[PATCH v2 2/3] bsps: Add flash wrapper for Xilinx GQSPI
aaron.nyholm at unfoldedeffective.com aaron.nyholm at unfoldedeffective.com
Wed Jan 24 05:22:16 UTC 2024
From: Aaron Nyholm <aaron.nyholm at unfoldedeffective.com>
 bsps/aarch64/xilinx-versal/include/bsp/irq.h  |   1 +
 bsps/include/dev/spi/xqspi_flash.h            |  65 ++++++
 bsps/include/dev/spi/xqspipsu-flash-helper.h  |  20 ++
 bsps/shared/dev/spi/xqspi_flash.c             | 210 ++++++++++++++++++
 bsps/shared/dev/spi/xqspipsu-flash-helper.c   |  13 ++
 spec/build/bsps/aarch64/xilinx-versal/grp.yml |   4 +
 spec/build/bsps/objxilinxsupportlp64.yml      |   4 +-
 spec/build/bsps/objxqspiflash.yml             |  22 ++
 spec/build/bsps/optxilsupportpath.yml         |   4 +-
 9 files changed, 341 insertions(+), 2 deletions(-)
 create mode 100644 bsps/include/dev/spi/xqspi_flash.h
 create mode 100644 bsps/shared/dev/spi/xqspi_flash.c
 create mode 100644 spec/build/bsps/objxqspiflash.yml
diff --git a/bsps/aarch64/xilinx-versal/include/bsp/irq.h b/bsps/aarch64/xilinx-versal/include/bsp/irq.h
index b34bdfd345..6f4d387e8f 100644
--- a/bsps/aarch64/xilinx-versal/include/bsp/irq.h
+++ b/bsps/aarch64/xilinx-versal/include/bsp/irq.h
@@ -61,6 +61,7 @@ extern "C" {
 #define VERSAL_IRQ_ETHERNET_0_WAKEUP 89
 #define VERSAL_IRQ_ETHERNET_1 90
 #define VERSAL_IRQ_ETHERNET_1_WAKEUP 91
+#define VERSAL_IRQ_QSPI 157
diff --git a/bsps/include/dev/spi/xqspi_flash.h b/bsps/include/dev/spi/xqspi_flash.h
new file mode 100644
index 0000000000..e4bc4a5183
--- /dev/null
+++ b/bsps/include/dev/spi/xqspi_flash.h
@@ -0,0 +1,65 @@
+ * Copyright (C) 2023, 2023 Aaron Nyholm
+ * are met:
+#ifndef XILINX_XQSPI_FLASH_H
+#define XILINX_XQSPI_FLASH_H
+#include <dev/flash/flashdev.h>
+#include <dev/spi/xqspipsu.h>
+#define XQSPI_MAX_REGIONS 32
+#define MAX_READ_SIZE 0x8000
+ * @brief Initializes a flash device using Xilinx's xqspi flash
+ * driver. The flash device is not registered in this call.
+ * If an rtems_flashdev is created using xqspi_flash_init it must be
+ * destroyed using xqspi_flash_destroy.
+ * @param[in] xQspiDev A configured XQspiPsu device to initialise.
+ * @retval A pointer to the rtems_flashdev.
+ * @retval NULL on failure.
+rtems_flashdev* xqspi_flash_init(XQspiPsu *xQspiDev);
+ * @brief Destroys a rtems_flashdev initialised with xqspi_flash_init.
+ * destroyed using xqspi_flash_destroy. The XQspiPsu originally passed in
+ * is untouched.
+ * @param[in] flash The flashdev to destroy
+void xqspi_flash_destroy(rtems_flashdev* flash);
+typedef struct versal_xqspi_region_table {
+  rtems_flashdev_region versal_xqspi_regions[XQSPI_MAX_REGIONS];
+  uint32_t versal_xqspi_bit_allocator;
+} versal_xqspi_region_table;
+#endif /* XILINX_XQSPI_FLASH_H */
diff --git a/bsps/include/dev/spi/xqspipsu-flash-helper.h b/bsps/include/dev/spi/xqspipsu-flash-helper.h
index e689660881..e73952769c 100644
--- a/bsps/include/dev/spi/xqspipsu-flash-helper.h
+++ b/bsps/include/dev/spi/xqspipsu-flash-helper.h
@@ -190,3 +190,23 @@ int QspiPsu_NOR_RDSFDP(
   u32 ByteCount,
   u8 **ReadBfrPtr
+ * This function returns the page size of attached flash parts.
+ * @param	QspiPsuPtr is a pointer to the QSPIPSU driver component to use.
+ * @return	The page size of attached flash in bytes.
