[PATCH] build: Use -frandom-seed=0
Wed Feb 28 07:24:04 UTC 2024
On 28.02.24 06:34, Chris Johns wrote:
> The manual says:
>    The string can either be a number (decimal, octal or hex) or
>    an arbitrary string (in which case it’s converted to a number by
>    computing CRC32).
>    The string should be different for every file you compile.
> I take this to mean the option `-frandom-seed=0` uses `0` as a number however it
> is the same for every file and the manual clearly says it must be different?
Using -frandom-seed=0 seems to be quite common on the internet. The
random seed is rarely used in GCC. The only use case in RTEMS I found is
related to the gcov code coverage instrumentation.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
