[PATCH 4/6] build: Add support to make bootloader images
Frank Kühndel frank.kuehndel at embedded-brains.de
Tue Feb 27 17:42:04 UTC 2024
Hello Sebastian,
On 2/27/24 16:15, Sebastian Huber wrote:
> Add a new build item type to provide optional BSP-specific tools to make
> bootloader images.  The tools are installed as Python scripts in:
>    ${prefix}/bin/rtems-mkimage-${ARCH}-${BSP_NAME}.py
> Application build systems can query the tool using the RTEMS_MKIMAGE package
> configuration varible, for example:
>    pkg-config --variable=RTEMS_MKIMAGE ${prefix}/lib/pkgconfig/${ARCH}-${BSP_NAME}.pc
> If the BSP does not provide a tool, then the variable RTEMS_MKIMAGE is set to
> "false".
Do I see this right? This will create automatically an
     ${PREFIX}/bin/rtems-mkimage-arm-xilinx-zynq.py
if RTEMS is build for ARM/xilinx-zynq and a mkimage shell command is
found on the host?
Where ${PREFIX} is the RTEMS install path and not necessarily the tools
path (i.e. it may not be in $PATH)?
Is it worth documenting that one can add this feature for further BSP by
creating an appropriate spec/build/bsps/<Arch>/<BSP>/mkimage.yml file?
> Update #4272.
>   spec/build/bsps/bspopts.yml              |  2 ++
>   spec/build/bsps/optpkgmkimage.yml        | 19 ++++++++++
>   spec/build/bsps/pkgconfig.yml            |  1 +
>   spec/build/cpukit/cpuopts.yml            |  4 +++
>   spec/build/cpukit/optbootimageext.yml    | 17 +++++++++
>   spec/build/cpukit/optbuildbootimages.yml | 16 +++++++++
>   wscript                                  | 45 ++++++++++++++++++++++--
>   7 files changed, 102 insertions(+), 2 deletions(-)
>   create mode 100644 spec/build/bsps/optpkgmkimage.yml
>   create mode 100644 spec/build/cpukit/optbootimageext.yml
>   create mode 100644 spec/build/cpukit/optbuildbootimages.yml
> diff --git a/spec/build/bsps/bspopts.yml b/spec/build/bsps/bspopts.yml
> index 734292f421..74fe6d17f9 100644
> --- a/spec/build/bsps/bspopts.yml
> +++ b/spec/build/bsps/bspopts.yml
> @@ -33,6 +33,8 @@ links:
>     uid: optldflagsbsp
>   - role: build-dependency
>     uid: optmakelegacy
> +- role: build-dependency
> +  uid: optpkgmkimage
>     uid: optprintexcpt
> diff --git a/spec/build/bsps/optpkgmkimage.yml b/spec/build/bsps/optpkgmkimage.yml
> new file mode 100644
> index 0000000000..00d9a0171f
> --- /dev/null
> +++ b/spec/build/bsps/optpkgmkimage.yml
> @@ -0,0 +1,19 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- get-string: null
> +- substitute: null
> +- env-assign: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2024 embedded brains GmbH & Co. KG
> +default:
> +- enabled-by: HAVE_MKIMAGE
> +  value: $${prefix}/bin/rtems-mkimage-${ARCH}-${BSP_NAME}.py
> +- enabled-by: true
> +  value: 'false'
> +description: ''
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: PKGCONFIG_MKIMAGE
> +type: build
> diff --git a/spec/build/bsps/pkgconfig.yml b/spec/build/bsps/pkgconfig.yml
> index afaffbbf0f..e1cdc9a70e 100644
> --- a/spec/build/bsps/pkgconfig.yml
> +++ b/spec/build/bsps/pkgconfig.yml
> @@ -20,6 +20,7 @@ content: |
>     RTEMS_MAJOR=${__RTEMS_MAJOR__}
>     RTEMS_MINOR=${__RTEMS_MINOR__}
>     RTEMS_REVISION=${__RTEMS_REVISION__}
> +  RTEMS_MKIMAGE=${PKGCONFIG_MKIMAGE}
>     Version: ${RTEMS_VERSION}
> diff --git a/spec/build/cpukit/cpuopts.yml b/spec/build/cpukit/cpuopts.yml
> index 1d28ace552..bdf8fc2f66 100644
> --- a/spec/build/cpukit/cpuopts.yml
> +++ b/spec/build/cpukit/cpuopts.yml
> @@ -75,6 +75,10 @@ links:
>     uid: optcoverageldflags
>     uid: optnocoverageldflags
> +  uid: optbootimageext
> +  uid: optbuildbootimages
>     uid: optversion
>   target: cpukit/include/rtems/score/cpuopts.h
> diff --git a/spec/build/cpukit/optbootimageext.yml b/spec/build/cpukit/optbootimageext.yml
> index 0000000000..c9347ffba8
> --- /dev/null
> +++ b/spec/build/cpukit/optbootimageext.yml
> @@ -0,0 +1,17 @@
> +actions:
> +- get-string: null
> +- env-assign: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: .img
> +description: |
> +  Defines the file extension of boot images.
