you need a patch based on git and sometimes
you have to generate one against a released version. But you still have to
put a patch in your patches directory and update the sha hash. Eventually
putting the working patch somewhere (hopefully merged upstream) not local.
--joel
> Kinsey
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240216/d50b6567/attachment.htm>
