6.1rc2 on Rocky 9
Thu Feb 29 15:43:53 UTC 2024
Hi
Looks pretty good overall. This appears to be the only issue:
Testing: riscv rv64imac_spike
BSP to Build: rv64imac
'distclean' finished successfully (0.011s)
Regenerate build specification cache (needs a couple of seconds)...
real 0m25.545s
user 2m30.639s
sys 0m29.614s
*** /home/joel/rtems-6.1rc2/rtems
Exception in thread _stdout[spike]:
Traceback (most recent call last):
  File "/opt/rh/rh-python36/root/usr/lib64/python3.6/threading.py", line
916, in _bootstrap_inner
    self.run()
864, in run
    self._target(*self._args, **self._kwargs)
  File
"/home/joel/rtems-6.1rc2/tools/6/share/rtems/rtemstoolkit/execute.py", line
226, in _readthread
    data = data.decode(sys.stdout.encoding)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xff in position 0:
invalid start byte
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240229/b4556209/attachment.htm>
