[Tools] rtemstoolkit/libierty: Add missing file
zhengxiaojun 17935334 at qq.com
Wed Feb 28 07:20:15 UTC 2024
The patch close #4974.
On 2024/2/28 15:11, Chris Johns wrote:
> OK and thanks
> Chris
> On 27/2/2024 9:56 pm, Sebastian Huber wrote:
>> This fixes the following build error for --host=x86_64-w64-mingw32:
>> rtemstoolkit/libiberty.a(pex-win32.c.18.o): in function `win32_spawn':
>> rtemstoolkit/libiberty/pex-win32.c:643: undefined reference to `writeargv'
>> Update #4969.
>>   rtemstoolkit/libiberty/argv.c | 568 ++++++++++++++++++++++++++++++++++
>>   rtemstoolkit/wscript          |   3 +-
>>   2 files changed, 570 insertions(+), 1 deletion(-)
>>   create mode 100644 rtemstoolkit/libiberty/argv.c
>> diff --git a/rtemstoolkit/libiberty/argv.c b/rtemstoolkit/libiberty/argv.c
>> new file mode 100644
>> index 0000000..a95a10e
>> --- /dev/null
>> +++ b/rtemstoolkit/libiberty/argv.c
>> @@ -0,0 +1,568 @@
>> +/* Create and destroy argument vectors (argv's)
>> +   Copyright (C) 1992-2023 Free Software Foundation, Inc.
>> +   Written by Fred Fish @ Cygnus Support
>> +This file is part of the libiberty library.
>> +Libiberty is free software; you can redistribute it and/or
>> +modify it under the terms of the GNU Library General Public
>> +License as published by the Free Software Foundation; either
>> +version 2 of the License, or (at your option) any later version.
>> +Libiberty is distributed in the hope that it will be useful,
>> +but WITHOUT ANY WARRANTY; without even the implied warranty of
>> +MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
>> +Library General Public License for more details.
>> +You should have received a copy of the GNU Library General Public
>> +License along with libiberty; see the file COPYING.LIB.  If
>> +not, write to the Free Software Foundation, Inc., 51 Franklin Street - Fifth Floor,
>> +Boston, MA 02110-1301, USA.  */
>> +/*  Create and destroy argument vectors.  An argument vector is simply an
>> +    array of string pointers, terminated by a NULL pointer. */
>> +#ifdef HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +#include "ansidecl.h"
>> +#include "libiberty.h"
>> +#include "safe-ctype.h"
>> +/*  Routines imported from standard C runtime libraries. */
>> +#include <stddef.h>
>> +#include <string.h>
>> +#include <stdlib.h>
>> +#include <stdio.h>
>> +#include <sys/types.h>
>> +#ifdef HAVE_UNISTD_H
>> +#include <unistd.h>
>> +#endif
>> +#if HAVE_SYS_STAT_H
>> +#include <sys/stat.h>
>> +#endif
>> +#ifndef NULL
>> +#define NULL 0
>> +#endif
>> +#ifndef EOS
>> +#define EOS '\0'
>> +#endif
>> +#define INITIAL_MAXARGC 8	/* Number of args + NULL in initial argv */
>> + at deftypefn Extension char** dupargv (char * const *@var{vector})
>> +Duplicate an argument vector.  Simply scans through @var{vector},
>> +duplicating each argument until the terminating @code{NULL} is found.
>> +Returns a pointer to the argument vector if successful.  Returns
>> + at code{NULL} if there is insufficient memory to complete building the
>> +argument vector.
>> + at end deftypefn
>> +char **
>> +dupargv (char * const *argv)
>> +  int argc;
>> +  char **copy;
>> +  if (argv == NULL)
>> +    return NULL;
>> +  /* the vector */
>> +  for (argc = 0; argv[argc] != NULL; argc++);
>> +  copy = (char **) xmalloc ((argc + 1) * sizeof (char *));
>> +  /* the strings */
>> +    copy[argc] = xstrdup (argv[argc]);
>> +  copy[argc] = NULL;
>> +  return copy;
>> + at deftypefn Extension void freeargv (char **@var{vector})
>> +Free an argument vector that was built using @code{buildargv}.  Simply
>> +scans through @var{vector}, freeing the memory for each argument until
>> +the terminating @code{NULL} is found, and then frees @var{vector}
>> +itself.
