[PATCH v2] cpukit/cache: Report coherent add area failures
Thu Jan 25 19:04:14 UTC 2024
On 25.01.24 16:00, Kinsey Moore wrote:
> -void rtems_cache_coherent_add_area(
> +rtems_status_code rtems_cache_coherent_add_area(
>     void *area_begin,
>     uintptr_t area_size
> +  rtems_status_code sc;
>     if ( _System_state_Is_up( _System_state_Get()) ) {
>       _RTEMS_Lock_allocator();
> -    add_area( area_begin, area_size );
> +  sc = add_area( area_begin, area_size );
> +  if ( _System_state_Is_up( _System_state_Get()) ) {
>       _RTEMS_Unlock_allocator();
> -  } else {
> +  return sc;
When I would be a static analyzer knowing that _RTEMS_Lock_allocator()
acquires a mutex and _RTEMS_Unlock_allocator() releases a mutex, then I
would complain about the changed code since a considerable amount of
reasoning is required to proof that the second if will take the same
branch as the first if.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
