[PATCH 2/4] dev/io: Add base64 decoder
Mon Jan 15 09:46:00 UTC 2024
From: Matthew Joyce <matthew.joyce at embedded-brains.de>
 cpukit/dev/iobase64decode.c                   | 166 ++++++++++++++++
 cpukit/include/rtems/dev/io.h                 |  63 ++++++
 spec/build/cpukit/librtemscpu.yml             |   1 +
 .../build/testsuites/unit/unit-no-clock-0.yml |   1 +
 testsuites/unit/tc-io-base64-decode.c         | 180 ++++++++++++++++++
 5 files changed, 411 insertions(+)
 create mode 100644 cpukit/dev/iobase64decode.c
 create mode 100644 testsuites/unit/tc-io-base64-decode.c
diff --git a/cpukit/dev/iobase64decode.c b/cpukit/dev/iobase64decode.c
new file mode 100644
index 0000000000..5d3fe1c3cb
--- /dev/null
+++ b/cpukit/dev/iobase64decode.c
@@ -0,0 +1,166 @@
+ * @file
+ * @ingroup RTEMSDeviceIO
+ * @brief This source file contains the implementation of
+ *   _IO_Base64_decode_initialize() and _IO_Base64_decode().
+ * Copyright (C) 2023 embedded brains GmbH & Co. KG
+ * are met:
+#include <rtems/dev/io.h>
+#define SPACE 253
+#define PAD 254
+#define INVALID 255
+const uint8_t _IO_Base64_decode_table[128] = {
+    ['A'] = 0,       ['B'] = 1,       ['C'] = 2,       ['D'] = 3,
+    ['E'] = 4,       ['F'] = 5,       ['G'] = 6,       ['H'] = 7,
+    ['I'] = 8,       ['J'] = 9,       ['K'] = 10,      ['L'] = 11,
+    ['M'] = 12,      ['N'] = 13,      ['O'] = 14,      ['P'] = 15,
+    ['Q'] = 16,      ['R'] = 17,      ['S'] = 18,      ['T'] = 19,
+    ['U'] = 20,      ['V'] = 21,      ['W'] = 22,      ['X'] = 23,
+    ['Y'] = 24,      ['Z'] = 25,      ['a'] = 26,      ['b'] = 27,
+    ['c'] = 28,      ['d'] = 29,      ['e'] = 30,      ['f'] = 31,
+    ['g'] = 32,      ['h'] = 33,      ['i'] = 34,      ['j'] = 35,
+    ['k'] = 36,      ['l'] = 37,      ['m'] = 38,      ['n'] = 39,
+    ['o'] = 40,      ['p'] = 41,      ['q'] = 42,      ['r'] = 43,
+    ['s'] = 44,      ['t'] = 45,      ['u'] = 46,      ['v'] = 47,
+    ['w'] = 48,      ['x'] = 49,      ['y'] = 50,      ['z'] = 51,
+    ['0'] = 52,      ['1'] = 53,      ['2'] = 54,      ['3'] = 55,
+    ['4'] = 56,      ['5'] = 57,      ['6'] = 58,      ['7'] = 59,
+    ['8'] = 60,      ['9'] = 61,      ['+'] = 62,      ['-'] = 62,
+    ['/'] = 63,      ['_'] = 63,      ['='] = PAD,     [' '] = SPACE,
+    ['\t'] = SPACE,  ['\n'] = SPACE,  ['\v'] = SPACE,  ['\f'] = SPACE,
+    ['\r'] = SPACE,  [0] = INVALID,   [1] = INVALID,   [2] = INVALID,
+    [3] = INVALID,   [4] = INVALID,   [5] = INVALID,   [6] = INVALID,
+    [7] = INVALID,   [8] = INVALID,   [14] = INVALID,  [15] = INVALID,
+    [16] = INVALID,  [17] = INVALID,  [18] = INVALID,  [19] = INVALID,
+    [20] = INVALID,  [21] = INVALID,  [22] = INVALID,  [23] = INVALID,
+    [24] = INVALID,  [25] = INVALID,  [26] = INVALID,  [27] = INVALID,
+    [28] = INVALID,  [29] = INVALID,  [30] = INVALID,  [31] = INVALID,
+    [33] = INVALID,  [34] = INVALID,  [35] = INVALID,  [36] = INVALID,
