[PATCH] bsps/clock: Fix fast idle mode
Tue Jan 16 15:44:06 UTC 2024
Switch back to the idle thread if no watchdogs are active.  In some tests, the
idle thread may do some non-blocking work.
 bsps/shared/dev/clock/clockimpl.h | 16 ++++++++++++++++
 1 file changed, 16 insertions(+)
diff --git a/bsps/shared/dev/clock/clockimpl.h b/bsps/shared/dev/clock/clockimpl.h
index e922c0b320..ec56e175f5 100644
--- a/bsps/shared/dev/clock/clockimpl.h
+++ b/bsps/shared/dev/clock/clockimpl.h
@@ -139,6 +139,21 @@ volatile uint32_t    Clock_driver_ticks;
 #error "Clock_driver_support_shutdown_hardware() is no longer supported"
 #endif
+#if CLOCK_DRIVER_USE_FAST_IDLE
+static bool Clock_Has_watchdogs(const Per_CPU_Control *cpu)
+  size_t i;
+  for (i = 0; i < RTEMS_ARRAY_SIZE(cpu->Watchdog.Header); ++i) {
+    if (_Watchdog_Header_first(&cpu->Watchdog.Header[i]) != NULL) {
+      return true;
+  return false;
+#endif
  *  @brief Clock_isr
@@ -182,6 +197,7 @@ rtems_isr Clock_isr(
           cpu_self->thread_dispatch_disable_level == cpu_self->isr_nest_level
             && cpu_self->heir == cpu_self->executing
             && cpu_self->executing->is_idle
+            && Clock_Has_watchdogs(cpu_self)
           ISR_lock_Context lock_context;
2.35.3
