[PATCH 4/6] build: Add support to make bootloader images
Wed Feb 28 23:05:50 UTC 2024
On 28/2/2024 6:44 pm, Sebastian Huber wrote:
> On 28.02.24 06:48, Chris Johns wrote:
>> Hi,
>> Is this to allow BSP ready output to be created from the build system?
> Yes, this is the goal.
Nice and thanks for looking into this.
>> If it is will the details be exported in the pkgconfig file and made available
>> for users building applications in a consistent and easy to use way?
> Application build systems can query the tool using the RTEMS_MKIMAGE package
> configuration varible, for example:
>   pkg-config --variable=RTEMS_MKIMAGE
> ${prefix}/lib/pkgconfig/${ARCH}-${BSP_NAME}.pc
Nice. This is my preferred way of handling this.
> If the BSP does not provide a tool, then the variable RTEMS_MKIMAGE is set to
> "false".
So the process has to be a single command?
> It could help to export also EXEEXT and BOOT_IMAGE_EXTENSION in the package
> configuration file. For RTEMS 6, we should have a look how our package
> configuration support can be used to build applications on some commonly used
> build systems. We are currently not able to produce build images.
Yes we should. I also wonder if base addresses and other values that get used
should be prov
>> Is this output created along side the ELF file?
> Yes.
+1
>> Does this approach handle all BSPs that need this?
> The BSP can use Python, so I would say yes.
I am sorry I do not follow.
>> Will you be converting all BSPs that need this type of support?
> I will add support for the BSPs using U-Boot.
Could you please provide the high level view of how this is to be handled? I
have not reviewed all the detail in the patches to understand this and even then
I may get things wrong.
Should we create a GSoC project to review and support the other BSPs?