+    [37] = INVALID,  [38] = INVALID,  [39] = INVALID,  [40] = INVALID,
+    [41] = INVALID,  [42] = INVALID,  [44] = INVALID,  [46] = INVALID,
+    [58] = INVALID,  [59] = INVALID,  [60] = INVALID,  [62] = INVALID,
+    [63] = INVALID,  [64] = INVALID,  [91] = INVALID,  [92] = INVALID,
+    [93] = INVALID,  [94] = INVALID,  [96] = INVALID,  [123] = INVALID,
+    [124] = INVALID, [125] = INVALID, [126] = INVALID, [127] = INVALID};
+void _IO_Base64_decode_initialize(IO_Base64_decode_control* self,
+                                  uint8_t* target,
+                                  size_t target_size) {
+  self->state = IO_BASE64_DECODE_STATE_0;
+  self->target = target;
+  self->target_end = target + target_size;
+IO_Base64_decode_status _IO_Base64_decode(IO_Base64_decode_control* self,
+                                          char ch) {
+  uint8_t decoded_ch;
+  uint8_t next_ch;
+  uint8_t* target;
+  const uint8_t* target_end;
+  IO_Base64_decode_state next_state;
+  if ((unsigned char)ch >= 128) {
+    return IO_BASE64_DECODE_INVALID_INPUT;
+  decoded_ch = _IO_Base64_decode_table[(unsigned char)ch];
+  if (decoded_ch == SPACE) {
+    return IO_BASE64_DECODE_SUCCESS;
+  target = self->target;
+  if (decoded_ch == PAD) {
+    self->target_end = target;
+  if (decoded_ch == INVALID) {
+  target_end = self->target_end;
+  if (target == target_end) {
+    return IO_BASE64_DECODE_OVERFLOW;
+  switch (self->state) {
+    case IO_BASE64_DECODE_STATE_0:
+      *target = decoded_ch << 2;
+      next_state = IO_BASE64_DECODE_STATE_1;
+      break;
+    case IO_BASE64_DECODE_STATE_1:
+      *target |= decoded_ch >> 4;
+      next_ch = (decoded_ch & 0x0fU) << 4;
+      ++target;
+      if (target != target_end) {
+        *target = next_ch;
+      } else if (next_ch != 0) {
+      next_state = IO_BASE64_DECODE_STATE_2;
+      break;
+    case IO_BASE64_DECODE_STATE_2:
+      *target |= decoded_ch >> 2;
+      next_ch = (decoded_ch & 0x03U) << 6;
+      ++target;
+      next_state = IO_BASE64_DECODE_STATE_3;
+      break;
+    default: /* IO_BASE64_DECODE_STATE_3 */
+      *target |= decoded_ch;
+      ++target;
+      next_state = IO_BASE64_DECODE_STATE_0;
+      break;
+  self->state = next_state;
diff --git a/cpukit/include/rtems/dev/io.h b/cpukit/include/rtems/dev/io.h
index efe0a32d0a..9b724e5df8 100644
--- a/cpukit/include/rtems/dev/io.h
+++ b/cpukit/include/rtems/dev/io.h
@@ -178,6 +178,69 @@ int _IO_Base64url(
   int          wordlen
+ * @brief Represents the base64 decoder state.
+typedef enum {
+  IO_BASE64_DECODE_STATE_0,
+  IO_BASE64_DECODE_STATE_1,
+  IO_BASE64_DECODE_STATE_2,
+  IO_BASE64_DECODE_STATE_3
+} IO_Base64_decode_state;
+ * @brief Contains the base64 decoder control.
+typedef struct {
+  IO_Base64_decode_state state;
+  uint8_t *target;
+  const uint8_t *target_end;
+} IO_Base64_decode_control;
+ * @brief Maps a 7-bit character to the 6-bit integer as defined by the base64
+ *   or base64url encoding or a special value.
