Pause on console in libmisc/shell detecting terminal size (mvme5500, beatnik)
Fri Jan 12 01:52:55 UTC 2024
On 12/1/2024 12:59 am, Peter Dufault wrote:
>> On Jan 10, 2024, at 7:05 PM, Chris Johns <chrisj at rtems.org> wrote:
>>> I changed the code to use VTIME of 1 (1/10 second, or 100 msec) instead of 0.   That lets TERMIOS do the character arrival timeout instead of using a delay in a loop that resets - essentially duplicating VTIME != 0 VMIN == 0.  Once I did that it times out as I expect in .1 seconds.
>> Thanks for investigating this and finding a solution. Are you able to post a patch?
>>> I don't know WHY no characters arrive but I know why it has a long delay.
>> The 150msec timeout is needed when accessing remote devices on the other side of
>> the world but it should be 1/10 of a second and then the shall moves on. The
>> process is only done when the command prompt is painted so it should not
>> normally be noticeable.
> I can post a patch.  Do I need to open a bug first?
No but maybe an "Update #???" referencing the original ticket?
> Only downside is VTIME needs to be multiples of .1 seconds, so it will be .1 or .2.
.1 should be fine. The original was 50msec and that was not fast enough in some
cases.
> The VTIME and VMIN is a good interface *except* that the VTIME>0 VMIN>0 case initial timeout is infinity.  I don't like that, though I suppose an alarm and EINTR would let me do what I wish they had defined.
Sure, happy to see this area get improved.
