[PATCH rtems 07/14] Flashdev: Refactor write_block_size and add function to dergister flashdev
berndmoessner80 at gmail.com berndmoessner80 at gmail.com
Tue Jan 2 20:45:28 UTC 2024
From: Bernd Moessner <berndmoessner80 at gmail.com>
 cpukit/dev/flash/flashdev.c                   |  71 ++++--
 cpukit/include/dev/flash/flashdev.h           |  22 +-
 cpukit/libmisc/shell/main_flashdev.c          |  26 +--
 testsuites/libtests/flashdev01/init.c         | 204 ++++++++++++------
 .../libtests/flashdev01/test_flashdev.c       |  54 +++--
 .../libtests/flashdev01/test_flashdev.h       |   4 +-
 6 files changed, 264 insertions(+), 117 deletions(-)
diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
index 0020e8d2c1..f50d2235a1 100644
--- a/cpukit/dev/flash/flashdev.c
+++ b/cpukit/dev/flash/flashdev.c
@@ -124,7 +124,7 @@ static int rtems_flashdev_ioctl_get_page_count(
   void *arg
-static int rtems_flashdev_ioctl_get_write_block_size(
+static int rtems_flashdev_ioctl_get_min_write_size(
   rtems_flashdev *flash,
   void *arg
@@ -146,8 +146,7 @@ static int rtems_flashdev_get_abs_addr(
 static int rtems_flashdev_update_and_return(
   rtems_libio_t *iop,
   int status,
-  size_t count,
-  off_t new_offset
+  size_t count
 static uint32_t rtems_flashdev_find_unallocated_region(
@@ -225,13 +224,20 @@ static const rtems_filesystem_file_handlers_r rtems_flashdev_handler = {
   .poll_h = rtems_filesystem_default_poll,
   .readv_h = rtems_filesystem_default_readv,
   .writev_h = rtems_filesystem_default_writev };
 static const IMFS_node_control
   rtems_flashdev_node_control = IMFS_GENERIC_INITIALIZER(
     &rtems_flashdev_handler,
     IMFS_node_initialize_generic,
     rtems_flashdev_node_destroy
+static const IMFS_node_control rtems_flashdev_node_control = {
+  .handlers = &rtems_flashdev_handler,
+  .node_initialize = IMFS_node_initialize_generic,
+  .node_remove = IMFS_node_remove_default,
+  .node_destroy = rtems_flashdev_node_destroy
 static void rtems_flashdev_node_destroy(
   IMFS_jnode_t *node
@@ -321,7 +327,7 @@ static int rtems_flashdev_read_write(
   int status;
   if ( read_buff == NULL && write_buff == NULL ) {
-    return 0;
+    return EINVAL;
   /* Get flash address */
@@ -335,12 +341,35 @@ static int rtems_flashdev_read_write(
   if ( read_buff != NULL ) {
     status = ( *flash->read )( flash, addr, count, read_buff );
   } else if ( write_buff != NULL ) {
+    size_t min_write_size = 0;
+    status = (flash)->get_min_write_size(flash, &min_write_size);
+    if ( status < 0 ) {
+      return status;
+    if (0 == min_write_size )
+      rtems_set_errno_and_return_minus_one( EIO );
+    else
+      if (count % min_write_size)
+        rtems_set_errno_and_return_minus_one( EINVAL );
+      if (addr % min_write_size)
+        rtems_set_errno_and_return_minus_one( EFAULT );
     status = ( *flash->write )( flash, addr, count, write_buff );
   rtems_flashdev_release( flash );
   /* Update offset and return */
-  return rtems_flashdev_update_and_return( iop, status, count, addr + count );
+  return rtems_flashdev_update_and_return( iop, status, count );
 static int rtems_flashdev_ioctl(
@@ -388,8 +417,8 @@ static int rtems_flashdev_ioctl(
     case RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT:
       err = rtems_flashdev_ioctl_get_page_count( flash, arg );
       break;
-    case RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE:
-      err = rtems_flashdev_ioctl_get_write_block_size( flash, arg );
+    case RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_SIZE:
+      err = rtems_flashdev_ioctl_get_min_write_size( flash, arg );
       break;
     default:
       err = EINVAL;
@@ -486,6 +515,18 @@ int rtems_flashdev_register(
   return rv;
+int rtems_flashdev_deregister(
+  const char *flash_path
+  rtems_filesystem_eval_path_context_t ctx;
+  int eval_flags = RTEMS_FS_FOLLOW_LINK;
+  const rtems_filesystem_location_info_t *currentloc =
+    rtems_filesystem_eval_path_start( &ctx , flash_path, eval_flags );
+  return IMFS_rmnod(NULL, currentloc);
 static int rtems_flashdev_do_init(
   void ( *destroy )( rtems_flashdev *flash )
@@ -503,7 +544,7 @@ static int rtems_flashdev_do_init(
   flash->get_page_info_by_offset = NULL;
   flash->get_page_info_by_index = NULL;
   flash->get_page_count = NULL;
-  flash->get_write_block_size = NULL;
