Naming convention for Rust target platforms
Frank Kühndel frank.kuehndel at embedded-brains.de
Tue Jan 30 17:13:42 UTC 2024
Hello Jan,
On 1/29/24 19:41, Jan.Sommer at dlr.de wrote:
> Hi everyone,
> As mentioned in the other Rust thread, I am working on an initial Rust port for RTEMS.
> The target platform for testing is the ARM Xilinx Zynq-7000 based BSPs.
> Where I am not completely sure, is how to name the new target for Rust (see here the current list:https://doc.rust-lang.org/nightly/rustc/platform-support.html#tier-3).
> The Rust ARM targets usually have the instruction set version and ABI as part of the name, e.g. armv7a-none-eabihf.
> In RTEMS the arm-rtems6-gcc covers all supported ARM versions and different ABIs (i.e. hard-float or soft-float) collectively.
> So, for the Zynq and similar BSPs this would yield for the Rust target something like: armv7a-rtems6-eabihf (and possibly armv7a-rtems6-eabi).
> Similarly, for other ARM BSPs additional Rust targets would need to be added. Which might add up to quite a  number of Rust targets over time.
> Is this fine or do you see another solution?
Just to make sure I understand your question correct:
You want to push the RTEMS support you have developed (changes to Rust
libraries, test framework, ability to have a main() in the Rust code for
RTEMS etc.) to the official Rust repository - so that it is available to
everyone through the Rust nightly builds?
If this is so, then your question would be primarily a question to the
Rust folks because it is their repository which would possibly receive
many different entries for (similar?) RTEMS BSPs?
As far as I understand this, the steps for an RTEMS developer would be:
1) Build the right RTEMS tools with the Source Builder. Here: ARM tools.
2) Build RTEMS (kernel) for the right (RTEMS) BSP
3) Install the Rust compiler and its tools
4) Create a Rust project
5) Fine tune some Rust configuration files in that project.
    Here the "armv7a-rtems6-eabihf" or something fitting the BSP would
    be used in a config file. The point is, it must be for the processor
    and BSP which matches the RTEMS tools and BSP selected in steps 1)
    and 2)
6) Make changes to the sample Rust code generated in the project
    or write the Rust code desired.
7) Load the nightly build of the Rust compiler.
    (The nightly is only needed as long as your code has not entered the
    stable build).
8) Compile the Rust program code with the Rust nightly compiler.
9) Link the Rust binary with the RTEMS libraries into a single
    executable (using a linker build by the RTEMS tools).
Which name Rust accepts instead of "armv7a-rtems6-eabihf" depends on the
naming convention of the Rust community:
     https://docs.rust-embedded.org/embedonomicon/custom-target.html
According to this file, the part `eabi` is for bare metal. Would this be
correct when it is based on RTEMS? For example, a Linux target would be
"x86_64-unknown-linux-gnu" where `gnu` means started by 'glibc'.
By the way, section "Adding a new target" of
    https://doc.rust-lang.org/nightly/rustc/target-tier-policy.html
points to an example:
    https://github.com/rust-lang/rust/pull/94872
and that person discussed that triple name here:
https://rust-lang.zulipchat.com/#narrow/stream/131828-t-compiler/topic/LLVM.2Bmingw-w64.20Windows.20targets
Greetings,
Frank
> Cheers,
>      Jan
> Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
> German Aerospace Center
> Institute for Software Technology | Software for Space Systems and Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
> Jan Sommer
> Telephone +49 531 295-2494 | Telefax 0531 295-2767 |jan.sommer at dlr.de
> DLR.de/SC
> devel mailing list
> devel at rtems.org
embedded brains GmbH & Co. KG
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone:  +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
Registernummer: HRA 117265