+extern const uint8_t _IO_Base64_decode_table[ 128 ];
+ * @brief Initializes the base64 decoder.
+ * @param[out] self is the base64 decoder control to initialize.
+ * @param[out] target is the base address of the target area for decoding.
+ * @param target_size is the size in bytes of the target area for decoding.
+  IO_Base64_decode_control *self,
+  uint8_t                  *target,
+ * @brief Represents the base64 decoder status.
+typedef enum {
+  IO_BASE64_DECODE_SUCCESS,
+  IO_BASE64_DECODE_OVERFLOW,
+  IO_BASE64_DECODE_INVALID_INPUT
+} IO_Base64_decode_status;
+ * @brief Decodes the character.
+ * The decoder accepts base64 and base64url encodings.  White space is ignored.
+ * @param[in, out] self is the base64 decoder control.
+ * @param ch is the character to decode.
+  char                      ch
  * @brief Issues a couple of no-operation instructions.
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 9202c31715..56e5243673 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -540,6 +540,7 @@ source:
 - cpukit/dev/i2c/ti-tmp112.c
 - cpukit/dev/i2c/xilinx-axi-i2c.c
 - cpukit/dev/iobase64.c
+- cpukit/dev/iobase64decode.c
 - cpukit/dev/ioprintf.c
 - cpukit/dev/iorelax.c
 - cpukit/dev/iovprintf.c
diff --git a/spec/build/testsuites/unit/unit-no-clock-0.yml b/spec/build/testsuites/unit/unit-no-clock-0.yml
index 5d15bf52b7..be5cafe990 100644
--- a/spec/build/testsuites/unit/unit-no-clock-0.yml
+++ b/spec/build/testsuites/unit/unit-no-clock-0.yml
@@ -13,6 +13,7 @@ links: []
 source:
 - testsuites/unit/tc-compiler-builtins.c
 - testsuites/unit/tc-config.c
+- testsuites/unit/tc-io-base64-decode.c
 - testsuites/unit/tc-misaligned-builtin-memcpy.c
 - testsuites/unit/tc-score-msgq.c
 - testsuites/unit/tc-score-rbtree.c
diff --git a/testsuites/unit/tc-io-base64-decode.c b/testsuites/unit/tc-io-base64-decode.c
index 0000000000..b09390960f
--- /dev/null
+++ b/testsuites/unit/tc-io-base64-decode.c
@@ -0,0 +1,180 @@
+ * are met:
+#include <rtems/test.h>
+typedef struct {
+  IO_Base64_decode_control base;
+  uint8_t buf[64];
+} test_control;
+static int test_run(test_control* self, const char* payload) {
+  size_t len = strlen(payload);
+  for (size_t i = 0; i < len; ++i) {
+    int rv = _IO_Base64_decode(&self->base, payload[i]);
+    if (rv != 0) {
+      return rv;
+  return 0;
+static int test_payload(test_control* self, const char* payload) {
+  memset(self->buf, 0xff, sizeof(self->buf));
+  _IO_Base64_decode_initialize(&self->base, &self->buf[0], sizeof(self->buf));
+  return test_run(self, payload);
+T_TEST_CASE(IOBase64Decode) {
+  int rv;
+  test_control instance;
+  test_control* self = &instance;
+  rv = test_payload(self, "POOL");
+  T_eq_int(rv, IO_BASE64_DECODE_SUCCESS);
+  T_eq_int(self->base.state, IO_BASE64_DECODE_STATE_0);
+  T_eq_ptr(self->base.target, &self->buf[3]);
+  const uint8_t expected1[] = {0x3c, 0xe3, 0x8b, 0xff};
+  T_eq_mem(&self->buf[0], expected1, sizeof(expected1));
+  rv = test_payload(self, "ABCDEFGH");
+  T_eq_ptr(self->base.target, &self->buf[6]);
