[PATCH rtems-lwip - v1 02/11] FIX: add library search path to allow lwip being installed aside the RTEMS installation
Kinsey Moore kinsey.moore at oarcorp.com
Thu Jan 4 22:54:55 UTC 2024
On Thu, Jan 4, 2024 at 4:40 PM Bernd Moessner <berndmoessner80 at gmail.com>
wrote:
> On 04.01.2024 23:26, Kinsey Moore wrote:
> On Thu, Jan 4, 2024 at 4:03 PM Bernd Moessner <berndmoessner80 at gmail.com>
> wrote:
>> On 04.01.2024 22:33, Kinsey Moore wrote:
>> > This looks like it should be fine for now to enable installing into
>> > somewhere that isn't the installed BSP directory. Longer term,
>> > rtems-lwip should probably support similar options to rtems-libbsd
>> > such that the RTEMS path can be passed on the configure line using
>> > --rtems=<PATH>.
>> > Kinsey
>> > On Thu, Jan 4, 2024 at 12:55 PM <berndmoessner80 at gmail.com> wrote:
>> >     From: Bernd Moessner <berndmoessner80 at gmail.com>
>> >      lwip.py | 7 ++++---
>> >      1 file changed, 4 insertions(+), 3 deletions(-)
>> >     diff --git a/lwip.py b/lwip.py
>> >     index bd743a1..65f1ead 100644
>> >     --- a/lwip.py
>> >     +++ b/lwip.py
>> >     @@ -137,9 +137,10 @@ def build(bld):
>> >                      includes=' '.join(test_app_incl))
>> >          lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
>> >     -    bld.read_stlib('telnetd', paths=[lib_path])
>> >     -    bld.read_stlib('rtemstest', paths=[lib_path])
>> >     -    bld.read_stlib('ftpd', paths=[lib_path])
>> >     +    rtems_lib_path = os.path.join(bld.env.RTEMS_PATH,
>> arch_lib_path)
>> >     +    bld.read_stlib('telnetd', paths=[lib_path, rtems_lib_path])
>> >     +    bld.read_stlib('rtemstest', paths=[lib_path, rtems_lib_path])
>> >     +    bld.read_stlib('ftpd', paths=[lib_path, rtems_lib_path])
>> >          bld.program(features='c',
>> >                      target='telnetd01.exe',
>> >     2.34.1
>> >     _______________________________________________
>> >     devel mailing list
>> >     devel at rtems.org
>> >     http://lists.rtems.org/mailman/listinfo/devel
>> Hmm --rtems=<PATH> works on my side now. I use
>> ./waf configure --prefix=${RTEMS_LWIP_INSTALL_DIR}
>> --rtems=${RTEMS_OS_INSTALL_DIR}
>> --rtems-tools=${RTEMS_TOOLCHAIN_INSTALL_DIR}
>> --rtems-bsps=${RTEMS_BSP_ARCH}/${RTEMS_BSP_NAME}
>> to build the project.
> Ah, sounds like this patch can be dropped, then. Being able to set the
> RTEMS path is part of the generic rtems_waf functionality.
> Kinsey
> The RTEMS_PATH was set up, but without the patch stated above it wasnt
> showing on the linker comand line as library search dir. You are absolutely
> right that my patch is only a temporary solution. I think we should not
> have to set up the RTEMS_PATH in the way shown above for every executable.
> I have simply to less knowledge of waf and scripts around to provide a
> better and more general solution. I just wanted to let you know that the
> configure line is okay - the "real fix" must be somewhere deeper down.
Ok, sorry. I misunderstood. The patch is fine to go in.
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240104/863cc5b3/attachment-0001.htm>
