[PATCH rtems-lwip 05/10] FIX: remove header files which are already provided by RTEMS
berndmoessner80 at gmail.com berndmoessner80 at gmail.com
Thu Jan 4 00:04:34 UTC 2024
From: Bernd Moessner <berndmoessner80 at gmail.com>
 defs/bsps/aarch64/xilinx_zynqmp_base.json     |   3 +-
 .../src/arm/ARMv8/64bit/xil_cache.h           |  75 ----
 .../standalone/src/arm/common/xil_exception.h | 408 ------------------
 rtemslwip/xilinx/xil_printf.h                 |  33 --
 rtemslwip/xilinx/xil_smc.h                    |   1 -
 5 files changed, 1 insertion(+), 519 deletions(-)
 delete mode 100644 embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_cache.h
 delete mode 100644 embeddedsw/lib/bsp/standalone/src/arm/common/xil_exception.h
 delete mode 100644 rtemslwip/xilinx/xil_printf.h
 delete mode 100644 rtemslwip/xilinx/xil_smc.h
diff --git a/defs/bsps/aarch64/xilinx_zynqmp_base.json b/defs/bsps/aarch64/xilinx_zynqmp_base.json
index 3e47434..600415d 100644
--- a/defs/bsps/aarch64/xilinx_zynqmp_base.json
+++ b/defs/bsps/aarch64/xilinx_zynqmp_base.json
@@ -6,8 +6,7 @@
 		"embeddedsw/XilinxProcessorIPLib/drivers/emacps/src",
 		"rtemslwip/xilinx",
 		"rtemslwip/zynqmp",
-		"embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit",
-		"embeddedsw/lib/bsp/standalone/src/arm/common"
+		"embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit"
 	"source-files-to-import": [
 		"rtemslwip/zynqmp/xemacps_g.c",
diff --git a/embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_cache.h b/embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_cache.h
deleted file mode 100644
index b878d05..0000000
--- a/embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_cache.h
+++ /dev/null
@@ -1,75 +0,0 @@
-* Copyright (c) 2014 - 2021 Xilinx, Inc.  All rights reserved.
-* SPDX-License-Identifier: MIT
-* @file xil_cache.h
-* @addtogroup a53_64_cache_apis Cortex A53 64bit Processor Cache Functions
-* Cache functions provide access to cache related operations such as flush
-* and invalidate for instruction and data caches. It gives option to perform
-* the cache operations on a single cacheline, a range of memory and an entire
-* cache.
-* <pre>
-* MODIFICATION HISTORY:
-* Ver   Who  Date     Changes
-* 5.00 	pkp  05/29/14 First release
-* </pre>
-#ifndef XIL_CACHE_H
-#define XIL_CACHE_H
-#include "xil_types.h"
-#ifdef __cplusplus
-extern "C" {
-#endif
- *@cond nocomments
-/************************** Constant Definitions *****************************/
-#define L1_DATA_PREFETCH_CONTROL_MASK  0xE000
-#define L1_DATA_PREFETCH_CONTROL_SHIFT  13
- *@endcond
-/***************** Macros (Inline Functions) Definitions *********************/
-#define Xil_DCacheFlushRange Xil_DCacheInvalidateRange
-/************************** Function Prototypes ******************************/
-void Xil_DCacheEnable(void);
-void Xil_DCacheDisable(void);
-void Xil_DCacheInvalidate(void);
-void Xil_DCacheInvalidateRange(INTPTR adr, INTPTR len);
-void Xil_DCacheInvalidateLine(INTPTR adr);
-void Xil_DCacheFlush(void);
-void Xil_DCacheFlushLine(INTPTR adr);
-void Xil_ICacheEnable(void);
-void Xil_ICacheDisable(void);
-void Xil_ICacheInvalidate(void);
-void Xil_ICacheInvalidateRange(INTPTR adr, INTPTR len);
-void Xil_ICacheInvalidateLine(INTPTR adr);
-void Xil_ConfigureL1Prefetch(u8 num);
-#ifdef __cplusplus
-#endif
-#endif
-* @} End of "addtogroup a53_64_cache_apis".
diff --git a/embeddedsw/lib/bsp/standalone/src/arm/common/xil_exception.h b/embeddedsw/lib/bsp/standalone/src/arm/common/xil_exception.h
index 144d842..0000000
--- a/embeddedsw/lib/bsp/standalone/src/arm/common/xil_exception.h
+++ /dev/null
@@ -1,408 +0,0 @@
-* Copyright (c) 2015 - 2022 Xilinx, Inc.  All rights reserved.
-* @file xil_exception.h
-* This header file contains ARM Cortex A53,A9,R5 specific exception related APIs.
