[PATCH 1/5] grlib/l2c: Fix whitespace
Martin Åberg
maberg at gaisler.com
Tue Jan 16 14:06:26 UTC 2024
No functional change
bsps/shared/grlib/l2c/l2c.c | 168 ++++++++++++++++++------------------
1 file changed, 84 insertions(+), 84 deletions(-)
diff --git a/bsps/shared/grlib/l2c/l2c.c b/bsps/shared/grlib/l2c/l2c.c
index 17d96874ae..4be29c56a4 100644
--- a/bsps/shared/grlib/l2c/l2c.c
+++ b/bsps/shared/grlib/l2c/l2c.c
@@ -52,11 +52,11 @@
#ifdef DEBUG
#define DBG(x...) printf(x)
#else
-#define DBG(x...)
+#define DBG(x...)
#endif
- * L2CACHE CTRL register fields
+ * L2CACHE CTRL register fields
#define L2C_CTRL_EN (0x1 << L2C_CTRL_EN_BIT)
#define L2C_CTRL_EDAC (0x1 << L2C_CTRL_EDAC_BIT)
@@ -83,7 +83,7 @@
#define L2C_CTRL_HP_BIT 0
- * L2CACHE STATUS register fields
+ * L2CACHE STATUS register fields
#define L2C_STAT_LS (0x1 << L2C_STAT_LS_BIT)
#define L2C_STAT_AT (0x1 << L2C_STAT_AT_BIT)
@@ -102,7 +102,7 @@
#define L2C_STAT_WAY_BIT 0
- * L2CACHE MTRR register fields
+ * L2CACHE MTRR register fields
#define L2C_MTRR_ADDR (0x3fff << L2C_MTRR_ADDR_BIT)
#define L2C_MTRR_ACC (0x3 << L2C_MTRR_ACC_BIT)
@@ -127,7 +127,7 @@
#define REG_READ(addr) (*(volatile unsigned int *)(addr))
- * L2CACHE FLUSHMEM register fields
+ * L2CACHE FLUSHMEM register fields
#define L2C_FLUSH_ADDR (0x7ffffff << L2C_FLUSH_ADDR_BIT)
#define L2C_FLUSH_DI (0x1 << L2C_FLUSH_DI_BIT)
@@ -145,7 +145,7 @@
#define L2C_FLUSH_FMODE_INV_WB_ALL (0x7 << L2C_FLUSH_FMODE_BIT)
- * L2CACHE FLUSSETINDEX register fields
+ * L2CACHE FLUSSETINDEX register fields
#define L2C_FLUSHSI_INDEX (0xffff << L2C_FLUSHSI_INDEX_BIT)
#define L2C_FLUSHSI_TAG (0x3fffff << L2C_FLUSHSI_TAG_BIT)
@@ -175,7 +175,7 @@
#define L2C_FLUSHSI_FMODE_WAY_UPDATE_WB_ALL (0x3 << L2C_FLUSHSI_FMODE_BIT)
- * L2CACHE ERROR register fields
+ * L2CACHE ERROR register fields
#define L2C_ERROR_AHBM (0xf << L2C_ERROR_AHBM_BIT)
#define L2C_ERROR_SCRUB (0x1 << L2C_ERROR_SCRUB_BIT)
@@ -222,34 +222,34 @@
#define L2C_ERROR_RST_BIT 0
- * L2CACHE DATA CHECK BITS register fields
+ * L2CACHE DATA CHECK BITS register fields
#define L2C_DCB_CB (0xfffffff << L2C_DCB_CB_BIT)
-#define L2C_DCB_CB_BIT 0
+#define L2C_DCB_CB_BIT 0
- * L2CACHE SCRUB register fields
+ * L2CACHE SCRUB register fields
#define L2C_SCRUB_INDEX (0xffff << L2C_SCRUB_INDEX_BIT)
#define L2C_SCRUB_WAY (0x3 << L2C_SCRUB_WAY_BIT)
#define L2C_SCRUB_PEN (0x1 << L2C_SCRUB_PEN_BIT)
#define L2C_SCRUB_EN (0x1 << L2C_SCRUB_EN_BIT)
-#define L2C_SCRUB_INDEX_BIT 16
+#define L2C_SCRUB_INDEX_BIT 16
#define L2C_SCRUB_WAY_BIT 2
