[PATCH rtems6 1/1] libmisc/shell: Fix timeout in getting terminal size
Wed Jan 24 00:09:01 UTC 2024
On 23/1/2024 9:00 pm, Peter Dufault wrote:
>> On Jan 22, 2024, at 1:51 PM, Peter Dufault <dufault at hda.com> wrote:
>>> On Jan 22, 2024, at 12:16 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> I have a couple minor notes below. More important, does this change
>>> require updating documentation?
>> I'd have to look to see if this window size detection is documented, I wanted to fix the problem it caused me.
>>> I know we have a somewhat aging shell-specific guide:
>>> https://docs.rtems.org/branches/master/shell/index.html
The original change is by me so I can take a look at this. Thanks for mentioning
this. :)
>>> On Fri, Jan 19, 2024 at 5:19 AM <dufault at hda.com> wrote:
>>>> From: Peter Dufault <dufault at hda.com>
>>>> - Fix detection of timeout in rtems_shell_term_wait_for().
>>>> - Switch to using "termios" VTIME inter-character timeout.
>>>> The previous implementation is dependent on the BSP clock tick value.
>>>> Updates #4763
>>>> cpukit/libmisc/shell/shell.c | 101 ++++++++++++++++++++++++++-----------------
>>>> 1 file changed, 62 insertions(+), 39 deletions(-)
>>>> diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
>>>> index 9cefc80..60cdb4f 100644
>>>> --- a/cpukit/libmisc/shell/shell.c
>>>> +++ b/cpukit/libmisc/shell/shell.c
>>>> @@ -805,28 +805,52 @@ void rtems_shell_print_env(
>>>> #endif
>>>> +/* Debugging output for the terminal I/O associated with window size detection
>>>> + * can be sent with rtems_shell_winsize_db().
>>>> +/* Window size detection knobs.
>>>> +static bool rtems_shell_winsize_dbf;        /* Debug.  "true" to debug. */
>>> Is this necessary? How does the application set/test this?
>> I don't know.  Same with the "vtime" setting, no way to change that either. Rationale:
>> - It puts what you may want to change in one place.
>> - I'm not a fan of "#define".
>> - I didn't want to add a public interface to tweak things (then I *would* need to document).
>> - It was useful. I left it in to make it clear how to compile-time turn it on if you need it.
>> I can make the "dbf" behavior pre-processor enabled at compile-time.  Or take it out.
> I'm embarrassed to say I didn't see that SHELL_WINSIZE_DEBUG is already in the code.  I will switch to use that.
> I don't like losing the format checking when a flag is undefined.  I can avoid that by unconditionally adding <rtems/bspIo.h>.  There is already SHELL_DEBUG conditional code using "printk()" without including <rtems/bspIo.h>.
Thanks for look into this and cleaning up the cruft. It couuld be BPS specific
and why it the include is an issue for some and not others.
> #define SHELL_STD_DEBUG 1      /* Or 0. */
> #define SHELL_WINSIZE_DEBUG 1  /* Or 0. */
> #if SHELL_STD_DEBUG | SHELL_WINSIZE_DEBUG
> #include <rtems/bspIo.h>
> #define shell_std_debug_(...) \
>   do { printk("shell[%08x]: ", rtems_task_self()); printk(__VA_ARGS__); } while (0)
> #endif
> #if SHELL_STD_DEBUG
> #define shell_std_debug(...) do { shell_std_debug_(__VA_ARGS__); } while (0)
> #else
> #endif
> #if SHELL_WINSIZE_DEBUG
> #define shell_winsize_debug(...) do { shell_std_debug_(__VA_ARGS__); } while (0)
> #else
> #endif
Compiling out the debug code is a good approach if not enabled.
> - OR: Polluted (with rtems/bspIo.h) implementation:
> #define shell_std_debug_(ENABLE, ...) \
>   do { if (ENABLE) printk("shell[%08x]: ", rtems_task_self()); printk(__VA_ARGS__); } while (0)
> #define shell_std_debug(...) shell_std_debug_(SHELL_STD_DEBUG, __VA_ARGS__)
> #define shell_winsize_debug(...) shell_std_debug_(SHELL_WINSIZE_DEBUG, __VA_ARGS__)
>> I would leave the "vtime" static, there was no way to change the previous timeout either.