+  flash->get_min_write_size = NULL;
   flash->region_table = NULL;
   return 0;
@@ -520,7 +561,6 @@ void rtems_flashdev_destroy_and_free( rtems_flashdev *flash )
   rtems_recursive_mutex_destroy( &( flash->mutex ) );
   free( flash );
-  flash = NULL;
   return;
@@ -602,13 +642,12 @@ static int rtems_flashdev_get_abs_addr(
   rtems_libio_t *iop,
   int status,
-  size_t count,
-  off_t new_offset
+  size_t count
   if ( status == 0 ) {
-    iop->offset = new_offset;
+    iop->offset += count;
     return count;
   } else {
     rtems_set_errno_and_return_minus_one( status );
@@ -847,7 +886,7 @@ static int rtems_flashdev_ioctl_get_page_count( rtems_flashdev *flash, void *arg
   void *arg
@@ -855,10 +894,10 @@ static int rtems_flashdev_ioctl_get_write_block_size(
   if ( arg == NULL ) {
-  if ( flash->get_write_block_size == NULL ) {
+  if ( flash->get_min_write_size == NULL ) {
     return 0;
   } else {
-    return ( *flash->get_write_block_size )( flash, ( (size_t *) arg ) );
+    return ( *flash->get_min_write_size )( flash, ( (size_t *) arg ) );
diff --git a/cpukit/include/dev/flash/flashdev.h b/cpukit/include/dev/flash/flashdev.h
index 6244d38e3a..f6973df2a3 100644
--- a/cpukit/include/dev/flash/flashdev.h
+++ b/cpukit/include/dev/flash/flashdev.h
@@ -142,7 +142,7 @@ typedef struct rtems_flashdev rtems_flashdev;
  * @param[out] count Integer containing the minimum write size.
-#define RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE 10
+#define RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_SIZE 10
  * @brief The maximum number of region limited file descriptors
@@ -354,14 +354,14 @@ struct rtems_flashdev {
    * @brief Call to device driver to return the minimum write size of the
    * flash device.
-   * @param[out] write_block_size The minimum write size of the flash device.
+   * @param[out] min_write_size The minimum write size of the flash device.
    * @retval 0 Success.
    * @retval non-zero Failed.
-  int ( *get_write_block_size )(
+  int ( *get_min_write_size )(
     rtems_flashdev *flashdev,
-    size_t *write_block_size
+    size_t *min_write_size
@@ -441,6 +441,20 @@ int rtems_flashdev_register(
+ * @brief Deregister the flash device.
+ * This function removes the node allocated for the flash device.
+ * @param[in] flash_path The path to the flash device file.
+ * @retval 0 Successful operation.
+ * @retval non-zero Failed operation.
  * @brief Destroys the flash device.
diff --git a/cpukit/libmisc/shell/main_flashdev.c b/cpukit/libmisc/shell/main_flashdev.c
index 516c77ae27..5851adfeef 100644
--- a/cpukit/libmisc/shell/main_flashdev.c
+++ b/cpukit/libmisc/shell/main_flashdev.c
@@ -40,7 +40,7 @@ static int flashdev_shell_get_jedec_id(char *dev_path);
 static int flashdev_shell_get_page_by_off(char *dev_path, int argc, char *argv[]);
 static int flashdev_shell_get_page_by_idx(char *dev_path, int argc, char *argv[]);
 static int flashdev_shell_get_pg_count(char *dev_path);
-static int flashdev_shell_get_wb_size(char *dev_path);
+static int flashdev_shell_get_min_write_size(char *dev_path);
 static int flashdev_shell_ioctl_value(
   char *dev_path,
@@ -67,7 +67,7 @@ static const char rtems_flashdev_shell_usage [] =
   "   -o <address>          Print the page information of page at address\n"
   "   -i <index>            Print the page information of page at index\n"
   "   -p                    Print the number of pages\n"
-  "   -b                    Print the write block size\n"
+  "   -b                    Print the min. write size\n"
   "   -h                    Print this help\n";
@@ -98,23 +98,23 @@ static int rtems_flashdev_shell_main( int argc, char *argv[] ) {
         /* Erase */
         return flashdev_shell_erase(dev_path, argc, &argv[i]);
       case ('t'):
-        /* Flash Type */
+        /* Get flash Type */
         return flashdev_shell_get_type(dev_path);
       case ('d'):
-        /* JEDEC Id */
+        /* Get JEDEC Id */
         return flashdev_shell_get_jedec_id(dev_path);
       case ('o'):
-        /* Page info by offset */
+        /* Get page info by offset */
         return flashdev_shell_get_page_by_off(dev_path, argc, &argv[i]);
       case ('i'):
-        /* Page info by index */
+        /* Get page info by index */