#define L2C_SCRUB_PEN_BIT 1
#define L2C_SCRUB_EN_BIT 0
- * L2CACHE SCRUBDELAY register fields
+ * L2CACHE SCRUBDELAY register fields
#define L2C_SCRUB_DEL (0xffff << L2C_SCRUB_DEL_BIT)
-#define L2C_SCRUB_DEL_BIT 0
+#define L2C_SCRUB_DEL_BIT 0
- * L2CACHE ERROR INJECT register fields
+ * L2CACHE ERROR INJECT register fields
#define L2C_ERRINJ_ADDR (0x3fffffff << L2C_ERRINJ_ADDR_BIT)
#define L2C_ERRINJ_EN (0x1 << L2C_ERRINJ_EN_BIT)
@@ -258,7 +258,7 @@
#define L2C_ERRINJ_EN_BIT 0
- * L2CACHE ACCESS CONTROL register fields
+ * L2CACHE ACCESS CONTROL register fields
#define L2C_ACCCTRL_DSC (0x1 << L2C_ACCCTRL_DSC_BIT)
#define L2C_ACCCTRL_SH (0x1 << L2C_ACCCTRL_SH_BIT)
@@ -286,7 +286,7 @@
#ifdef TEST_L2CACHE
- * L2CACHE TAG fields
+ * L2CACHE TAG fields
#define L2C_TAG_TAG (0xfffffc << L2C_TAG_TAG_BIT)
#define L2C_TAG_VALID (0x3 << L2C_TAG_VALID_BIT)
@@ -326,7 +326,7 @@ struct l2cache_priv {
- * L2CACHE internal prototypes
+ * L2CACHE internal prototypes
/* -Register access functions */
STATIC INLINE int l2cache_reg_ctrl_enable(void);
@@ -338,7 +338,7 @@ STATIC INLINE int l2cache_reg_ctrl_iway(int way);
STATIC INLINE int l2cache_reg_ctrl_writep(int policy);
STATIC INLINE unsigned int l2cache_reg_ctrl(void);
STATIC INLINE unsigned int l2cache_reg_status(void);
-STATIC INLINE int l2cache_reg_mtrr_set(int index, unsigned int addr,
+STATIC INLINE int l2cache_reg_mtrr_set(int index, unsigned int addr,
unsigned int mask, int options);
UNUSED STATIC INLINE unsigned int l2cache_reg_mtrr_get(int index);
STATIC INLINE int l2cache_reg_flushmem(unsigned int addr, int options);
@@ -378,7 +378,7 @@ int l2cache_init1(struct drvmgr_dev *dev);
void l2cache_isr(void *arg);
- * L2CACHE static members
+ * L2CACHE static members
static struct l2cache_priv *l2cachepriv = NULL;
#ifdef DEBUG
@@ -387,14 +387,14 @@ static char * repl_names[4] = {"LRU","Random","Master-Idx-1","Master-IDx-2"};
/* L2CACHE DRIVER */
-struct drvmgr_drv_ops l2cache_ops =
+struct drvmgr_drv_ops l2cache_ops =
.init = {l2cache_init1, NULL, NULL, NULL},
.remove = NULL,
.info = NULL
-struct amba_dev_id l2cache_ids[] =
+struct amba_dev_id l2cache_ids[] =
{VENDOR_GAISLER, GAISLER_L2CACHE},
{0, 0} /* Mark end of table */
@@ -442,7 +442,7 @@ STATIC int l2cache_init(struct l2cache_priv *priv)
/* Initialize L2CACHE status */
unsigned int status = l2cache_reg_status();
priv->ways = (status & L2C_STAT_WAY) + 1;
- priv->waysize =
+ priv->waysize =
((status & L2C_STAT_WAYSIZE) >> L2C_STAT_WAYSIZE_BIT) * 1024;
priv->linesize = ((status & L2C_STAT_LS)? 64 : 32);