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: BOOT_IMAGE_EXTENSION
> +type: build
> diff --git a/spec/build/cpukit/optbuildbootimages.yml b/spec/build/cpukit/optbuildbootimages.yml
> index 0000000000..12328b006d
> --- /dev/null
> +++ b/spec/build/cpukit/optbuildbootimages.yml
> @@ -0,0 +1,16 @@
> +actions:
> +- get-boolean: null
> +- env-enable: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: false
> +description: |
> +  If this option is enabled, then boot images for the test programs are built.
> +enabled-by: true
> +links: []
> +name: BUILD_BOOT_IMAGES
> +type: build
> diff --git a/wscript b/wscript
> index e43ae8ba3e..c6cfad147a 100755
> --- a/wscript
> +++ b/wscript
> @@ -197,6 +197,15 @@ def make_tar_info_reproducible(info):
>       return info
> +def make_image(bld, target):
> +    if not target.endswith(".norun.exe"):
> +        if bld.env.BUILD_TOOL_MKIMAGE:
> +            image = os.path.splitext(target)[0] + bld.env.BOOT_IMAGE_EXTENSION
> +            bld(rule="${BUILD_TOOL_MKIMAGE} ${SRC} ${TGT}",
> +                source=target,
> +                target=image)
>   class Item(object):
>       def __init__(self, uid, data):
> @@ -590,6 +599,30 @@ class ConfigFileItem(Item):
>           self.install_target(bld)
> +class MakeImageItem(Item):
> +    def __init__(self, uid, data):
> +        super(MakeImageItem, self).__init__(uid, data)
> +    def do_configure(self, conf, cic):
> +        content = self.substitute(conf, self.data["content"])
> +        f = conf.bldnode.make_node(conf.env.VARIANT + "/bin/mkimage.py")
> +        f.parent.mkdir()
> +        f.write(content)
> +        # 493 == 0755
> +        f.chmod(493)
In Python2 and Python3: 0o755
Greetings,
fk
> +        file_path = f.abspath()
> +        conf.env.BUILD_TOOL_MKIMAGE = file_path
> +        conf.env.append_value("cfg_files", file_path)
> +        conf.env.append_value("ENABLE", "HAVE_MKIMAGE")
> +    def do_build(self, bld, bic):
> +        bld.install_as("${PREFIX}/bin/rtems-mkimage-" + bld.env.ARCH + "-" +
> +                       bld.env.BSP_NAME + ".py",
> +                       "bin/mkimage.py",
> +                       chmod=493)
>   class ConfigHeaderItem(Item):
> @@ -745,6 +778,7 @@ class TestProgramItem(Item):
> +        target = self.get(bld, "target")
>           bld(
>               cflags=bic.cflags,
>               cppflags=bic.cppflags,
> @@ -756,9 +790,10 @@ class TestProgramItem(Item):
>               source=self.data["source"],
>               start_files=True,
>               stlib=self.data["stlib"],
> -            target=self.get(bld, "target"),
> +            target=target,
>               use=bic.objects + bic.use,
> +        make_image(bld, target)
>   class AdaTestProgramItem(TestProgramItem):
> @@ -770,14 +805,16 @@ class AdaTestProgramItem(TestProgramItem):
>           objs = []
>           for s in self.data["source"]:
>               objs.append(self.cc(bld, bic, s))
>           self.gnatmake(
>               bld,
>               bic,
>               self.data["ada-object-directory"],
>               objs,
>               self.data["ada-main"],
> -            self.data["target"],
> +            target,
>   class OptionItem(Item):
> @@ -1161,6 +1198,9 @@ class ScriptItem(Item):
>           script = self.data["do-build"]
>           if script:
>               exec(script)
> +        target = self.data.get("target", None)
> +        if target is not None:
> +            make_image(bld, self.substitute(bld, target))
>   class ConfigItemContext(object):
> @@ -1284,6 +1324,7 @@ def load_items(ctx, specs):
>           "test-program": TestProgramItem,
>           "group": GroupItem,
>           "library": LibraryItem,
> +        "mkimage": MakeImageItem,
>           "objects": ObjectsItem,
>           "option": OptionItem,
>           "script": ScriptItem,
> -- 2.35.3 _______________________________________________ devel mailing
> list devel at rtems.org http://lists.rtems.org/mailman/listinfo/devel
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone:  +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
Registernummer: HRA 117265
