[PATCH rtems6 - v2 15/16] flashdev: Refactor IOCTL defines into enum
berndmoessner80 at gmail.com berndmoessner80 at gmail.com
Sun Jan 7 18:18:49 UTC 2024
From: Bernd Moessner <berndmoessner80 at gmail.com>
Updates #4981
 cpukit/include/dev/flash/flashdev.h | 24 +++++++++++++-----------
 1 file changed, 13 insertions(+), 11 deletions(-)
diff --git a/cpukit/include/dev/flash/flashdev.h b/cpukit/include/dev/flash/flashdev.h
index ac21f883e8..d59f5e92e5 100644
--- a/cpukit/include/dev/flash/flashdev.h
+++ b/cpukit/include/dev/flash/flashdev.h
@@ -58,18 +58,19 @@ typedef struct rtems_flashdev rtems_flashdev;
 /* IOCTL Calls */
+typedef enum {
  * @brief Obtains the flash device.
  * This command has no argument.
-#define RTEMS_FLASHDEV_IOCTL_OBTAIN 0
+RTEMS_FLASHDEV_IOCTL_OBTAIN,
  * @brief Releases the flash device.
-#define RTEMS_FLASHDEV_IOCTL_RELEASE 1
+RTEMS_FLASHDEV_IOCTL_RELEASE,
  * @brief Returns the JEDEC ID of the flash device. This IOCTL call
  * is informational only.
@@ -77,14 +78,14 @@ typedef struct rtems_flashdev rtems_flashdev;
  * @param[out] jedec_id Pointer to uint32_t in which the JEDEC ID is
  * returned in.
-#define RTEMS_FLASHDEV_IOCTL_GET_JEDEC_ID 2
+RTEMS_FLASHDEV_IOCTL_GET_JEDEC_ID,
  * @brief Erases flash device.
  * @param[in] erase_args Pointer to rtems_flashdev_region struct
  * containing offset and size of erase to be performed.
-#define RTEMS_FLASHDEV_IOCTL_ERASE 3
+RTEMS_FLASHDEV_IOCTL_ERASE,
  * @brief Set a region that limits read, write and erase calls to within it.
  * Regions are file descriptor specific and limited to a single region per
@@ -94,20 +95,20 @@ typedef struct rtems_flashdev rtems_flashdev;
  * @param[in] region Pointer to rtems_flashdev_region struct containing
  * base and length of defined region.
-#define RTEMS_FLASHDEV_IOCTL_SET_REGION 4
+RTEMS_FLASHDEV_IOCTL_SET_REGION,
  * @brief Removes the set region on the file descriptor.
-#define RTEMS_FLASHDEV_IOCTL_UNSET_REGION 5
+RTEMS_FLASHDEV_IOCTL_UNSET_REGION,
  * @brief Returns the type of flash device (e.g. NOR or NAND).
  * @param[out] flash_type Pointer to integer which is set to the flash
  * type macro value.
-#define RTEMS_FLASHDEV_IOCTL_GET_TYPE 6
+RTEMS_FLASHDEV_IOCTL_GET_TYPE,
  * @brief Get the size and address of flash page at given offset
@@ -118,7 +119,7 @@ typedef struct rtems_flashdev rtems_flashdev;
  * @param[in,out] rtems_flashdev_ioctl_page_info arg Pointer to struct
  * with offset and space for return values.
-#define RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET 7
+RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET,
  * @brief Get the size and address of nth flash page where n is index passed in.
@@ -128,21 +129,22 @@ typedef struct rtems_flashdev rtems_flashdev;
  * with index and space for return values.
-#define RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX 8
+RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX,
  * @brief Get the number of pages in flash device.
  * @param[out] count Integer containing the number of pages.
-#define RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT 9
+RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT,
  * @brief Get the minimum write block size supported by the driver.
  * @param[out] count Integer containing the minimum write block size.
-#define RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_BLOCK_SIZE 10
+RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_BLOCK_SIZE,
+} rtems_flashdev_ioctl_token;
  * @brief The maximum number of region limited file descriptors
2.34.1