priv->index = ((priv->waysize)/(priv->linesize));
@@ -464,7 +464,7 @@ STATIC int l2cache_init(struct l2cache_priv *priv)
}else{
l2cache_reg_accctrl_split_disable();
- priv->split_support =
+ priv->split_support =
((split_new ^ split_old) >> L2C_ACCCTRL_SPLIT_BIT) & 1;
DBG("L2CACHE driver initialized\n");
@@ -472,7 +472,7 @@ STATIC int l2cache_init(struct l2cache_priv *priv)
return 0;
-/* Called when a core is found with the AMBA device and vendor ID
+/* Called when a core is found with the AMBA device and vendor ID
* given in l2cache_ids[]. IRQ, Console does not work here
@@ -528,8 +528,8 @@ STATIC INLINE int l2cache_reg_ctrl_repl(int policy)
struct l2cache_priv *priv = l2cachepriv;
unsigned int ctrl = REG_READ(&priv->regs->control);
- REG_WRITE(&priv->regs->control,
- ((ctrl & ~(L2C_CTRL_REPL)) |
+ REG_WRITE(&priv->regs->control,
+ ((ctrl & ~(L2C_CTRL_REPL)) |
((policy << L2C_CTRL_REPL_BIT) & L2C_CTRL_REPL))
return 0;
@@ -540,8 +540,8 @@ STATIC INLINE int l2cache_reg_ctrl_iway(int way)
- ((ctrl & ~(L2C_CTRL_IWAY)) |
+ ((ctrl & ~(L2C_CTRL_IWAY)) |
((way << L2C_CTRL_IWAY_BIT) & L2C_CTRL_IWAY))
return 0;
@@ -552,7 +552,7 @@ STATIC INLINE int l2cache_reg_ctrl_writep(int policy)
((ctrl & ~(L2C_CTRL_WP)) | ((policy << L2C_CTRL_WP_BIT) & L2C_CTRL_WP))
return 0;
@@ -564,8 +564,8 @@ STATIC INLINE int l2cache_reg_ctrl_locked_set(int locked)
ctrl = (ctrl & ~(L2C_CTRL_LOCK));
- ctrl |
+ ctrl |
((locked << L2C_CTRL_LOCK_BIT) & L2C_CTRL_LOCK));
return 0;
@@ -575,8 +575,8 @@ STATIC INLINE int l2cache_reg_ctrl_edac_set(int edac)
- (ctrl & ~(L2C_CTRL_EDAC)) |
+ (ctrl & ~(L2C_CTRL_EDAC)) |
(edac? L2C_CTRL_EDAC:0));
return 0;
@@ -595,14 +595,14 @@ STATIC INLINE unsigned int l2cache_reg_status(void)
return REG_READ(&priv->regs->status);
/* Set mtrr */
addr = addr & L2C_MTRR_ADDR;
- mask = (mask >> 16) & L2C_MTRR_MASK;
+ mask = (mask >> 16) & L2C_MTRR_MASK;
options = ((options & ~(L2C_MTRR_ADDR)) & ~(L2C_MTRR_MASK));
unsigned int mtrr = 0 | addr | mask | options;
REG_WRITE(&priv->regs->mtrr[index], mtrr);
@@ -672,7 +672,7 @@ STATIC INLINE int l2cache_reg_error_irqmask(int mask)
unsigned int ctrl = REG_READ(&priv->regs->error_status_control);
- REG_WRITE(&priv->regs->error_status_control,
+ REG_WRITE(&priv->regs->error_status_control,
(ctrl & ~(L2C_ERROR_IRQM)) | (mask & L2C_ERROR_IRQM));
return 0;
@@ -700,7 +700,7 @@ STATIC INLINE int l2cache_reg_scrub_enable(int delay)
accc | L2C_ACCCTRL_DSC | L2C_ACCCTRL_SH);
unsigned int ctrl = REG_READ(&priv->regs->scrub_control_status);
