[PATCH rtems-lwip - v1 06/11] FIX: printf format spec compiler warning due to uintptr having 64bits on 64bit machines
Kinsey Moore kinsey.moore at oarcorp.com
Thu Jan 4 22:22:29 UTC 2024
Comments inline.
On Thu, Jan 4, 2024 at 12:54 PM <berndmoessner80 at gmail.com> wrote:
> From: Bernd Moessner <berndmoessner80 at gmail.com>
>  .../lwip211/src/contrib/ports/xilinx/netif/xadapter.c          | 3 ++-
>  1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git
> a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xadapter.c
> b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xadapter.c
> index 9594ff5..98e7a8e 100644
> @@ -184,8 +184,9 @@ xemac_add(struct netif *netif,
>  #endif
>  #endif
>                         default:
> -                               xil_printf("unable to determine type of
> EMAC with baseaddress 0x%08x\r\n",
> +                               xil_printf("unable to determine type of
> EMAC with baseaddress %" PRIXPTR,
>                                                 mac_baseaddr);
> +                               xil_printf("\r\b");
The second line has a \b instead of a \n.
Beyond that typo, changes in third-party sources in rtems-lwIP are treated
just like they are in rtems-libbsd. Changes are additive only and gated by
__rtems__. So if you wanted to change line A to line B, you'd have this
construct:
#ifdef __rtems__
line B
#else
line A
#endif
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240104/1367e4f1/attachment.htm>