+  const uint8_t expected2[] = {0x00, 0x10, 0x83, 0x10, 0x51, 0x87, 0xff};
+  T_eq_mem(&self->buf[0], expected2, sizeof(expected2));
+  /* Non-base64 character results in an error */
+  rv = test_payload(self, "PO*OL");
+  T_eq_int(rv, IO_BASE64_DECODE_INVALID_INPUT);
+  T_eq_int(self->base.state, IO_BASE64_DECODE_STATE_2);
+  T_eq_ptr(self->base.target, &self->buf[1]);
+  const uint8_t expected3[] = {0x3c};
+  T_eq_mem(&self->buf[0], expected3, sizeof(expected3));
+  /* Other non-base64 character results in an error */
+  rv = test_payload(self, "PO\x80OL");
+  /* Space characters should be ignored */
+  rv = test_payload(self, "P OOL");
+  const uint8_t expected4[] = {0x3c, 0xe3, 0x8b, 0xff};
+  T_eq_mem(&self->buf[0], expected4, sizeof(expected4));
+  /* Handle pad characters */
+  rv = test_payload(self, "POOL==");
+  T_eq_ptr(self->base.target, self->base.target_end);
+  const uint8_t expected5[] = {0x3c, 0xe3, 0x8b, 0xff};
+  T_eq_mem(&self->buf[0], expected5, sizeof(expected5));
+  /* If characters come after pad characters, an error results */
+  rv = test_payload(self, "POOL==xy");
+  T_eq_int(rv, IO_BASE64_DECODE_OVERFLOW);
+  T_eq_int(self->base.state, IO_BASE64_DECODE_SUCCESS);
+  const uint8_t expected6[] = {0x3c, 0xe3, 0x8b, 0xff};
+  T_eq_mem(&self->buf[0], expected6, sizeof(expected6));
+  rv = test_payload(self, "POOLPOOL");
+  const uint8_t expected7[] = {0x3c, 0xe3, 0x8b, 0x3c, 0xe3, 0x8b, 0xff};
+  T_eq_mem(&self->buf[0], expected7, sizeof(expected7));
+   * Test valid payload with series of target sizes. All target sizes
+   * less than three are invalid for the given payload and will result
+   * in an error.
+  const uint8_t expected9[] = {0x3c, 0xe3, 0x8b, 0xff};
+  for (size_t i = 0; i < 4; ++i) {
+    memset(&self->buf[0], 0xff, sizeof(self->buf));
+    _IO_Base64_decode_initialize(&self->base, &self->buf[0], i);
+    rv = test_run(self, "POOL");
+    if (i < 3) {
+      T_eq_int(self->base.state, i);
+      T_ne_ptr(self->base.target, &self->buf[3]);
+      T_ne_mem(&self->buf[0], expected9, sizeof(expected9));
+    } else {
+      T_eq_mem(&self->buf[0], expected9, sizeof(expected9));
+  /* No overflow in state 1 */
+  _IO_Base64_decode_initialize(&self->base, &self->buf[0], 1);
+  rv = test_run(self, "AA");
+  const uint8_t expected10[] = {0x00, 0xff};
+  T_eq_mem(&self->buf[0], expected10, sizeof(expected10));
+  /* No overflow in state 2 */
+  _IO_Base64_decode_initialize(&self->base, &self->buf[0], 2);
+  rv = test_run(self, "AAA");
+  T_eq_int(self->base.state, IO_BASE64_DECODE_STATE_3);
+  T_eq_ptr(self->base.target, &self->buf[2]);
+  const uint8_t expected11[] = {0x00, 0x00, 0xff};
+  T_eq_mem(&self->buf[0], expected11, sizeof(expected11));
+T_TEST_CASE(IOBase64DecodeInitialize) {
+  IO_Base64_decode_control instance;
+  IO_Base64_decode_control* self = &instance;
+  uint8_t buf[1];
+  memset(self, 0xff, sizeof(*self));
+  _IO_Base64_decode_initialize(self, buf, sizeof(buf));
+  T_eq_int(self->state, IO_BASE64_DECODE_STATE_0);
+  T_eq_ptr(self->target, &buf[0]);
+  T_eq_ptr(self->target_end, &buf[1]);
2.35.3
