[PATCH rtems-libbsd 07/14] Enable NEW_PCIB
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Jan 23 09:09:08 UTC 2024
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
 rtemsbsd/include/machine/resource.h           |  1 +
 .../include/machine/rtems-bsd-kernel-space.h  |  8 +++++++
 rtemsbsd/rtems/rtems-kernel-nexus.c           | 21 +++++++++++++++++++
 3 files changed, 30 insertions(+)
diff --git a/rtemsbsd/include/machine/resource.h b/rtemsbsd/include/machine/resource.h
index ad4f0f29..babc1ae6 100644
--- a/rtemsbsd/include/machine/resource.h
+++ b/rtemsbsd/include/machine/resource.h
@@ -45,5 +45,6 @@
 #define SYS_RES_MEMORY 3
 #define SYS_RES_IOPORT 4
 #define SYS_RES_GPIO 5
+#define PCI_RES_BUS 6
 #endif /* _RTEMS_BSD_MACHINE_RESOURCE_H_ */
diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-space.h b/rtemsbsd/include/machine/rtems-bsd-kernel-space.h
index 09f3c64d..2b45c2db 100644
--- a/rtemsbsd/include/machine/rtems-bsd-kernel-space.h
+++ b/rtemsbsd/include/machine/rtems-bsd-kernel-space.h
@@ -247,6 +247,14 @@ dev_t rtems_bsd__makedev(int _M, int _m);
 struct dirent;
 void dirent_terminate(struct dirent *dp);
+ * Enable the "new" PCI-PCI bridge driver, since this is going to be the future
+ * FreeBSD driver:
+ * https://reviews.freebsd.org/D32954
+#define	NEW_PCIB 1
 #ifdef __cplusplus
 #endif /* __cplusplus */
diff --git a/rtemsbsd/rtems/rtems-kernel-nexus.c b/rtemsbsd/rtems/rtems-kernel-nexus.c
index 8fc879fe..c5ee33d8 100644
--- a/rtemsbsd/rtems/rtems-kernel-nexus.c
+++ b/rtemsbsd/rtems/rtems-kernel-nexus.c
@@ -57,6 +57,7 @@
 #endif
 #include <rtems/bsd/bsd.h>
+#include <rtems/bsd/modules.h>
 #include <rtems/irq-extension.h>
 #include <bsp.h>
@@ -103,6 +104,10 @@ static struct rman mem_rman;
 static struct rman irq_rman;
+#ifdef RTEMS_BSD_MODULE_PCI
+static struct rman pci_rman;
+#endif
 #if defined(RTEMS_BSP_PCI_IO_REGION_BASE)
 static struct rman port_rman;
 #endif
@@ -137,6 +142,17 @@ nexus_probe(device_t dev)
 	err = rman_manage_region(&irq_rman, irq_rman.rm_start, irq_rman.rm_end);
 	BSD_ASSERT(err == 0);
+	pci_rman.rm_start = 0;
+	pci_rman.rm_end = ~0UL;
+	pci_rman.rm_type = RMAN_ARRAY;
+	pci_rman.rm_descr = "PCI bus";
+	err = rman_init(&pci_rman) != 0;
+	BSD_ASSERT(err == 0);
+	err = rman_manage_region(&pci_rman, pci_rman.rm_start, pci_rman.rm_end);
+#endif
 	port_rman.rm_start = 0;
 	port_rman.rm_end = ~0UL;
@@ -191,6 +207,11 @@ nexus_alloc_resource(device_t bus, device_t child, int type, int *rid,
 	case SYS_RES_IRQ:
 		rm = &irq_rman;
 		break;
+	case PCI_RES_BUS:
+		rm = &pci_rman;
+		break;
+#endif
 	case SYS_RES_IOPORT:
 		rm = &port_rman;
2.35.3