>>>> +static int rtems_shell_winsize_vtime = 1;  /* VTIME timeout in .1 seconds */
Why is this in RAM. Do you see users needing to adjust this value? If so now
would a user change it?
>>>> +static void rtems_shell_winsize_vdb(const char *format, va_list ap) {
>>>> +  if (rtems_shell_winsize_dbf == false)
>>>> +    return;
>>>> +  printf("shell_winsize: ");
>>>> +  vprintf(format, ap);
>>>> +  fflush(stdout);
>>>> +static void rtems_shell_winsize_db(const char *format, ...) {
>>>> +  va_list ap;
>>>> +  va_start(ap, format);
>>>> +  rtems_shell_winsize_vdb(format, ap);
>>>> +  va_end(ap);
>>>> * Wait for the string to return or timeout.
>>>> -static bool rtems_shell_term_wait_for(const int fd, const char* str, const int timeout)
>>>> +static bool rtems_shell_term_wait_for(const int fd, const char* str)
>>>> -  int msec = timeout;
>>>>  int i = 0;
>>>> -  while (msec-- > 0 && str[i] != '\0') {
>>>> +  while (str[i] != '\0') {
>>>>    char ch[2];
>>>> -    if (read(fd, &ch[0], 1) == 1) {
>>>> -      fflush(stdout);
>>>> +    ssize_t n;
>>>> +    if ((n = read(fd, &ch[0], 1)) == 1) {
>>>>      if (ch[0] != str[i++]) {
>>>> +        rtems_shell_winsize_db("Wrong char at char %d.\n", i);
>>>>        return false;
>>>> -      msec = timeout;
>>>>    } else {
>>>> -      usleep(1000);
>>>> +      rtems_shell_winsize_db("%s reading char %d.\n",
>>>> +       (n == 0) ? "Timeout" : "Error", i);
>>> I'd suggest putting the 'i' on it's own line here.  I don't know that
>>> there's a specific style guide for this file, but having trailing
>>> statements after the ternary is a bit harder to read. imo
>> Sure.
>>>> +      return false;
>>>> -  if (msec == 0) {
>>>> -    return false;
>>>> +  rtems_shell_winsize_db("Matched string.\n");
>>>>  return true;
>>>> @@ -836,41 +860,42 @@ static bool rtems_shell_term_wait_for(const int fd, const char* str, const int t
>>>> static int rtems_shell_term_buffer_until(const int fd,
>>>>                                         char* buf,
>>>>                                         const int size,
>>>> -                                         const char* end,
>>>> -                                         const int timeout)
>>>> +                                         const char* end)
>>>>  int i = 0;
>>>>  int e = 0;
>>>>  memset(&buf[0], 0, size);
>>>> -  while (msec-- > 0 && i < size && end[e] != '\0') {
>>>> +  while (i < size && end[e] != '\0') {
>>>>    char ch[2];
>>>> -      fflush(stdout);
>>>> +    ssize_t n;
>>>> +    if ( (n = read(fd, &ch[0], 1)) == 1) {
>>>>      buf[i++] = ch[0];
>>>>      if (ch[0] == end[e]) {
>>>>        e++;
>>>>      } else {
>>>> +        rtems_shell_winsize_db("Reset search for end string.\n");
>>>>        e = 0;
>>>> -      msec = timeout;
>>>>    } else {
>>>> -      usleep(1000);
>>>> +      /* Error or timeout. */
Question?
>>>> +         "%s looking for end string \"%s\". Read \"%s\".\n",
>>>> +         (n == 0) ? "Timeout" : "Error", end, buf
>>>> +      return -1;
>>>> -  if (msec == 0 || end[e] != '\0') {
>>>> -    return -1;
>>>> -  i -= e;
>>>> +  i -= e;   /* Toss away the matched end. */
>>>>  if (i < size) {
>>>>    buf[i] = '\0';
>>>> +  rtems_shell_winsize_db("Found end string \"%s\".\n", end);
>>>>  return i;
>>>> - * Determine if the terminal has the row and column values
>>>> - * swapped
>>>> + * Determine if this is a version of the "tmux" terminal emulator with
>>>> + * the row and column values swapped
>>>> * https://github.com/tmux/tmux/issues/3457
>>>> @@ -878,19 +903,19 @@ static int rtems_shell_term_buffer_until(const int fd,
>>>> * in the time it takes to get the fix into code so see if tmux is
>>>> * running and which version and work around the bug.