-* For exception related functions that can be used across all Xilinx supported
-* processors, please use xil_exception.h.
-* @addtogroup arm_exception_apis ARM Processor Exception Handling
-* ARM processors specific exception related APIs for cortex A53,A9 and R5 can
-* utilized for enabling/disabling IRQ, registering/removing handler for
-* exceptions or initializing exception vector table with null handler.
-* <pre>
-* 5.2	pkp  	 28/05/15 First release
-* 6.0   mus      27/07/16 Consolidated file for a53,a9 and r5 processors
-* 6.7   mna      26/04/18 Add API Xil_GetExceptionRegisterHandler.
-* 6.7   asa      18/05/18 Update signature of API Xil_GetExceptionRegisterHandler.
-* 7.0   mus      01/03/19 Tweak Xil_ExceptionEnableMask and
-*                         Xil_ExceptionDisableMask macros to support legacy
-*                         examples for Cortexa72 EL3 exception level.
-* 7.3   mus      04/15/20 Added Xil_EnableNestedInterrupts and
-*                         Xil_DisableNestedInterrupts macros for ARMv8.
-*                         For Cortexa72, these macro's would not be supported
-*                         at EL3, as Cortexa72 is using GIC-500(GICv3),  which
-*                         triggeres only FIQ at EL3. Fix for CR#1062506
-* 7.6   mus      09/17/21 Updated flag checking to fix warning reported with
-*                         -Wundef compiler option CR#1110261
-* 7.7   mus      01/31/22 Few of the #defines in xil_exception.h in are treated
-*                         in different way based on "versal" flag. In existing
-*                         flow, this flag is defined only in xparameters.h and
-*                         BSP compiler flags, it is not defined in application
-*                         compiler flags. So, including xil_exception.h in
-*                         application source file, without including
-*                         xparameters.h results  in incorrect behavior.
-*                         Including xparameters.h in xil_exception.h to avoid
-*                         such issues. It fixes CR#1120498.
-* 7.7	sk	 03/02/22 Define XExc_VectorTableEntry structure to fix
-* 			  misra_c_2012_rule_5_6 violation.
-* 7.7	sk	 03/02/22 Add XExc_VectorTable as extern to fix misra_c_2012_
-* 			  rule_8_4 violation.
-* </pre>
- *@cond nocomments
-#ifndef XIL_EXCEPTION_H /* prevent circular inclusions */
-#define XIL_EXCEPTION_H /* by using protection macros */
-/***************************** Include Files ********************************/
-#include "xpseudo_asm.h"
-#include "bspconfig.h"
-#include "xparameters.h"
-#ifdef __cplusplus
-extern "C" {
-#endif
-/************************** Constant Definitions ****************************/
-#define XIL_EXCEPTION_FIQ	XREG_CPSR_FIQ_ENABLE
-#define XIL_EXCEPTION_IRQ	XREG_CPSR_IRQ_ENABLE
-#define XIL_EXCEPTION_ALL	(XREG_CPSR_FIQ_ENABLE | XREG_CPSR_IRQ_ENABLE)
-#define XIL_EXCEPTION_ID_FIRST			0U
-#if defined (__aarch64__)
-#define XIL_EXCEPTION_ID_SYNC_INT		1U
-#define XIL_EXCEPTION_ID_IRQ_INT		2U
-#define XIL_EXCEPTION_ID_FIQ_INT		3U
-#define XIL_EXCEPTION_ID_SERROR_ABORT_INT		4U
-#define XIL_EXCEPTION_ID_LAST			5U
-#else
-#define XIL_EXCEPTION_ID_RESET			0U
-#define XIL_EXCEPTION_ID_UNDEFINED_INT		1U
-#define XIL_EXCEPTION_ID_SWI_INT		2U
-#define XIL_EXCEPTION_ID_PREFETCH_ABORT_INT	3U
-#define XIL_EXCEPTION_ID_DATA_ABORT_INT		4U
-#define XIL_EXCEPTION_ID_IRQ_INT		5U
-#define XIL_EXCEPTION_ID_FIQ_INT		6U
-#define XIL_EXCEPTION_ID_LAST			6U
-#endif
- * XIL_EXCEPTION_ID_INT is defined for all Xilinx processors.
-#if defined (versal) && !defined(ARMR5) && EL3
-#define XIL_EXCEPTION_ID_INT    XIL_EXCEPTION_ID_FIQ_INT
-#else
-#define XIL_EXCEPTION_ID_INT	XIL_EXCEPTION_ID_IRQ_INT
-#endif
-/**************************** Type Definitions ******************************/
- * This typedef is the exception handler function.