>> + at end deftypefn
>> +void freeargv (char **vector)
>> +  register char **scan;
>> +  if (vector != NULL)
>> +      for (scan = vector; *scan != NULL; scan++)
>> +	  free (*scan);
>> +      free (vector);
>> +static void
>> +consume_whitespace (const char **input)
>> +  while (ISSPACE (**input))
>> +      (*input)++;
>> +static int
>> +only_whitespace (const char* input)
>> +  while (*input != EOS && ISSPACE (*input))
>> +    input++;
>> +  return (*input == EOS);
>> + at deftypefn Extension char** buildargv (char *@var{sp})
>> +Given a pointer to a string, parse the string extracting fields
>> +separated by whitespace and optionally enclosed within either single
>> +or double quotes (which are stripped off), and build a vector of
>> +pointers to copies of the string for each field.  The input string
>> +remains unchanged.  The last element of the vector is followed by a
>> + at code{NULL} element.
>> +All of the memory for the pointer array and copies of the string
>> +is obtained from @code{xmalloc}.  All of the memory can be returned to the
>> +system with the single function call @code{freeargv}, which takes the
>> +returned result of @code{buildargv}, as it's argument.
>> + at code{NULL} if @var{sp} is @code{NULL} or if there is insufficient
>> +memory to complete building the argument vector.
>> +If the input is a null string (as opposed to a @code{NULL} pointer),
>> +then buildarg returns an argument vector that has one arg, a null
>> +string.
>> + at end deftypefn
>> +The memory for the argv array is dynamically expanded as necessary.
>> +In order to provide a working buffer for extracting arguments into,
>> +with appropriate stripping of quotes and translation of backslash
>> +sequences, we allocate a working buffer at least as long as the input
>> +string.  This ensures that we always have enough space in which to
>> +work, since the extracted arg is never larger than the input string.
>> +The argument vector is always kept terminated with a @code{NULL} arg
>> +pointer, so it can be passed to @code{freeargv} at any time, or
>> +returned, as appropriate.
>> +char **buildargv (const char *input)
>> +  char *arg;
>> +  char *copybuf;
>> +  int squote = 0;
>> +  int dquote = 0;
>> +  int bsquote = 0;
>> +  int argc = 0;
>> +  int maxargc = 0;
>> +  char **argv = NULL;
>> +  char **nargv;
>> +  if (input != NULL)
>> +      copybuf = (char *) xmalloc (strlen (input) + 1);
>> +      /* Is a do{}while to always execute the loop once.  Always return an
>> +	 argv, even for null strings.  See NOTES above, test case below. */
>> +      do
>> +	  /* Pick off argv[argc] */
>> +	  consume_whitespace (&input);
>> +	  if ((maxargc == 0) || (argc >= (maxargc - 1)))
>> +	      /* argv needs initialization, or expansion */
>> +	      if (argv == NULL)
>> +		  maxargc = INITIAL_MAXARGC;
>> +		  nargv = (char **) xmalloc (maxargc * sizeof (char *));
>> +	      else
>> +		  maxargc *= 2;
>> +		  nargv = (char **) xrealloc (argv, maxargc * sizeof (char *));
>> +	      argv = nargv;
>> +	      argv[argc] = NULL;
>> +	  /* Begin scanning arg */
>> +	  arg = copybuf;
>> +	  while (*input != EOS)
>> +	      if (ISSPACE (*input) && !squote && !dquote && !bsquote)
>> +		  break;
>> +	      else
>> +		  if (bsquote)
>> +		      bsquote = 0;
>> +		      *arg++ = *input;
>> +		  else if (*input == '\\')
>> +		      bsquote = 1;
>> +		  else if (squote)
>> +		      if (*input == '\'')
>> +			  squote = 0;
>> +		      else
>> +			  *arg++ = *input;
>> +		  else if (dquote)
>> +		      if (*input == '"')
>> +			  dquote = 0;
>> +		      else
>> +			  *arg++ = *input;
>> +		  else
>> +			  squote = 1;
>> +		      else if (*input == '"')
>> +			  dquote = 1;
>> +		      else
>> +			  *arg++ = *input;
>> +		  input++;
>> +	  *arg = EOS;
>> +	  argv[argc] = xstrdup (copybuf);
>> +	  argc++;
>> +      while (*input != EOS);
>> +      free (copybuf);
>> +  return (argv);
>> + at deftypefn Extension int writeargv (char * const *@var{argv}, FILE *@var{file})
>> +Write each member of ARGV, handling all necessary quoting, to the file
>> +named by FILE, separated by whitespace.  Return 0 on success, non-zero
>> +if an error occurred while writing to FILE.