         return flashdev_shell_get_page_by_idx(dev_path, argc, &argv[i]);
       case ('p'):
-        /* Page count */
+        /* Get page count */
         return flashdev_shell_get_pg_count(dev_path);
       case ('b'):
-        /* Write block size */
-        return flashdev_shell_get_wb_size(dev_path);
+        /* Get min write size */
+        return flashdev_shell_get_min_write_size(dev_path);
       case ('h'):
       default:
         /* Help */
@@ -480,7 +480,7 @@ static int flashdev_shell_get_pg_count( char *dev_path )
   return 0;
-static int flashdev_shell_get_wb_size( char *dev_path )
+static int flashdev_shell_get_min_write_size( char *dev_path )
   size_t ret;
   int status;
@@ -488,16 +488,16 @@ static int flashdev_shell_get_wb_size( char *dev_path )
   /* Get Write Block Size */
   status = flashdev_shell_ioctl_value(
     dev_path,
-    RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE,
+    RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_SIZE,
     &ret
   /* Print Write Block Size */
   if (status) {
-    printf("Failed to get write block size\n");
+    printf("Failed to get min write size\n");
     return status;
   } else {
-    printf("Write block size: 0x%zx\n", ret);
+    printf("Min. Write size: 0x%zx\n", ret);
   return 0;
diff --git a/testsuites/libtests/flashdev01/init.c b/testsuites/libtests/flashdev01/init.c
index 30af3f33c1..dc174daa62 100644
--- a/testsuites/libtests/flashdev01/init.c
+++ b/testsuites/libtests/flashdev01/init.c
@@ -34,14 +34,15 @@
 #include <fcntl.h>
 #include <sys/ioctl.h>
-#define TEST_NAME_LENGTH 10
 #define TEST_DATA_SIZE (PAGE_SIZE * PAGE_COUNT)
 #define PAGE_COUNT 16
 #define PAGE_SIZE 128
-#define WB_SIZE 1
+#define MIN_WRITE_SIZE 1
 const char rtems_test_name[] = "FLASHDEV 1";
+const char test_string[] = "My test string!";
 static void run_test(void);
@@ -53,89 +54,134 @@ static void run_test(void) {
   rtems_flashdev* flash;
   int status;
   char* read_data;
+  size_t bytes_read;
   rtems_flashdev_region e_args;
   rtems_flashdev_ioctl_page_info pg_info;
   rtems_flashdev_region region;
   uint32_t jedec;
   int page_count;
   int type;
-  size_t wb_size;
+  size_t min_write_size_in[] = {1,8,16};
+  size_t min_write_size_out;
+  const char flash_path[] = "/dev/flashdev0";
+  for ( int loop = 0; loop <= 2; loop++)
+    /* Initalize the flash device driver and flashdev */
+    flash = test_flashdev_init(min_write_size_in[loop]);
+    rtems_test_assert(flash != NULL);
+    /* Register the flashdev as a device */
+    status = rtems_flashdev_register(flash, flash_path);
+    rtems_test_assert(!status);
+    /* Open the flashdev */
+    file = fopen(flash_path, "r+");
+    rtems_test_assert(file != NULL);
+    /* Adjust the file buffering */
+    status = setvbuf(file, NULL, _IOFBF, min_write_size_in[loop]);
+    fd = fileno(file);
+    /* Read data from flash */
+    read_data = fgets(buff, TEST_DATA_SIZE, file);
+    rtems_test_assert(read_data != NULL);
+    /* Fseek to start of flash and read again */
+    status = fseek(file, 0x0, SEEK_SET);
+    bytes_read = fread(buff, 1, TEST_DATA_SIZE, file);
+    rtems_test_assert(bytes_read == TEST_DATA_SIZE);
+    /* Fseek to start of flash */
+    /* Write the test name to the flash */
+    status = fwrite(test_string, 1, sizeof(test_string), file);
+    rtems_test_assert(status == sizeof(test_string));
+    fgets(buff, TEST_DATA_SIZE, file);
+    rtems_test_assert(!strncmp(buff, test_string, sizeof(test_string)));
+    /* Test Erasing */
+    e_args.offset = 0x0;
+    e_args.size = PAGE_SIZE;
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_ERASE, &e_args);
+    fseek(file, 0x0, SEEK_SET);
+    rtems_test_assert(buff[0] == 0);
+    /* Test getting JEDEC ID */
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_JEDEC_ID, &jedec);
+    rtems_test_assert(jedec == 0x00ABCDEF);
+    /* Test getting flash type */
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_TYPE, &type);
+    rtems_test_assert(type == RTEMS_FLASHDEV_NOR);
+    /* Test getting page info from offset */
+    pg_info.location = PAGE_SIZE + PAGE_SIZE/2;
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET, &pg_info);
+    rtems_test_assert(pg_info.page_info.offset == PAGE_SIZE);
+    rtems_test_assert(pg_info.page_info.size == PAGE_SIZE);
+    /* Test getting page info from index */
