[PATCH rtems-lwip - v1 03/11] Clean up: remove non-existent include paths
Kinsey Moore kinsey.moore at oarcorp.com
Thu Jan 4 21:34:36 UTC 2024
This patch looks good.
Kinsey
On Thu, Jan 4, 2024 at 12:55 PM <berndmoessner80 at gmail.com> wrote:
> From: Bernd Moessner <berndmoessner80 at gmail.com>
>  defs/bsps/aarch64/xilinx_zynqmp_base.json | 2 --
>  1 file changed, 2 deletions(-)
> diff --git a/defs/bsps/aarch64/xilinx_zynqmp_base.json
> b/defs/bsps/aarch64/xilinx_zynqmp_base.json
> index c18b339..3e47434 100644
> --- a/defs/bsps/aarch64/xilinx_zynqmp_base.json
> +++ b/defs/bsps/aarch64/xilinx_zynqmp_base.json
> @@ -2,13 +2,11 @@
>         "header-paths-to-import": [
> "embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include",
>                 "embeddedsw/lib/bsp/standalone/src/common",
> -               "embeddedsw/XilinxProcessorIPLib/drivers/common/src/",
>                 "embeddedsw/XilinxProcessorIPLib/drivers/scugic/src",
>                 "embeddedsw/XilinxProcessorIPLib/drivers/emacps/src",
>                 "rtemslwip/xilinx",
>                 "rtemslwip/zynqmp",
>                 "embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit",
> -               "embeddedsw/lib/bsp/standalone/src/arm/common/gcc",
>                 "embeddedsw/lib/bsp/standalone/src/arm/common"
>         "source-files-to-import": [
> 2.34.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240104/a75a0bc0/attachment-0001.htm>
