[PATCH rtems-lwip - v1 02/11] FIX: add library search path to allow lwip being installed aside the RTEMS installation
Kinsey Moore kinsey.moore at oarcorp.com
Thu Jan 4 22:26:56 UTC 2024
On Thu, Jan 4, 2024 at 4:03 PM Bernd Moessner <berndmoessner80 at gmail.com>
wrote:
> On 04.01.2024 22:33, Kinsey Moore wrote:
> > This looks like it should be fine for now to enable installing into
> > somewhere that isn't the installed BSP directory. Longer term,
> > rtems-lwip should probably support similar options to rtems-libbsd
> > such that the RTEMS path can be passed on the configure line using
> > --rtems=<PATH>.
> > Kinsey
> > On Thu, Jan 4, 2024 at 12:55 PM <berndmoessner80 at gmail.com> wrote:
> >     From: Bernd Moessner <berndmoessner80 at gmail.com>
> >      lwip.py | 7 ++++---
> >      1 file changed, 4 insertions(+), 3 deletions(-)
> >     diff --git a/lwip.py b/lwip.py
> >     index bd743a1..65f1ead 100644
> >     --- a/lwip.py
> >     +++ b/lwip.py
> >     @@ -137,9 +137,10 @@ def build(bld):
> >                      includes=' '.join(test_app_incl))
> >          lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
> >     -    bld.read_stlib('telnetd', paths=[lib_path])
> >     -    bld.read_stlib('rtemstest', paths=[lib_path])
> >     -    bld.read_stlib('ftpd', paths=[lib_path])
> >     +    rtems_lib_path = os.path.join(bld.env.RTEMS_PATH, arch_lib_path)
> >     +    bld.read_stlib('telnetd', paths=[lib_path, rtems_lib_path])
> >     +    bld.read_stlib('rtemstest', paths=[lib_path, rtems_lib_path])
> >     +    bld.read_stlib('ftpd', paths=[lib_path, rtems_lib_path])
> >          bld.program(features='c',
> >                      target='telnetd01.exe',
> >     2.34.1
> >     _______________________________________________
> >     devel mailing list
> >     devel at rtems.org
> >     http://lists.rtems.org/mailman/listinfo/devel
> Hmm --rtems=<PATH> works on my side now. I use
> ./waf configure --prefix=${RTEMS_LWIP_INSTALL_DIR}
> --rtems=${RTEMS_OS_INSTALL_DIR}
> --rtems-tools=${RTEMS_TOOLCHAIN_INSTALL_DIR}
> --rtems-bsps=${RTEMS_BSP_ARCH}/${RTEMS_BSP_NAME}
> to build the project.
Ah, sounds like this patch can be dropped, then. Being able to set the
RTEMS path is part of the generic rtems_waf functionality.
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240104/bfe95784/attachment.htm>
