[PATCH rtems 14/14] FIX: 80 char per line limit issues
berndmoessner80 at gmail.com berndmoessner80 at gmail.com
Tue Jan 2 20:45:35 UTC 2024
From: Bernd Moessner <berndmoessner80 at gmail.com>
 cpukit/dev/flash/flashdev.c                   | 43 +++++++++++++------
 cpukit/include/dev/flash/flashdev.h           |  3 +-
 cpukit/libmisc/shell/main_flashdev.c          | 10 ++++-
 testsuites/libtests/flashdev01/init.c         | 17 ++++++--
 .../libtests/flashdev01/test_flashdev.h       |  7 ++-
 5 files changed, 60 insertions(+), 20 deletions(-)
diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
index ee01b8b447..ee06007a53 100644
--- a/cpukit/dev/flash/flashdev.c
+++ b/cpukit/dev/flash/flashdev.c
@@ -415,7 +415,9 @@ static off_t rtems_flashdev_get_partition_offset(
   /* Region is already checked to be defined */
-  assert( rtems_flashdev_get_active_partition_index( iop ) != RTEMS_FLASHDEV_PARTITION_UNDEFINED );
+  assert( rtems_flashdev_get_active_partition_index( iop ) !=
+                                        RTEMS_FLASHDEV_PARTITION_UNDEFINED );
   rtems_flashdev_partition *table = flash->partition_table;
   return table[ rtems_flashdev_get_active_partition_index( iop ) ].offset;
@@ -426,7 +428,9 @@ static size_t rtems_flashdev_get_partition_size(
   return table[ rtems_flashdev_get_active_partition_index( iop ) ].size;
@@ -557,7 +561,8 @@ static int rtems_flashdev_open(
   int ret = rtems_filesystem_default_open( iop, path, oflag, mode );
-  rtems_flashdev_mark_partition_defined(iop, RTEMS_FLASHDEV_PARTITION_UNDEFINED);
+  rtems_flashdev_mark_partition_defined(iop,
+                                        RTEMS_FLASHDEV_PARTITION_UNDEFINED);
   return ret;
@@ -700,8 +705,8 @@ static bool rtems_flashdev_is_a_partition_active(
   rtems_libio_t *iop
-  return (rtems_flashdev_get_active_partition_index( iop )
-    != RTEMS_FLASHDEV_PARTITION_UNDEFINED);
+  return (rtems_flashdev_get_active_partition_index( iop ) !=
 static bool rtems_flashdev_is_partition_defined(
@@ -719,7 +724,8 @@ static int rtems_flashdev_activate_partition(
   if(!rtems_flashdev_is_partition_defined(iop, partition_idx)){return -1;}
-  iop->data0 = set_bit(iop->data0, partition_idx + RTEMS_FLASHDEV_MAX_PARTITIONS);
+  iop->data0 = set_bit( iop->data0,
+                        partition_idx + RTEMS_FLASHDEV_MAX_PARTITIONS);
   return 0;
@@ -729,7 +735,8 @@ static int rtems_flashdev_deactivate_partition(
-  iop->data0 = clear_bit(iop->data0, partition_idx + RTEMS_FLASHDEV_MAX_PARTITIONS);
+  iop->data0 = clear_bit( iop->data0,
   return 0;
@@ -834,7 +841,9 @@ rtems_flashdev *rtems_flashdev_alloc_and_init( size_t size )
     flash = calloc( 1, size );
     if ( NULL != flash ) {
       int rv;
-      rtems_flashdev_partition * table = calloc( RTEMS_FLASHDEV_MAX_PARTITIONS, sizeof(rtems_flashdev_partition));
+      rtems_flashdev_partition * table = calloc( RTEMS_FLASHDEV_MAX_PARTITIONS,
+                                            sizeof(rtems_flashdev_partition));
       rv = rtems_flashdev_do_init( flash, rtems_flashdev_destroy_and_free );
       if ( (rv != 0) || (table == NULL) ) {
         rtems_recursive_mutex_destroy( &flash->mutex );
@@ -943,7 +952,10 @@ static int rtems_flashdev_ioctl_erase(
   new_offset = erase_args_1->offset;
-  status = rtems_flashdev_get_abs_addr(flash, iop, erase_args_1->size, &new_offset);
+  status = rtems_flashdev_get_abs_addr( flash,
+                                        iop,
+                                        erase_args_1->size,
+                                        &new_offset);
   if ( status < 0 ) {
     return status;
@@ -986,7 +998,10 @@ static int rtems_flashdev_ioctl_create_partition(
   /* New partition to allocate and space to allocate partition */
-  return rtems_flashdev_create_partition( iop, table, partition_idx, partition_in );
+  return rtems_flashdev_create_partition( iop,
+                                          table,
+                                          partition_idx,
+                                          partition_in );
 static int rtems_flashdev_ioctl_delete_partition(
@@ -1039,7 +1054,10 @@ static int rtems_flashdev_ioctl_resize_partition(
     else
-      ret = rtems_flashdev_create_partition( iop, flash->partition_table, partition_idx, &storage);
+      ret = rtems_flashdev_create_partition( iop,
+                                             flash->partition_table,
+                                             partition_idx,
+                                             &storage );
       if (ret >= 0)
         rtems_flashdev_activate_partition(iop, partition_idx);
@@ -1139,7 +1157,8 @@ static int rtems_flashdev_ioctl_get_pageinfo_by_index( rtems_flashdev *flash,
-static int rtems_flashdev_ioctl_get_page_count( rtems_flashdev *flash, void *arg )
+static int rtems_flashdev_ioctl_get_page_count( rtems_flashdev *flash,
+                                              void *arg )
   if ( arg == NULL ) {
     rtems_set_errno_and_return_minus_one( EINVAL );
diff --git a/cpukit/include/dev/flash/flashdev.h b/cpukit/include/dev/flash/flashdev.h
index d1ffd30583..7d7a70f5bc 100644
--- a/cpukit/include/dev/flash/flashdev.h
+++ b/cpukit/include/dev/flash/flashdev.h
@@ -165,7 +165,8 @@ typedef enum {
   RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET,
-   * @brief Get the size and address of nth flash page where n is index passed in.
