Naming convention for Rust target platforms
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Mon Jan 29 18:41:19 UTC 2024
Hi everyone,
As mentioned in the other Rust thread, I am working on an initial Rust port for RTEMS.
The target platform for testing is the ARM Xilinx Zynq-7000 based BSPs.
Where I am not completely sure, is how to name the new target for Rust (see here the current list: https://doc.rust-lang.org/nightly/rustc/platform-support.html#tier-3).
The Rust ARM targets usually have the instruction set version and ABI as part of the name, e.g. armv7a-none-eabihf.
In RTEMS the arm-rtems6-gcc covers all supported ARM versions and different ABIs (i.e. hard-float or soft-float) collectively.
So, for the Zynq and similar BSPs this would yield for the Rust target something like: armv7a-rtems6-eabihf (and possibly armv7a-rtems6-eabi).
Similarly, for other ARM BSPs additional Rust targets would need to be added. Which might add up to quite a  number of Rust targets over time.
Is this fine or do you see another solution?
Cheers,
    Jan
Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
German Aerospace Center
Institute for Software Technology | Software for Space Systems and Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
Jan Sommer
Telephone +49 531 295-2494 | Telefax 0531 295-2767 | jan.sommer at dlr.de
DLR.de/SC