- REG_WRITE(&priv->regs->scrub_delay,
+ REG_WRITE(&priv->regs->scrub_delay,
(delay << L2C_SCRUB_DEL_BIT) & L2C_SCRUB_DEL);
REG_WRITE(&priv->regs->scrub_control_status, ctrl | L2C_SCRUB_EN);
return 0;
@@ -719,7 +719,7 @@ STATIC INLINE int l2cache_reg_scrub_line(int way, int index)
- REG_WRITE(&priv->regs->scrub_control_status,
+ REG_WRITE(&priv->regs->scrub_control_status,
((index << L2C_SCRUB_INDEX_BIT) & L2C_SCRUB_INDEX) |
((way << L2C_SCRUB_WAY_BIT) & L2C_SCRUB_WAY) |
L2C_SCRUB_PEN);
@@ -779,7 +779,7 @@ STATIC INLINE int l2cache_reg_error_dcb(unsigned int cb)
- REG_WRITE(&priv->regs->data_check_bit, (cb & L2C_DCB_CB));
+ REG_WRITE(&priv->regs->data_check_bit, (cb & L2C_DCB_CB));
return 0;
@@ -787,8 +787,8 @@ STATIC INLINE int l2cache_reg_error_inject(unsigned int addr)
- REG_WRITE(&priv->regs->error_injection,
- (addr & L2C_ERRINJ_ADDR) | L2C_ERRINJ_EN);
+ REG_WRITE(&priv->regs->error_injection,
+ (addr & L2C_ERRINJ_ADDR) | L2C_ERRINJ_EN);
return 0;
@@ -862,7 +862,7 @@ int l2cache_lookup(uint32_t addr, int * way)
uint32_t exptag = l2cache_get_tag(addr);
int index = l2cache_get_index(addr);
- /* Check all tags in the set */
+ /* Check all tags in the set */
for(i=0; i< priv->ways; i++){
ret = l2cache_diag_tag(i, index, &gottag);
if (ret != L2CACHE_ERR_OK){
@@ -878,13 +878,13 @@ int l2cache_lookup(uint32_t addr, int * way)
if (way){
*way = i;
- DBG("L2CACHE lookup: index=%d, tag=0x%08x HIT way=%d.\n",
+ DBG("L2CACHE lookup: index=%d, tag=0x%08x HIT way=%d.\n",
index, (unsigned int) exptag, i);
return L2CACHE_HIT;
- DBG("L2CACHE lookup: index=%d, tag=0x%08x MISS.\n",
+ DBG("L2CACHE lookup: index=%d, tag=0x%08x MISS.\n",
index, (unsigned int) exptag);
/* MISS! */
return L2CACHE_MISS;
@@ -990,7 +990,7 @@ int l2cache_error_inject_address( uint32_t addr, uint32_t mask)
/* Inject error */
l2cache_reg_error_inject(addr);
- DBG("L2CACHE error injected in 0x%08x (0x%08x).\n",
+ DBG("L2CACHE error injected in 0x%08x (0x%08x).\n",
(unsigned int) addr, (unsigned int) mask);
return L2CACHE_ERR_OK;
@@ -1048,8 +1048,8 @@ int l2cache_disable(int flush)
return L2CACHE_ERR_NOINIT;
- if ((flush < 0) ||
- (flush >
+ if ((flush < 0) ||
+ (flush >
(L2CACHE_OPTIONS_FLUSH_INVALIDATE | L2CACHE_OPTIONS_FLUSH_WAIT))
DBG("L2CACHE wrong flush option.\n");
@@ -1137,8 +1137,8 @@ int l2cache_flush(int flush)
- (flush >
+ (flush >
@@ -1181,8 +1181,8 @@ int l2cache_flush_address(uint32_t addr, int size, int flush)
- (flush >
+ (flush >
@@ -1228,7 +1228,7 @@ int l2cache_flush_address(uint32_t addr, int size, int flush)