-typedef void (*Xil_ExceptionHandler)(void *data);
-typedef void (*Xil_InterruptHandler)(void *data);
-typedef struct {
-        Xil_ExceptionHandler Handler;
-        void *Data;
-} XExc_VectorTableEntry;
-extern XExc_VectorTableEntry XExc_VectorTable[];
-*@endcond
-/***************** Macros (Inline Functions) Definitions ********************/
-* @brief	Enable Exceptions.
-* @param	Mask: Value for enabling the exceptions.
-* @return	None.
-* @note		If bit is 0, exception is enabled.
-*			C-Style signature: void Xil_ExceptionEnableMask(Mask)
- * Cortexa72 processor in versal is coupled with GIC-500, and GIC-500 supports
- * only FIQ at EL3. Hence, tweaking this macro to always enable FIQ
- * ignoring argument passed by user.
-#define Xil_ExceptionEnableMask(Mask)	\
-		mtcpsr(mfcpsr() & ~ ((XIL_EXCEPTION_FIQ) & XIL_EXCEPTION_ALL))
-#elif defined (__GNUC__) || defined (__ICCARM__)
-		mtcpsr(mfcpsr() & ~ ((Mask) & XIL_EXCEPTION_ALL))
-#else
-		  register u32 Reg __asm("cpsr"); \
-		  mtcpsr((Reg) & (~((Mask) & XIL_EXCEPTION_ALL))); \
-#endif
-* @brief	Enable the IRQ exception.
-* @return   None.
-* @note     None.
-#define Xil_ExceptionEnable() \
-                Xil_ExceptionEnableMask(XIL_EXCEPTION_FIQ)
-#else
-		Xil_ExceptionEnableMask(XIL_EXCEPTION_IRQ)
-#endif
-* @brief	Disable Exceptions.
-* @param	Mask: Value for disabling the exceptions.
-* @return	None.
-* @note		If bit is 1, exception is disabled.
-*			C-Style signature: Xil_ExceptionDisableMask(Mask)
- * only FIQ at EL3. Hence, tweaking this macro to always disable FIQ
-#define Xil_ExceptionDisableMask(Mask)	\
-		mtcpsr(mfcpsr() | ((XIL_EXCEPTION_FIQ) & XIL_EXCEPTION_ALL))
-		mtcpsr(mfcpsr() | ((Mask) & XIL_EXCEPTION_ALL))
-#else
-		  mtcpsr((Reg) | ((Mask) & XIL_EXCEPTION_ALL)); \
-#endif
-* Disable the IRQ exception.
-* @return   None.
-* @note     None.
-#define Xil_ExceptionDisable() \
-		Xil_ExceptionDisableMask(XIL_EXCEPTION_IRQ)
-#if ( defined (PLATFORM_ZYNQMP) && defined (EL3) && (EL3==1) )
-* @brief	Enable nested interrupts by clearing the I bit in DAIF.This
-*			macro is defined for Cortex-A53 64 bit mode BSP configured to run
-*			at EL3.. However,it is not defined for Versal Cortex-A72 BSP
-*			configured to run at EL3. Reason is, Cortex-A72 is coupled
-*			with GIC-500(GICv3 specifications) and it triggers only FIQ at EL3.
-* @return   None.
-* @note     This macro is supposed to be used from interrupt handlers. In the
-*			interrupt handler the interrupts are disabled by default (I bit
-*			is set as 1). To allow nesting of interrupts, this macro should be
-*			used. It clears the I bit. Once that bit is cleared and provided the
-*			preemption of interrupt conditions are met in the GIC, nesting of
-*			interrupts will start happening.
-*			Caution: This macro must be used with caution. Before calling this
-*			macro, the user must ensure that the source of the current IRQ
-*			is appropriately cleared. Otherwise, as soon as we clear the I
-*			bit, there can be an infinite loop of interrupts with an
-*			eventual crash (all the stack space getting consumed).
-#define Xil_EnableNestedInterrupts() \
-                __asm__ __volatile__ ("mrs    X1, ELR_EL3"); \
-                __asm__ __volatile__ ("mrs    X2, SPSR_EL3");  \
-                __asm__ __volatile__ ("stp    X1,X2, [sp,#-0x10]!"); \
-                __asm__ __volatile__ ("mrs    X1, DAIF");  \
-                __asm__ __volatile__ ("bic    X1,X1,#(0x1<<7)");  \
-                __asm__ __volatile__ ("msr    DAIF, X1");  \
-* @brief	Disable the nested interrupts by setting the I bit in DAIF. This
-*			at EL3.
-* @return   None.
-* @note     This macro is meant to be called in the interrupt service routines.