+   * @brief Get the size and address of nth flash page where n is index
+   * passed in.
    * The index ignores the region limiting.
diff --git a/cpukit/libmisc/shell/main_flashdev.c b/cpukit/libmisc/shell/main_flashdev.c
index 2b703a88ec..e2e6bc02b2 100644
--- a/cpukit/libmisc/shell/main_flashdev.c
+++ b/cpukit/libmisc/shell/main_flashdev.c
@@ -37,8 +37,14 @@ static int flashdev_shell_write(char *dev_path, int argc, char *argv[]);
 static int flashdev_shell_erase(char *dev_path, int argc, char *argv[]);
 static int flashdev_shell_get_type(char *dev_path);
 static int flashdev_shell_get_jedec_id(char *dev_path);
-static int flashdev_shell_get_page_by_off(char *dev_path, int argc, char *argv[]);
-static int flashdev_shell_get_page_by_idx(char *dev_path, int argc, char *argv[]);
+static int flashdev_shell_get_page_by_off(char *dev_path,
+  int argc,
+  char *argv[]
+static int flashdev_shell_get_page_by_idx(char *dev_path,
+  int argc,
+  char *argv[]
 static int flashdev_shell_get_pg_count(char *dev_path);
 static int flashdev_shell_get_min_write_size(char *dev_path);
 static int flashdev_shell_get_erase_size(char *dev_path);
diff --git a/testsuites/libtests/flashdev01/init.c b/testsuites/libtests/flashdev01/init.c
index 33cbb8bad8..7005ef272e 100644
--- a/testsuites/libtests/flashdev01/init.c
+++ b/testsuites/libtests/flashdev01/init.c
@@ -73,7 +73,10 @@ static void run_test(void) {
   for ( int loop = 0; loop <= 2; loop++)
     /* Initalize the flash device driver and flashdev */
-    flash = test_flashdev_init(page_size_in, page_count_in, min_write_size_in[loop], ERASE_SIZE);
+    flash = test_flashdev_init( page_size_in,
+                                page_count_in,
+                                min_write_size_in[loop],
+                                ERASE_SIZE);
     rtems_test_assert(flash != NULL);
     /* Register the flashdev as a device */
@@ -172,9 +175,12 @@ static void run_test(void) {
     rtems_test_assert(page_count == PAGE_COUNT);
     /* Test getting min write size */
-    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_SIZE, &min_write_size_out);
+    status = ioctl( fd, RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_SIZE,
+                    &min_write_size_out);
     rtems_test_assert(!status);
-    rtems_test_assert(0 == memcmp(&min_write_size_out, &min_write_size_in[loop] , sizeof(size_t)));
+    rtems_test_assert(0 == memcmp(&min_write_size_out,
+                                  &min_write_size_in[loop],
+                                  sizeof(size_t)));
     /* Close the file handle */
     status = fclose(file);
@@ -188,7 +194,10 @@ static void run_test(void) {
-  flash = test_flashdev_init(page_size_in, page_count_in, min_write_size_in[1], ERASE_SIZE);
+                              page_count_in,
+                              min_write_size_in[1],
+                              ERASE_SIZE);
diff --git a/testsuites/libtests/flashdev01/test_flashdev.h b/testsuites/libtests/flashdev01/test_flashdev.h
index b02a5deed1..2867b8c993 100644
--- a/testsuites/libtests/flashdev01/test_flashdev.h
+++ b/testsuites/libtests/flashdev01/test_flashdev.h
@@ -31,7 +31,12 @@
 #include <dev/flash/flashdev.h>
-rtems_flashdev* test_flashdev_init(size_t page_size, size_t page_count, size_t min_write_size, size_t erase_size);
+rtems_flashdev* test_flashdev_init(
+  size_t page_size,
+  size_t page_count,
+  size_t min_write_size,
+  size_t erase_size
 void test_flashdev_deinit(rtems_flashdev* flash);
2.34.1
