AW: Naming convention for Rust target platforms
Wed Jan 31 07:08:06 UTC 2024
On 30.01.24 13:45, Jan.Sommer at dlr.de wrote:
>> -----Ursprüngliche Nachricht-----
>> Von: Sebastian Huber<sebastian.huber at embedded-brains.de>
>> Gesendet: Dienstag, 30. Januar 2024 11:08
>> An: devel<devel at rtems.org>
>> Cc: Sommer, Jan<Jan.Sommer at dlr.de>
>> Betreff: Re: Naming convention for Rust target platforms
>> Hello Jan,
>> On 29.01.24 19:41,Jan.Sommer at dlr.de  wrote:
>>> So, for the Zynq and similar BSPs this would yield for the Rust target
>>> something like: armv7a-rtems6-eabihf (and possibly armv7a-rtems6-eabi).
>>> Similarly, for other ARM BSPs additional Rust targets would need to be
>>> added. Which might add up to quite a  number of Rust targets over time.
>>> Is this fine or do you see another solution?
>> how are the GCC machine flags determined (for linking)? Are they derived
>> from the target name?
> In my current setup I read the information from the pkgconfig files of the BSP.
> I remember that at some point the pkgconfig was marked as experimental. > Is that still the case or is it now an official part of the RTEMS6
release?
When RTEMS 6.1 is released, the pkg-config support should be way to get
the BSP settings. It would be good to get a bit of user feedback how it
is used right now.
If you use the BSP provided flags, then what is the purpose of the Rust
target name? For example, what happens if I just use "foobar"?
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
