[RTEMS Tools 0/1] trace/wscript: Improve C++ standard selection
Sun Jan 21 16:42:19 UTC 2024
On 20.01.24 16:25, Sebastian Huber wrote:
> On 19.01.24 10:13, Sebastian Huber wrote:
>> On 19.01.24 09:09, Cedric Berger wrote:
>>> On 19.01.2024 08:55, Sebastian Huber wrote:
>>>> On 19.01.24 07:58, Sebastian Huber wrote:
>>>>> This patch fixes bugs #4908 and #4965 which were reported by RTMES
>>>>> users.  The patch is from 19 May 2023 and was blocked due to missing
>>>>> tests on macOS.  I have no macOS system for tests.  Would someone mind
>>>>> testing this patch?  It would be nice to build the RTEMS Tools on
>>>>> modern
>>>>> Linux systems with a standard LLVM package.
>>>> I added a simple CI script to our Github fork of rtems-tools:
>>>> https://github.com/embedded-brains/rtems-tools
>>>> It seems that the current tools build with LLVM installed on
>>>> ubuntu-latest event without the patch:
>>>> https://github.com/embedded-brains/rtems-tools/actions/runs/7580906673
>>>> It builds also with the patch:
>>>> https://github.com/embedded-brains/rtems-tools/actions/runs/7580925618
>>>> I installed LLVM on macOS using brew, however, the rtems-tools
>>>> didn't pick it up. How can I build the rtems-tools on macOS with
>>>> LLVM support?
>>> I'm willing to spend some time testing stuff on macOS.
>> Thanks for having a look at it.
>>> However, I don't really understand why you installed LLVM using brew:
>>> people on MacOS usually use the standard XCode compiler from Apple,
>>> which is itself based on LLVM.
>> I don't use macOS myself, so I have no idea how this is set up
>> normally. It would be great to have the standard approach available as
>> a Github workflow.
>>> What needs to be tested exactly?
>> The rtems-tools need to be built with the LLVM support. For this ./waf
>> configure needs to find LLVM. If it works it prints out something like
>> this:
>> Checking for library LLVM                : yes
>> Checking for header llvm/DebugInfo/Symbolize/Symbolize.h : yes
>> Checking for header zlib.h                               : yes
>> Checking for library z                                   : yes
>> Checking for library ws2_32                              : not found
>> Checking for compiler flags -std=c++20                   : yes
> The Github macOS runner has several tools installed:
> https://github.com/actions/runner-images/blob/main/images/macos/macos-13-Readme.md
> It would be nice if you could figure out how you have to configure the
> rtems-tools build so that it finds an LLVM installation providing
> Symbolize.h on macOS.
In the Github job, I added the LLVM 17 installation from brew to the $PATH:
           export
PATH="/System/Volumes/Data/usr/local/Cellar/llvm/17.0.6/bin:$PATH"
           ./waf configure
           ./waf
           sudo ./waf install
Without the patch, the build fails:
https://github.com/embedded-brains/rtems-tools/actions/runs/7602490988/job/20703105123
With the patch it works:
https://github.com/embedded-brains/rtems-tools/actions/runs/7602509162/job/20703139110
Does XCode ship a Symbolize.h and llvm-config? If yes, how do you get
the tool in the $PATH?
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