>> + at end deftypefn
>> +int
>> +writeargv (char * const *argv, FILE *f)
>> +  int status = 0;
>> +  if (f == NULL)
>> +    return 1;
>> +  while (*argv != NULL)
>> +      const char *arg = *argv;
>> +      while (*arg != EOS)
>> +          char c = *arg;
>> +          if (ISSPACE(c) || c == '\\' || c == '\'' || c == '"')
>> +            if (EOF == fputc ('\\', f))
>> +                status = 1;
>> +                goto done;
>> +          if (EOF == fputc (c, f))
>> +              status = 1;
>> +              goto done;
>> +          arg++;
>> +      /* Write out a pair of quotes for an empty argument.  */
>> +      if (arg == *argv)
>> +	if (EOF == fputs ("\"\"", f))
>> +	    status = 1;
>> +	    goto done;
>> +      if (EOF == fputc ('\n', f))
>> +          status = 1;
>> +          goto done;
>> +      argv++;
>> + done:
>> +  return status;
>> + at deftypefn Extension void expandargv (int *@var{argcp}, char ***@var{argvp})
>> +The @var{argcp} and @code{argvp} arguments are pointers to the usual
>> + at code{argc} and @code{argv} arguments to @code{main}.  This function
>> +looks for arguments that begin with the character @samp{@@}.  Any such
>> +arguments are interpreted as ``response files''.  The contents of the
>> +response file are interpreted as additional command line options.  In
>> +particular, the file is separated into whitespace-separated strings;
>> +each such string is taken as a command-line option.  The new options
>> +are inserted in place of the option naming the response file, and
>> + at code{*argcp} and @code{*argvp} will be updated.  If the value of
>> + at code{*argvp} is modified by this function, then the new value has
>> +been dynamically allocated and can be deallocated by the caller with
>> + at code{freeargv}.  However, most callers will simply call
>> + at code{expandargv} near the beginning of @code{main} and allow the
>> +operating system to free the memory when the program exits.
>> + at end deftypefn
>> +void
>> +expandargv (int *argcp, char ***argvp)
>> +  /* The argument we are currently processing.  */
>> +  int i = 0;
>> +  /* To check if ***argvp has been dynamically allocated.  */
>> +  char ** const original_argv = *argvp;
>> +  /* Limit the number of response files that we parse in order
>> +     to prevent infinite recursion.  */
>> +  unsigned int iteration_limit = 2000;
>> +  /* Loop over the arguments, handling response files.  We always skip
>> +     ARGVP[0], as that is the name of the program being run.  */
>> +  while (++i < *argcp)
>> +      /* The name of the response file.  */
>> +      const char *filename;
>> +      /* The response file.  */
>> +      FILE *f;
>> +      /* An upper bound on the number of characters in the response
>> +	 file.  */
>> +      long pos;
>> +      /* The number of characters in the response file, when actually
>> +	 read.  */
>> +      size_t len;
>> +      /* A dynamically allocated buffer used to hold options read from a
>> +	 response file.  */
>> +      char *buffer;
>> +      /* Dynamically allocated storage for the options read from the
>> +	 response file.  */
>> +      char **file_argv;
>> +      /* The number of options read from the response file, if any.  */
>> +      size_t file_argc;
>> +#ifdef S_ISDIR
>> +      struct stat sb;
>> +#endif
>> +      /* We are only interested in options of the form "@file".  */
>> +      filename = (*argvp)[i];
>> +      if (filename[0] != '@')
>> +	continue;
>> +      /* If we have iterated too many times then stop.  */
>> +      if (-- iteration_limit == 0)
>> +	  fprintf (stderr, "%s: error: too many @-files encountered\n", (*argvp)[0]);
>> +	  xexit (1);
>> +#ifdef S_ISDIR
>> +      if (stat (filename+1, &sb) < 0)
>> +	continue;
>> +      if (S_ISDIR(sb.st_mode))
>> +	  fprintf (stderr, "%s: error: @-file refers to a directory\n", (*argvp)[0]);
>> +	  xexit (1);
>> +#endif
>> +      /* Read the contents of the file.  */
>> +      f = fopen (++filename, "r");
>> +      if (!f)
>> +	continue;
>> +      if (fseek (f, 0L, SEEK_END) == -1)
>> +	goto error;
>> +      pos = ftell (f);
>> +      if (pos == -1)
>> +	goto error;
>> +      if (fseek (f, 0L, SEEK_SET) == -1)
>> +	goto error;
>> +      buffer = (char *) xmalloc (pos * sizeof (char) + 1);
>> +      len = fread (buffer, sizeof (char), pos, f);
>> +      if (len != (size_t) pos
>> +	  /* On Windows, fread may return a value smaller than POS,
>> +	     due to CR/LF->CR translation when reading text files.