>>>> - * The terminal device needs to have VMIN=0, and VTIME=0
>>>> + * The terminal device needs to have VMIN=0, and VTIME set to the
>>>> + * desired timeout in .1 seconds.
>>>> -static bool rtems_shell_term_row_column_swapped(const int fd, const int timeout) {
>>>> +static bool rtems_shell_term_row_column_swapped(const int fd, const int fout) {
>>>>  char buf[64];
>>>>  memset(&buf[0], 0, sizeof(buf));
>>>>   * CSI > Ps q
>>>>   *    Ps = 0   =>   DCS > | text ST
>>>> -  fputs("\033[>0q", stdout);
>>>> -  fflush(stdout);
>>>> -  if (rtems_shell_term_wait_for(fd, "\033P>|", timeout)) {
>>>> -    int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "\033\\", timeout);
>>>> +  write(fout, "\033[>0q", 5);
Why the change to use write?
>>>> +  if (rtems_shell_term_wait_for(fd, "\033P>|")) {
>>>> +    int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "\033\\");
>>>>    if (len > 0) {
>>>>      if (memcmp(buf, "tmux ", 5) == 0) {
>>>>        static const char* bad_versions[] = {
>>>> @@ -916,8 +941,8 @@ static bool rtems_shell_term_row_column_swapped(const int fd, const int timeout)
>>>> static void rtems_shell_winsize( void )
>>>>  const int fd = fileno(stdin);
>>>> +  const int fout = fileno(stdout);
>>>>  struct winsize ws;
>>>> -  const int timeout = 150;
>>>>  char buf[64];
>>>>  bool ok = false;
>>>>  int lines = 0;
>>>> @@ -933,18 +958,16 @@ static void rtems_shell_winsize( void )
>>>>    if (tcgetattr(fd, &cterm) >= 0) {
>>>>      struct termios term = cterm;
>>>>      term.c_cc[VMIN] = 0;
>>>> -      term.c_cc[VTIME] = 0;
>>>> -      if (tcsetattr (fd, TCSADRAIN, &term) >= 0) {
>>>> +      term.c_cc[VTIME] = rtems_shell_winsize_vtime;
>>>> +      if (tcsetattr (fd, TCSAFLUSH, &term) >= 0) {
>>>>         * https://invisible-island.net/xterm/ctlseqs/ctlseqs.html#h3-Miscellaneous
>>>>         * CSI 1 8 t
>>>> -        fputs("\033[18t", stdout);
>>>> -        fflush(stdout);
>>>> -        if (rtems_shell_term_wait_for(fd, "\033[8;", timeout)) {
>>>> -          int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), ";", timeout);
>>>> +        if (write(fout, "\033[18t", 5) == 5 && rtems_shell_term_wait_for(fd, "\033[8;"))
I prefer these statements to be on separate lines.
>>>> +          int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), ";");
>>>>          if (len > 0) {
>>>>            int i;
>>>>            lines = 0;
>>>> @@ -953,7 +976,7 @@ static void rtems_shell_winsize( void )
>>>>              lines *= 10;
>>>>              lines += buf[i++] - '0';
>>>> -            len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "t", timeout);
>>>> +            len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "t");
>>>>            if (len > 0) {
>>>>              cols = 0;
>>>>              i = 0;
>>>> @@ -966,7 +989,7 @@ static void rtems_shell_winsize( void )
>>>> -      if (rtems_shell_term_row_column_swapped(fd, timeout)) {
>>>> +      if (ok && rtems_shell_term_row_column_swapped(fd, fout)) {
>>>>        int tmp = lines;
>>>>        lines = cols;
>>>>        cols = tmp;
>>>> 1.8.3.1
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>> Peter
>> Peter Dufault
>> HD Associates, Inc.      Software and System Engineering
>> devel mailing list
>> devel at rtems.org
> Peter
> Peter Dufault
> devel mailing list
> devel at rtems.org
