[PATCH] improved error checking in ticks per timeslice
zack leung zakthertemsdev at gmail.com
Wed Feb 28 02:33:34 UTC 2024
joel said:
   +#if CONFIGURE_TICKS_PER_TIMESLICE <= 0 &&
>     defined(CONFIGURE_TICKS_PER_TIMESLICE)
>     +  #error "CONFIGURE_TICKS_PER_TIMESLICE shall be greater than zero"
>     +#endif
> This is modifying the right file but I think it is safer to check that
> it is defined
> before checking its value.
Yes, the defined() check should be first. - sebestian
You said this in relation to joel's comment in my previous thread. You can
check in either one.  The  previous one used the "and" statement.
Zack
On Tue, 27 Feb 2024 at 02:08, Sebastian Huber <
> On 19.02.24 03:13, zakthertemsdev at gmail.com wrote:
> > +#if defined(CONFIGURE_TICKS_PER_TIMESLICE)
> > +  #if CONFIGURE_TICKS_PER_TIMESLICE <= 0
> > +  #endif
> > +#endif
> This should be
> #if defined(CONFIGURE_TICKS_PER_TIMESLICE) &&
> from my point of view. Just check the style of the related header files
> for a reference.
> embedded brains GmbH & Co. KG
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240227/f7aff229/attachment.htm>