+u32 QspiPsu_NOR_Get_Page_Size(XQspiPsu *QspiPsuPtr);
+ * This function returns the JEDEC ID of attached flash parts.
+ * @return	The JEDEC ID of attached flash in bytes.
+u32 QspiPsu_NOR_Get_JEDEC_ID(XQspiPsu *QspiPsuPtr);
diff --git a/bsps/shared/dev/spi/xqspi_flash.c b/bsps/shared/dev/spi/xqspi_flash.c
index 0000000000..b641932abc
--- /dev/null
+++ b/bsps/shared/dev/spi/xqspi_flash.c
@@ -0,0 +1,210 @@
+ * are met:
+#include <bsp/irq.h>
+#include <dev/spi/xqspi_flash.h>
+#include <dev/spi/xqspipsu-flash-helper.h>
+#include <dev/spi/xqspipsu_flash_config.h>
+#include <stdlib.h>
+#include <string.h>
+static uint32_t xqspi_get_jedec_id(rtems_flashdev *flash) {
+  return QspiPsu_NOR_Get_JEDEC_ID(flash->driver);
+static int xqspi_get_flash_type(
+  rtems_flashdev *flash,
+  rtems_flashdev_flash_type *type
+  *type = RTEMS_FLASHDEV_NOR;
+  return 0;
+static int xqspi_read_wrapper(
+    uintptr_t offset,
+    size_t count,
+    void *buffer
+  XQspiPsu *flash_driver = (XQspiPsu*)flash->driver;
+  uint8_t *tmp_buffer;
+  int status;
+  int startAlign = 0;
+  /* Align offset to two byte boundary */
+  if (offset%2) {
+    startAlign = 1;
+    offset = offset - 1;
+    count = count + 1;
+  while (count > MAX_READ_SIZE) {
+    /* Read block and copy to buffer */
+    status = QspiPsu_NOR_Read(flash_driver, (uint32_t)offset, MAX_READ_SIZE, &tmp_buffer);
+    if (status == 0) {
+      memcpy(buffer, tmp_buffer + startAlign, MAX_READ_SIZE - startAlign);
+      /* Update count, offset and buffer pointer */
+      count = count - MAX_READ_SIZE;
+      buffer = buffer + MAX_READ_SIZE - startAlign;
+      offset = offset + MAX_READ_SIZE;
+      /* Clear startAlign once first block read */
+      if (startAlign) {
+        startAlign = 0;
+    } else {
+      return status;
+  status = QspiPsu_NOR_Read(flash_driver, (uint32_t)offset, (uint32_t)count, &tmp_buffer);
+    memcpy(buffer, tmp_buffer + startAlign, count);
+  return status;
+static int xqspi_page_info_by_off(
+  off_t search_offset,
+  off_t *page_offset,
+  size_t *page_size
+  *page_size = QspiPsu_NOR_Get_Page_Size(flash->driver);
+  *page_offset = search_offset - (search_offset%((off_t)(*page_size)));
+  return 0;
+static int xqspi_page_info_by_index(
+  off_t search_index,
+  size_t *page_size
+  *page_offset = *page_size * search_index;
+  return 0;
+static int xqspi_page_count(
+  int *page_count
+  *page_count = QspiPsu_NOR_Get_Device_Size(flash->driver) /
+                  QspiPsu_NOR_Get_Page_Size(flash->driver);
+  return 0;
+static int xqspi_write_block_size(
+  size_t *write_block_size
+  *write_block_size = QspiPsu_NOR_Get_Page_Size(flash->driver);
+  return 0;
+static int xqspi_write_wrapper(
+  uintptr_t offset,
+  size_t count,
+  const void *buffer
+  return QspiPsu_NOR_Write(flash_driver, (uint32_t)offset, (uint32_t)count, (void*)buffer);
+static int xqspi_erase_wrapper(
+  uintptr_t offset,
+  size_t count
+  return QspiPsu_NOR_Erase(flash_driver, (uint32_t)offset, (uint32_t)count);
+  versal_xqspi_region_table *xtable =
+    calloc(1, sizeof(versal_xqspi_region_table));
+  if (xtable == NULL) {
+    free(xQspiDev);
+    return NULL;
+  rtems_flashdev_region_table *ftable =
+    calloc(1, sizeof(rtems_flashdev_region_table));
+  if (ftable == NULL) {
+    free(xtable);
+    free(xQspiDev);
+    return NULL;
+  ftable->regions = (rtems_flashdev_region*)(&(xtable->versal_xqspi_regions));
+  ftable->max_regions = XQSPI_MAX_REGIONS;
+  ftable->bit_allocator = &(xtable->versal_xqspi_bit_allocator);
