[PATCH 1/8] tmcontext01: Prevent optimizations
Tue Jan 9 09:36:50 UTC 2024
The previous method to prevent optimizations no longer worked at least
with GCC 13.  Disable intra-procedural optimizations.
 testsuites/tmtests/tmcontext01/init.c | 15 +++------------
 1 file changed, 3 insertions(+), 12 deletions(-)
diff --git a/testsuites/tmtests/tmcontext01/init.c b/testsuites/tmtests/tmcontext01/init.c
index 1cba67bb3f..5aea18e5f1 100644
--- a/testsuites/tmtests/tmcontext01/init.c
+++ b/testsuites/tmtests/tmcontext01/init.c
@@ -49,8 +49,6 @@ const char rtems_test_name[] = "TMCONTEXT 1";
 static rtems_counter_ticks t[SAMPLES];
-static volatile int prevent_optimization;
 static size_t cache_line_size;
 static size_t data_size;
@@ -72,17 +70,13 @@ static int dirty_data_cache(volatile int *data, size_t n, size_t clsz, int j)
   return i + j;
-static int call_at_level(
+static __attribute__((__noipa__)) void call_at_level(
   int start,
   int fl,
   int s,
   bool dirty
-  int prevent_optimization;
-  prevent_optimization = start + fl;
   if (fl == start) {
      * Some architectures like the SPARC have register windows.  A side-effect
@@ -99,6 +93,7 @@ static int call_at_level(
       s,
       dirty
+    __asm__ volatile ("" : : : "memory");
   } else {
     char *volatile space;
     rtems_counter_ticks a;
@@ -120,8 +115,6 @@ static int call_at_level(
     b = rtems_counter_read();
     t[s] = rtems_counter_difference(b, a);
-  return prevent_optimization;
 static void load_task(rtems_task_argument arg)
@@ -149,7 +142,7 @@ static void sort_t(void)
   qsort(&t[0], SAMPLES, sizeof(t[0]), cmp);
-static void test_by_function_level(int fl, bool dirty)
+static __attribute__((__noipa__)) void test_by_function_level(int fl, bool dirty)
   RTEMS_INTERRUPT_LOCK_DECLARE(, lock)
   rtems_interrupt_lock_context lock_context;
@@ -160,8 +153,6 @@ static void test_by_function_level(int fl, bool dirty)
   uint64_t q3;
   uint64_t max;
-  fl += prevent_optimization;
   rtems_interrupt_lock_initialize(&lock, "test");
   rtems_interrupt_lock_acquire(&lock, &lock_context);
2.35.3
