[RFC] libdl: Make Elf_Sym::st_other available
Fri Mar 1 07:05:48 UTC 2024
On 29.02.24 00:27, Chris Johns wrote:
> On 27/2/2024 6:46 pm, Sebastian Huber wrote:
>> The 64-bit PowerPC ELFv2 relocation support needs access to the
>> Elf_Sym::st_other symbol information.  The machine-specific relocation handler
>> had only access to the Elf_Sym::st_info symbol information.  This change
>> extends the 8-bit syminfo parameter to 16-bit and uses the additional
>> 8-bits to provide Elf_Sym::st_other.  Another approach could be to pass
>> a pointer to an Elf_Sym object instead of symname, syminfo, and
>> symvalue.
> I think symname and symvalue have to stay or the code needed to support them
> moves out to all reloc handlers [1]. I agree there is a limit to the number args
> to keep adding. If there is a need for more fields then it may pay to pass in
> Elf_Sym* or rtems_rtl_obj_sym* which is the symbol table reference?
> Chris
> [1] https://git.rtems.org/rtems/tree/cpukit/libdl/rtl-elf.c#n429
What do you prefer, a new st_other parameter, use Elf_Sym*, or use
rtems_rtl_obj_sym*?
The
  * An object file symbol.
typedef struct rtems_rtl_obj_sym
   rtems_chain_node node;    /**< The node's link in the chain. */
   const char*      name;    /**< The symbol's name. */
   void*            value;   /**< The value of the symbol. */
   uint32_t         data;    /**< Format specific data. */
} rtems_rtl_obj_sym;
has no st_info and st_other members. I tend to pass a Elf_Sym* pointer.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
