[PATCH rtems-central] spec/cache/coherent: Add return value for add area
Thu Jan 25 08:17:27 UTC 2024
On 24.01.24 18:19, Kinsey Moore wrote:
> This changes the return type for rtems_cache_coherent_add_area from void
> to rtems_status_code so that the function can report errors when they
> occur.
>   spec/rtems/cache/if/coherent-add-area.yml | 14 ++++++++++++--
>   1 file changed, 12 insertions(+), 2 deletions(-)
> diff --git a/spec/rtems/cache/if/coherent-add-area.yml b/spec/rtems/cache/if/coherent-add-area.yml
> index 410f3c58..325d043c 100644
> --- a/spec/rtems/cache/if/coherent-add-area.yml
> +++ b/spec/rtems/cache/if/coherent-add-area.yml
> @@ -10,7 +10,7 @@ definition:
>       params:
>       - void *${.:/params[0]/name}
>       - ${/c/if/uintptr_t:/name} ${.:/params[1]/name}
> -    return: void
> +    return: rtems_status_code
This should be:
return: ${../../status/if/code:/name}
>     variants: []
>   description: null
>   enabled-by: true
> @@ -40,5 +40,15 @@ params:
>       is the size in bytes of the cache coherent memory area to add.
>     dir: null
> -return: null
> +return:
> +  return: |
> +    Returns a rtems_status_code indicating whether the area was added to cache
> +    coherent memory.
We have a standard scheme for status code documentations, see for
example spec/rtems/sem/if/obtain.yml. For example:
return:
   return: null
   return-values:
   - description: |
       The requested operation was successful.
     value: ${../../status/if/successful:/name}
   - description: |
       The memory area is too small and was not added to the heap.
     value: ${../../status/if/unsatisfied:/name}
> +  return-values:
> +  - description: |
> +      The cache coherent memory extension was successful.
> +    value: ${../../status/if/successful:/name}
> +  - description: |
> +      The cache coherent memory extension was not successful.
> +    value: ${../../status/if/unsatisfied:/name}
>   type: interface
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