+  rtems_flashdev *flash = rtems_flashdev_alloc_and_init(sizeof(rtems_flashdev));
+  if (flash == NULL) {
+    free(xQspiDev);
+    free(xtable);
+    free(ftable);
+    return NULL;
+  flash->driver = xQspiDev;
+  flash->read = &xqspi_read_wrapper;
+  flash->write = &xqspi_write_wrapper;
+  flash->erase = &xqspi_erase_wrapper;
+  flash->jedec_id = &xqspi_get_jedec_id;
+  flash->flash_type = &xqspi_get_flash_type;
+  flash->page_info_by_offset = &xqspi_page_info_by_off;
+  flash->page_info_by_index = &xqspi_page_info_by_index;
+  flash->page_count = &xqspi_page_count;
+  flash->write_block_size = &xqspi_write_block_size;
+  flash->region_table = ftable;
+  return flash;
+  free(flash->region_table->regions);
+  free(flash->region_table);
+  rtems_flashdev_destroy_and_free(flash);
diff --git a/bsps/shared/dev/spi/xqspipsu-flash-helper.c b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
index 69c4035e6a..ef19f850e7 100644
--- a/bsps/shared/dev/spi/xqspipsu-flash-helper.c
+++ b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
@@ -2338,3 +2338,16 @@ u32 QspiPsu_NOR_Get_Device_Size(XQspiPsu *QspiPsuPtr)
   return Flash_Config_Table[FCTIndex].FlashDeviceSize;
+  if(QspiPsuPtr->Config.ConnectionMode == XQSPIPSU_CONNECTION_MODE_STACKED) {
+    return Flash_Config_Table[FCTIndex].PageSize * 2;
+  return Flash_Config_Table[FCTIndex].PageSize;
+  return Flash_Config_Table[FCTIndex].jedec_id;
diff --git a/spec/build/bsps/aarch64/xilinx-versal/grp.yml b/spec/build/bsps/aarch64/xilinx-versal/grp.yml
index 6b4ea31133..cb8c1afc75 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/grp.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/grp.yml
@@ -56,6 +56,10 @@ links:
   uid: ../../objdevspixil
 - role: build-dependency
   uid: ../../objmem
+- role: build-dependency
+  uid: ../../objxilinxsupport
+  uid: ../../objxqspiflash
   uid: ../../optcachedata
diff --git a/spec/build/bsps/objxilinxsupportlp64.yml b/spec/build/bsps/objxilinxsupportlp64.yml
index 330ffc34fd..601a717c5c 100644
--- a/spec/build/bsps/objxilinxsupportlp64.yml
+++ b/spec/build/bsps/objxilinxsupportlp64.yml
@@ -6,7 +6,9 @@ copyrights:
 cppflags: []
 cxxflags: []
 enabled-by:
-- bsps/aarch64/xilinx_versal
+- aarch64/xilinx_versal_aiedge
+- aarch64/xilinx_versal_qemu
+- aarch64/xilinx_versal_vck190
 - aarch64/xilinx_zynqmp_lp64_cfc400x
 - aarch64/xilinx_zynqmp_lp64_qemu
 - aarch64/xilinx_zynqmp_lp64_zu3eg
diff --git a/spec/build/bsps/objxqspiflash.yml b/spec/build/bsps/objxqspiflash.yml
index 0000000000..e1aad09adc
--- /dev/null
+++ b/spec/build/bsps/objxqspiflash.yml
@@ -0,0 +1,22 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2023 Aaron Nyholm
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+- bsps/include/dev/spi/
+- bsps/include/xil/
+- bsps/include/xil/${XIL_SUPPORT_PATH}/
+install:
+- destination: ${BSP_INCLUDEDIR}/dev/spi
+  source:
+  - bsps/include/dev/spi/xqspi_flash.h
+links:
+  uid: objxilinxsupport
+source:
+- bsps/shared/dev/spi/xqspi_flash.c
+type: build
diff --git a/spec/build/bsps/optxilsupportpath.yml b/spec/build/bsps/optxilsupportpath.yml
index 85bcc7e059..53898e6575 100644
--- a/spec/build/bsps/optxilsupportpath.yml
+++ b/spec/build/bsps/optxilsupportpath.yml
@@ -20,10 +20,12 @@ default:
   - aarch64/xilinx_zynqmp_ilp32_zu3eg
   value: arm/ARMv8/32bit
 - enabled-by:
+  - aarch64/xilinx_versal_aiedge
+  - aarch64/xilinx_versal_qemu
+  - aarch64/xilinx_versal_vck190
-  - bsps/aarch64/xilinx_versal
   value: arm/ARMv8/64bit
 description: Set the Xilinx support path
 enabled-by: true
2.25.1
