[PATCH] cpukit/cache: Report coherent add area failures
Kinsey Moore kinsey.moore at oarcorp.com
Wed Jan 24 17:19:39 UTC 2024
This alters the API for rtems_cache_coherent_add_area to allow reporting
of failures that can occur during the process of adding a new area to
the coherent cache heap.
 cpukit/include/rtems/rtems/cache.h          | 12 ++++++++-
 cpukit/libcsupport/src/cachecoherentalloc.c | 27 ++++++++++++---------
 2 files changed, 27 insertions(+), 12 deletions(-)
diff --git a/cpukit/include/rtems/rtems/cache.h b/cpukit/include/rtems/rtems/cache.h
index 20c630a3eb..d37a671849 100644
--- a/cpukit/include/rtems/rtems/cache.h
+++ b/cpukit/include/rtems/rtems/cache.h
@@ -59,6 +59,7 @@
 #include <stddef.h>
 #include <stdint.h>
+#include <rtems/rtems/status.h>
 #ifdef __cplusplus
 extern "C" {
@@ -89,6 +90,15 @@ extern "C" {
  * @param size is the size in bytes of the cache coherent memory area to add.
+ * @retval ::RTEMS_SUCCESSFUL The cache coherent memory extension was
+ *   successful.
+ * @retval ::RTEMS_UNSATISFIED The cache coherent memory extension was not
+ *   successful.
+ * @return Returns a rtems_status_code indicating whether the area was added to
+ *   cache coherent memory.
  * @par Constraints
  * @parblock
  * The following constraints apply to this directive:
@@ -102,7 +112,7 @@ extern "C" {
  *   cause the calling task to be preempted.
  * @endparblock
-void rtems_cache_coherent_add_area( void *begin, uintptr_t size );
+rtems_status_code rtems_cache_coherent_add_area( void *begin, uintptr_t size );
 /* Generated from spec:/rtems/cache/if/coherent-allocate */
diff --git a/cpukit/libcsupport/src/cachecoherentalloc.c b/cpukit/libcsupport/src/cachecoherentalloc.c
index 198eb907b5..1e15758f98 100644
--- a/cpukit/libcsupport/src/cachecoherentalloc.c
+++ b/cpukit/libcsupport/src/cachecoherentalloc.c
@@ -97,7 +97,7 @@ void rtems_cache_coherent_free( void *ptr )
   _RTEMS_Unlock_allocator();
-static void add_area(
+static int add_area(
   void *area_begin,
   uintptr_t area_size
@@ -105,31 +105,36 @@ static void add_area(
   Heap_Control *heap = cache_coherent_heap;
   if ( heap == NULL ) {
-    bool ok;
     heap = &cache_coherent_heap_instance;
-    ok = _Heap_Initialize( heap, area_begin, area_size, 0 );
-    if ( ok ) {
-      cache_coherent_heap = heap;
+    if ( _Heap_Initialize( heap, area_begin, area_size, 0 ) == 0 ) {
+      return -1;
+    cache_coherent_heap = heap;
   } else {
-    _Heap_Extend( heap, area_begin, area_size, 0 );
+    if (_Heap_Extend( heap, area_begin, area_size, 0 ) == 0) {
+      return -1;
+  return 0;
   void *area_begin,
   uintptr_t area_size
+  int status;
   if ( _System_state_Is_up( _System_state_Get()) ) {
     _RTEMS_Lock_allocator();
-    add_area( area_begin, area_size );
+  status = add_area( area_begin, area_size );
+  if ( _System_state_Is_up( _System_state_Get()) ) {
-  } else {
+  return status == 0 ? RTEMS_SUCCESSFUL : RTEMS_UNSATISFIED;
2.39.2
