[PATCH] improved error checking in ticks per timeslice
zack leung zakthertemsdev at gmail.com
Tue Feb 27 01:47:21 UTC 2024
ping
On Tue, 20 Feb 2024 at 20:25, zack leung <zakthertemsdev at gmail.com> wrote:
> ping
> On Sun, 18 Feb 2024 at 21:15, <zakthertemsdev at gmail.com> wrote:
>>  cpukit/doxygen/appl-config.h          | 2 +-
>>  cpukit/include/rtems/confdefs/clock.h | 6 ++++++
>>  2 files changed, 7 insertions(+), 1 deletion(-)
>> diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
>> index bd7cde628f..d480eb3971 100644
>> --- a/cpukit/doxygen/appl-config.h
>> +++ b/cpukit/doxygen/appl-config.h
>> @@ -3312,7 +3312,7 @@
>>   * @parblock
>>   * The following constraints apply to this configuration option:
>> - * * The value of the configuration option shall be greater than or
>> equal to
>> + * * The value of the configuration option shall be greater than
>>   *   zero.
>>   * * The value of the configuration option shall be less than or equal
>> to <a
>> diff --git a/cpukit/include/rtems/confdefs/clock.h
>> b/cpukit/include/rtems/confdefs/clock.h
>> index 26519cc70b..f4c4575057 100644
>> --- a/cpukit/include/rtems/confdefs/clock.h
>> +++ b/cpukit/include/rtems/confdefs/clock.h
>> @@ -74,6 +74,12 @@
>>    #error "CONFIGURE_MICROSECONDS_PER_TICK must be positive"
>>  #endif
>> +#if defined(CONFIGURE_TICKS_PER_TIMESLICE)
>> +  #if CONFIGURE_TICKS_PER_TIMESLICE <= 0
>> +    #error "CONFIGURE_TICKS_PER_TIMESLICE shall be greater than zero"
>> +  #endif
>> +#endif
>>  #ifdef __cplusplus
>>  extern "C" {
>>  #endif
>> 2.43.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240226/955ce113/attachment.htm>
