[PATCH] build: Use -frandom-seed=0
Thu Feb 29 07:36:00 UTC 2024
On 29.02.24 00:29, Chris Johns wrote:
> On 28/2/2024 6:24 pm, Sebastian Huber wrote:
>> On 28.02.24 06:34, Chris Johns wrote:
>>> The manual says:
>>>     The string can either be a number (decimal, octal or hex) or
>>>     an arbitrary string (in which case it’s converted to a number by
>>>     computing CRC32).
>>>     The string should be different for every file you compile.
>>> I take this to mean the option `-frandom-seed=0` uses `0` as a number however it
>>> is the same for every file and the manual clearly says it must be different?
>> Using -frandom-seed=0 seems to be quite common on the internet. The random seed
>> is rarely used in GCC. The only use case in RTEMS I found is related to the gcov
>> code coverage instrumentation.
> There are lots of things that are common on the internet I ignore 😉
> Is this a bug in the documentation?
 From my point of view this random seed is a gray area in the compiler.
The cases in which it is used should not matter for the RTEMS build
(except for the code coverage):
https://gcc.gnu.org/pipermail/gcc-help/2024-February/143324.html
I will try to add it only to the coverage flags.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