if (flush & L2CACHE_OPTIONS_FLUSH_WAIT){
l2cache_flushwait();
DBG("L2CACHE address range flushed\n");
@@ -1244,8 +1244,8 @@ int l2cache_flush_line(int way, int index, int flush)
- (flush >
+ (flush >
@@ -1266,7 +1266,7 @@ int l2cache_flush_line(int way, int index, int flush)
case L2CACHE_OPTIONS_FLUSH_NONE:
break;
case L2CACHE_OPTIONS_FLUSH_INV_WBACK:
- l2cache_reg_flushline(way, index,
+ l2cache_reg_flushline(way, index,
L2C_FLUSHSI_FMODE_SET_INV_WB_ONE);
break;
case L2CACHE_OPTIONS_FLUSH_WRITEBACK:
@@ -1297,8 +1297,8 @@ int l2cache_flush_way(int way, int flush)
- (flush >
+ (flush >
@@ -1358,17 +1358,17 @@ int l2cache_fill_way(int way, uint32_t tag, int options, int flush)
/* Perform the Way-flush */
flags = ((options & L2CACHE_OPTIONS_FETCH)? L2C_FLUSHSI_FL:0) |
- ((options & L2CACHE_OPTIONS_VALID)? L2C_FLUSHSI_VB:0) |
+ ((options & L2CACHE_OPTIONS_VALID)? L2C_FLUSHSI_VB:0) |
((options & L2CACHE_OPTIONS_DIRTY)? L2C_FLUSHSI_DB:0);
- /*DBG("L2CACHE lock way: Locked=%d, way=%d, option=0x%04x\n",
+ /*DBG("L2CACHE lock way: Locked=%d, way=%d, option=0x%04x\n",
* locked, way, flags);*/
switch(flush & 0x3){
break;
case L2CACHE_OPTIONS_FLUSH_INVALIDATE:
- l2cache_reg_flushway(tag, way,
+ l2cache_reg_flushway(tag, way,
flags | L2C_FLUSHSI_FMODE_WAY_UPDATE);
break;
@@ -1376,7 +1376,7 @@ int l2cache_fill_way(int way, uint32_t tag, int options, int flush)
break;
default:
flags | L2C_FLUSHSI_FMODE_WAY_UPDATE_WB_ALL);
break;
@@ -1420,7 +1420,7 @@ int l2cache_lock_way(uint32_t tag, int options, int flush, int enable)
/* Check L2C status */
enabled = l2cache_ctrl_status();
/* Disable L2C */
ret = l2cache_disable(flush);
if (ret < 0){
@@ -1434,7 +1434,7 @@ int l2cache_lock_way(uint32_t tag, int options, int flush, int enable)
@@ -1444,7 +1444,7 @@ int l2cache_lock_way(uint32_t tag, int options, int flush, int enable)
break;
break;
@@ -1452,7 +1452,7 @@ int l2cache_lock_way(uint32_t tag, int options, int flush, int enable)
break;
default:
break;
@@ -1502,9 +1502,9 @@ int l2cache_unlock()
/* Setup L2CACHE:
* Parameters:
- * -options: Can be:
+ * -options: Can be:
-int l2cache_mtrr_enable(int index, uint32_t addr, uint32_t mask, int options,
+int l2cache_mtrr_enable(int index, uint32_t addr, uint32_t mask, int options,
int flush)
struct l2cache_priv * priv = l2cachepriv;
@@ -1544,16 +1544,16 @@ int l2cache_mtrr_enable(int index, uint32_t addr, uint32_t mask, int options,
/* Decode options */
flags = 0 |
- (options & L2CACHE_OPTIONS_MTRR_ACCESS_WRITETHROUGH?