>> +	     That does not in-and-of itself indicate failure.  */
>> +	  && ferror (f))
>> +	  free (buffer);
>> +	  goto error;
>> +      /* Add a NUL terminator.  */
>> +      buffer[len] = '\0';
>> +      /* If the file is empty or contains only whitespace, buildargv would
>> +	 return a single empty argument.  In this context we want no arguments,
>> +	 instead.  */
>> +      if (only_whitespace (buffer))
>> +	  file_argv = (char **) xmalloc (sizeof (char *));
>> +	  file_argv[0] = NULL;
>> +      else
>> +	/* Parse the string.  */
>> +	file_argv = buildargv (buffer);
>> +      /* If *ARGVP is not already dynamically allocated, copy it.  */
>> +      if (*argvp == original_argv)
>> +	*argvp = dupargv (*argvp);
>> +      /* Count the number of arguments.  */
>> +      file_argc = 0;
>> +      while (file_argv[file_argc])
>> +	++file_argc;
>> +      /* Free the original option's memory.  */
>> +      free ((*argvp)[i]);
>> +      /* Now, insert FILE_ARGV into ARGV.  The "+1" below handles the
>> +	 NULL terminator at the end of ARGV.  */
>> +      *argvp = ((char **)
>> +		xrealloc (*argvp,
>> +			  (*argcp + file_argc + 1) * sizeof (char *)));
>> +      memmove (*argvp + i + file_argc, *argvp + i + 1,
>> +	       (*argcp - i) * sizeof (char *));
>> +      memcpy (*argvp + i, file_argv, file_argc * sizeof (char *));
>> +      /* The original option has been replaced by all the new
>> +	 options.  */
>> +      *argcp += file_argc - 1;
>> +      /* Free up memory allocated to process the response file.  We do
>> +	 not use freeargv because the individual options in FILE_ARGV
>> +	 are now in the main ARGV.  */
>> +      free (file_argv);
>> +      free (buffer);
>> +      /* Rescan all of the arguments just read to support response
>> +	 files that include other response files.  */
>> +      --i;
>> +    error:
>> +      /* We're all done with the file now.  */
>> +      fclose (f);
>> + at deftypefn Extension int countargv (char * const *@var{argv})
>> +Return the number of elements in @var{argv}.
>> +Returns zero if @var{argv} is NULL.
>> + at end deftypefn
>> +int
>> +countargv (char * const *argv)
>> +  int argc;
>> +  if (argv == NULL)
>> +    return 0;
>> +    continue;
>> +  return argc;
>> +#ifdef MAIN
>> +/* Simple little test driver. */
>> +static const char *const tests[] =
>> +  "a simple command line",
>> +  "arg 'foo' is single quoted",
>> +  "arg \"bar\" is double quoted",
>> +  "arg \"foo bar\" has embedded whitespace",
>> +  "arg 'Jack said \\'hi\\'' has single quotes",
>> +  "arg 'Jack said \\\"hi\\\"' has double quotes",
>> +  "a b c d e f g h i j k l m n o p q r s t u v w x y z 1 2 3 4 5 6 7 8 9",
>> +  /* This should be expanded into only one argument.  */
>> +  "trailing-whitespace ",
>> +  NULL
>> +int
>> +main (void)
>> +  char **argv;
>> +  const char *const *test;
>> +  char **targs;
>> +  for (test = tests; *test != NULL; test++)
>> +      printf ("buildargv(\"%s\")\n", *test);
>> +      if ((argv = buildargv (*test)) == NULL)
>> +	  printf ("failed!\n\n");
>> +      else
>> +	  for (targs = argv; *targs != NULL; targs++)
>> +	      printf ("\t\"%s\"\n", *targs);
>> +	  printf ("\n");
>> +      freeargv (argv);
>> +  return 0;
>> +#endif	/* MAIN */
>> diff --git a/rtemstoolkit/wscript b/rtemstoolkit/wscript
>> index d1d5127..20b1047 100644
>> --- a/rtemstoolkit/wscript
>> +++ b/rtemstoolkit/wscript
>> @@ -410,7 +410,8 @@ def bld_libiberty(bld, conf):
>>                 includes = ['libiberty'],
>>                 cflags = conf['cflags'],
>>                 defines = defines,
>> -              source =['libiberty/concat.c',
>> +              source =['libiberty/argv.c',
>> +                       'libiberty/concat.c',
>>                          'libiberty/cplus-dem.c',
>>                          'libiberty/cp-demangle.c',
>>                          'libiberty/d-demangle.c',
> devel mailing list
> devel at rtems.org