+    pg_info.location = 2;
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX, &pg_info);
+    rtems_test_assert(pg_info.page_info.offset == 2*PAGE_SIZE);
+    /* Test getting page count */
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT, &page_count);
+    rtems_test_assert(page_count == PAGE_COUNT);
+    /* Test getting min write size */
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_SIZE, &min_write_size_out);
+    rtems_test_assert(0 == memcmp(&min_write_size_out, &min_write_size_in[loop] , sizeof(size_t)));
+    /* Close the file handle */
+    status = fclose(file);
+    /* Deregister path */
+    status = rtems_flashdev_deregister(flash_path);
+    test_flashdev_deinit(flash);
-  flash = test_flashdev_init();
+  flash = test_flashdev_init(min_write_size_in[1]);
-  status = rtems_flashdev_register(flash, "dev/flashdev0");
-  file = fopen("dev/flashdev0", "r+");
-  fd = fileno(file);
-  /* Read data from flash */
-  read_data = fgets(buff, TEST_DATA_SIZE, file);
-  rtems_test_assert(read_data != NULL);
-  /* Fseek to start of flash */
-  status = fseek(file, 0x0, SEEK_SET);
-  rtems_test_assert(!status);
-  /* Write the test name to the flash */
-  status = fwrite(rtems_test_name, TEST_NAME_LENGTH, 1, file);
-  rtems_test_assert(status == 1);
-  /* Fseek to start of flash and read again */
-  fgets(buff, TEST_DATA_SIZE, file);
-  rtems_test_assert(!strncmp(buff, rtems_test_name, TEST_NAME_LENGTH));
-  /* Test Erasing */
-  e_args.offset = 0x0;
-  e_args.size = PAGE_SIZE;
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_ERASE, &e_args);
+  status = setvbuf(file, NULL, _IOFBF, min_write_size_in[1]);
-  fseek(file, 0x0, SEEK_SET);
-  rtems_test_assert(buff[0] == 0);
-  /* Test getting JEDEC ID */
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_JEDEC_ID, &jedec);
-  rtems_test_assert(jedec == 0x00ABCDEF);
-  /* Test getting flash type */
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_TYPE, &type);
-  rtems_test_assert(type == RTEMS_FLASHDEV_NOR);
-  /* Test getting page info from offset */
-  pg_info.location = PAGE_SIZE + PAGE_SIZE/2;
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET, &pg_info);
-  rtems_test_assert(pg_info.page_info.offset == PAGE_SIZE);
-  rtems_test_assert(pg_info.page_info.size == PAGE_SIZE);
-  /* Test getting page info from index */
-  pg_info.location = 2;
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX, &pg_info);
-  rtems_test_assert(pg_info.page_info.offset == 2*PAGE_SIZE);
-  /* Test getting page count */
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT, &page_count);
-  rtems_test_assert(page_count == PAGE_COUNT);
-  /* Test getting write block size */
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE, &wb_size);
-  rtems_test_assert(wb_size == WB_SIZE);
   /* Test Regions */
   region.offset = 0x400;
@@ -143,10 +189,16 @@ static void run_test(void) {
   status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_SET_REGION, &region);
+  /* Test read within then region */
+  bytes_read = fread(buff, 1, 0x200, file);
+  rtems_test_assert(bytes_read == 0x200);
   /* Test read to larger then region */
   read_data = fgets(buff, 2048, file);
-  rtems_test_assert(read_data == NULL);
   /* Test fseek outside of region */
   status = fseek(file, 0x201, SEEK_SET);
@@ -154,11 +206,21 @@ static void run_test(void) {
   /* Write to base unset region and check the writes location */
-  fwrite("HELLO WORLD", 11, 1, file);
+  fwrite("HELLO WORLD!!!!!", 1, 16, file);
   ioctl(fd, RTEMS_FLASHDEV_IOCTL_UNSET_REGION, NULL);
   fseek(file, 0x400, SEEK_SET);
-  fgets(buff, 11, file);
-  rtems_test_assert(strncmp(buff, "HELLO WORLD", 11));
+  fgets(buff, 16, file);
+  rtems_test_assert(strncmp(buff, "HELLO WORLD!!!!!", 16));
 static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/flashdev01/test_flashdev.c b/testsuites/libtests/flashdev01/test_flashdev.c
index d97f5d8145..0022210668 100644
--- a/testsuites/libtests/flashdev01/test_flashdev.c
+++ b/testsuites/libtests/flashdev01/test_flashdev.c
@@ -33,11 +33,12 @@
-#define WB_SIZE 1
 #define MAX_NUM_REGIONS 48
 #define BITALLOC_SIZE 32
 #define NUM_BITALLOC ((MAX_NUM_REGIONS + BITALLOC_SIZE - 1) / BITALLOC_SIZE)
+static size_t g_min_write_size = 0;
  * This flash device driver is for testing flashdev
  * API calls.