- L2C_MTRR_WRITETHROUGH :
+ (options & L2CACHE_OPTIONS_MTRR_ACCESS_WRITETHROUGH?
+ L2C_MTRR_WRITETHROUGH :
L2C_MTRR_UNCACHED) |
- (options & L2CACHE_OPTIONS_MTRR_WRITEPROT_ENABLE?
- L2C_MTRR_WRITEPROT_ENABLE :
+ (options & L2CACHE_OPTIONS_MTRR_WRITEPROT_ENABLE?
+ L2C_MTRR_WRITEPROT_ENABLE :
L2C_MTRR_WRITEPROT_DISABLE) |
L2C_MTRR_ACCESSCONTROL_ENABLE;
/* Configure mtrr */
- l2cache_reg_mtrr_set(index, addr, mask, flags);
+ l2cache_reg_mtrr_set(index, addr, mask, flags);
/* Enable cache again (if needed) */
if (enabled){
@@ -1561,9 +1561,9 @@ int l2cache_mtrr_enable(int index, uint32_t addr, uint32_t mask, int options,
DBG("MTRR[%d] succesfully configured for 0x%08x (mask 0x%08x), "
- "access=%s, wprot=%s\n",
- index, (unsigned int) addr, (unsigned int) mask,
+ "access=%s, wprot=%s\n",
+ index, (unsigned int) addr, (unsigned int) mask,
"WRITETHROUGH":"UNCACHED"),
(options & L2CACHE_OPTIONS_MTRR_WRITEPROT_ENABLE? "ENABLE":"DISABLE")
@@ -1573,7 +1573,7 @@ int l2cache_mtrr_enable(int index, uint32_t addr, uint32_t mask, int options,
/* Setup L2CACHE:
* Parameters:
int l2cache_mtrr_disable(int index)
@@ -1595,7 +1595,7 @@ int l2cache_mtrr_disable(int index)
- l2cache_reg_mtrr_set(index, 0, 0, L2C_MTRR_ACCESSCONTROL_DISABLE);
+ l2cache_reg_mtrr_set(index, 0, 0, L2C_MTRR_ACCESSCONTROL_DISABLE);
DBG("MTRR[%d] disabled\n", index);
@@ -1623,14 +1623,14 @@ int l2cache_print(void)
" MTRR:%d, FT:%s, Locked:%d, Split:%s\n"
" REPL:%s, WP:%s, EDAC:%s, Enabled:%s\n"
" Scrub:%s, S-Delay:%d\n",
- priv->ways,
- priv->waysize,
- priv->linesize,
- (priv->index * priv->ways),
- priv->mtrr,
+ priv->ways,
+ priv->waysize,
+ priv->linesize,
+ (priv->index * priv->ways),
+ priv->mtrr,
(priv->ft_support? "Available":"N/A"),
L2CACHE_LOCKED_WAYS(status),
- (priv->split_support? (L2CACHE_SPLIT_ENABLED(status)?
+ (priv->split_support? (L2CACHE_SPLIT_ENABLED(status)?
"Enabled":"Disabled"):"N/A"),
repl_names[L2CACHE_REPL(status)],
(L2CACHE_WRITETHROUGH(status)? "Write-through":"Write-back"),
@@ -1990,7 +1990,7 @@ int l2cache_isr_register(l2cache_isr_t isr, void * arg, int options)
/* First time registering an ISR */
if (priv->isr == NULL){
/* Install and Enable L2CACHE interrupt handler */
- drvmgr_interrupt_register(priv->dev, 0, priv->devname, l2cache_isr,
+ drvmgr_interrupt_register(priv->dev, 0, priv->devname, l2cache_isr,
priv);
2.34.1