-*			This macro cannot be used independently. It can only be used when
-*			nesting of interrupts have been enabled by using the macro
-*			Xil_EnableNestedInterrupts(). In a typical flow, the user first
-*			calls the Xil_EnableNestedInterrupts in the ISR at the appropriate
-*			point. The user then must call this macro before exiting the interrupt
-*			service routine. This macro puts the ARM back in IRQ mode and
-*			hence sets back the I bit.
-#define Xil_DisableNestedInterrupts() \
-                __asm__ __volatile__ ("ldp    X1,X2, [sp,#0x10]!"); \
-                __asm__ __volatile__ ("msr    ELR_EL3, X1"); \
-                __asm__ __volatile__ ("msr    SPSR_EL3, X2"); \
-                __asm__ __volatile__ ("orr    X1, X1, #(0x1<<7)"); \
-#elif (defined (EL1_NONSECURE) && (EL1_NONSECURE==1))
-*			macro is defined for Cortex-A53 64 bit mode and Cortex-A72 64 bit
-*			BSP configured to run at EL1 NON SECURE
-* @return   None.
-                __asm__ __volatile__ ("mrs    X1, ELR_EL1"); \
-                __asm__ __volatile__ ("mrs    X2, SPSR_EL1");  \
-* @return   None.
-                __asm__ __volatile__ ("msr    ELR_EL1, X1"); \
-                __asm__ __volatile__ ("msr    SPSR_EL1, X2"); \
-#elif (!defined (__aarch64__) && !defined (ARMA53_32))
-* @brief	Enable nested interrupts by clearing the I and F bits in CPSR. This
-* 			API is defined for cortex-a9 and cortex-r5.
-* @return   None.
-*			interrupt handler the interrupts are disabled by default (I and F
-*			are 1). To allow nesting of interrupts, this macro should be
-*			used. It clears the I and F bits by changing the ARM mode to
-*			system mode. Once these bits are cleared and provided the
-*			is appropriately cleared. Otherwise, as soon as we clear the I and
-*			F bits, there can be an infinite loop of interrupts with an
-		__asm__ __volatile__ ("stmfd   sp!, {lr}"); \
-		__asm__ __volatile__ ("mrs     lr, spsr");  \
-		__asm__ __volatile__ ("msr     cpsr_c, #0x1F"); \
-* @brief	Disable the nested interrupts by setting the I and F bits. This API
-*			is defined for cortex-a9 and cortex-r5.
-* @return   None.
-*			service routine. This macro puts the ARM back in IRQ/FIQ mode and
-*			hence sets back the I and F bits.
-		__asm__ __volatile__ ("ldmfd   sp!, {lr}");   \
-		__asm__ __volatile__ ("msr     cpsr_c, #0x92"); \
-		__asm__ __volatile__ ("msr     spsr_cxsf, lr"); \
-#endif
-/************************** Variable Definitions ****************************/
-/************************** Function Prototypes *****************************/
-extern void Xil_ExceptionRegisterHandler(u32 Exception_id,
-					 Xil_ExceptionHandler Handler,
-					 void *Data);
-extern void Xil_ExceptionRemoveHandler(u32 Exception_id);
-extern void Xil_GetExceptionRegisterHandler(u32 Exception_id,
-					Xil_ExceptionHandler *Handler, void **Data);
-extern void Xil_ExceptionInit(void);
-void Xil_SyncAbortHandler(void *CallBackRef);
-void Xil_SErrorAbortHandler(void *CallBackRef);
-#else
-extern void Xil_DataAbortHandler(void *CallBackRef);
-extern void Xil_PrefetchAbortHandler(void *CallBackRef);
-extern void Xil_UndefinedExceptionHandler(void *CallBackRef);
-#endif
-#ifdef __cplusplus
-#endif /* __cplusplus */
-#endif /* XIL_EXCEPTION_H */
-* @} End of "addtogroup arm_exception_apis".
diff --git a/rtemslwip/xilinx/xil_printf.h b/rtemslwip/xilinx/xil_printf.h
index 3da55bd..0000000
--- a/rtemslwip/xilinx/xil_printf.h
+++ /dev/null
@@ -1,33 +0,0 @@
- * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
- * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
-#ifndef XIL_PRINTF_H
-#define XIL_PRINTF_H
-#define xil_printf( args ... ) printf( args )
-#define print( args ... ) printf( args )
-#endif
diff --git a/rtemslwip/xilinx/xil_smc.h b/rtemslwip/xilinx/xil_smc.h
index d35e631..0000000
--- a/rtemslwip/xilinx/xil_smc.h
+++ /dev/null
@@ -1 +0,0 @@
-/* This file is a stub and intentionally left blank */
2.34.1