@@ -68,9 +69,9 @@ int test_flashdev_get_page_count(
   int *page_count
-int test_flashdev_get_wb_size(
+int test_flashdev_get_min_write_size(
 uint32_t test_flashdev_get_jedec_id(
@@ -102,7 +103,7 @@ int test_flashdev_erase(
   size_t count
-/* Find page info by offset handler */
+/* Get page info by offset handler */
 int test_flashdev_get_page_by_off(
   off_t search_offset,
@@ -115,7 +116,7 @@ int test_flashdev_get_page_by_off(
   return 0;
-/* Find page by index handler */
+/* Get page info by index handler */
 int test_flashdev_get_page_by_index(
   off_t search_index,
@@ -128,7 +129,7 @@ int test_flashdev_get_page_by_index(
   return 0;
-/* Page count handler */
+/* Get page count handler */
   int *page_count
@@ -138,13 +139,13 @@ int test_flashdev_get_page_count(
   return 0;
-/* Write block size handler */
+/* Get min. write size handler */
-  *write_block_size = WB_SIZE;
+  *min_write_size = g_min_write_size;
   return 0;
@@ -230,8 +231,13 @@ int test_flashdev_erase(
 /* Initialize Flashdev and underlying driver. */
-rtems_flashdev* test_flashdev_init(void)
+rtems_flashdev* test_flashdev_init(size_t min_write_size)
+  if (0 == min_write_size) {
+    return NULL;
+  g_min_write_size = min_write_size;
   rtems_flashdev *flash = rtems_flashdev_alloc_and_init(sizeof(rtems_flashdev));
   if (flash == NULL) {
@@ -268,8 +274,32 @@ rtems_flashdev* test_flashdev_init(void)
   flash->get_page_info_by_offset = &test_flashdev_get_page_by_off;
   flash->get_page_info_by_index = &test_flashdev_get_page_by_index;
   flash->get_page_count = &test_flashdev_get_page_count;
-  flash->get_write_block_size = &test_flashdev_get_wb_size;
+  flash->get_min_write_size = &test_flashdev_get_min_write_size;
   flash->region_table = ftable;
   return flash;
+/* Free Flashdev and underlying driver. */
+void test_flashdev_deinit(
+  rtems_flashdev* flash
+  if (NULL != flash)
+    if (NULL != flash->driver)
+      free(flash->region_table);
+      test_flashdev* flash_driver = (test_flashdev*) flash->driver;
+      if (NULL != flash_driver->data)
+        free( flash_driver->data);
+      free(flash->driver);
+    rtems_flashdev_destroy_and_free(flash);
diff --git a/testsuites/libtests/flashdev01/test_flashdev.h b/testsuites/libtests/flashdev01/test_flashdev.h
index 8b03959c42..ad995854ea 100644
--- a/testsuites/libtests/flashdev01/test_flashdev.h
+++ b/testsuites/libtests/flashdev01/test_flashdev.h
@@ -30,6 +30,8 @@
 #include <dev/flash/flashdev.h>
-rtems_flashdev* test_flashdev_init(void);
+rtems_flashdev* test_flashdev_init(size_t min_write_size);
+void test_flashdev_deinit(rtems_flashdev* flash);
 #endif /* __TEST_FLASHDEV_H */
2.34.1
