[PATCH rtems-libbsd 04/14] pci: Back port changes
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Jan 23 09:09:05 UTC 2024
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
 freebsd/sys/dev/pci/pci.c     | 3 ++-
 freebsd/sys/dev/pci/pci_pci.c | 3 ++-
 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/freebsd/sys/dev/pci/pci.c b/freebsd/sys/dev/pci/pci.c
index 0cc72dba..3789a73e 100644
--- a/freebsd/sys/dev/pci/pci.c
+++ b/freebsd/sys/dev/pci/pci.c
@@ -233,7 +233,8 @@ static device_method_t pci_methods[] = {
 DEFINE_CLASS_0(pci, pci_driver, pci_methods, sizeof(struct pci_softc));
 static devclass_t pci_devclass;
-DRIVER_MODULE(pci, pcib, pci_driver, pci_devclass, pci_modevent, NULL);
+EARLY_DRIVER_MODULE(pci, pcib, pci_driver, pci_devclass, pci_modevent, NULL,
+    BUS_PASS_BUS);
 MODULE_VERSION(pci, 1);
 static char	*pci_vendordata;
diff --git a/freebsd/sys/dev/pci/pci_pci.c b/freebsd/sys/dev/pci/pci_pci.c
index 5ba3e9a0..c1e73a3c 100644
--- a/freebsd/sys/dev/pci/pci_pci.c
+++ b/freebsd/sys/dev/pci/pci_pci.c
@@ -136,7 +136,8 @@ static device_method_t pcib_methods[] = {
 static devclass_t pcib_devclass;
 DEFINE_CLASS_0(pcib, pcib_driver, pcib_methods, sizeof(struct pcib_softc));
-DRIVER_MODULE(pcib, pci, pcib_driver, pcib_devclass, NULL, NULL);
+EARLY_DRIVER_MODULE(pcib, pci, pcib_driver, pcib_devclass, NULL, NULL,
+    BUS_PASS_BUS);
 #if defined(NEW_PCIB) || defined(PCI_HP)
 SYSCTL_DECL(_hw_pci);
2.35.3
