[PATCH 4/6] build: Add support to make bootloader images
Fri Mar 1 10:28:34 UTC 2024
On 29.02.24 00:05, Chris Johns wrote:
>> It could help to export also EXEEXT and BOOT_IMAGE_EXTENSION in the package
>> configuration file. For RTEMS 6, we should have a look how our package
>> configuration support can be used to build applications on some commonly used
>> build systems. We are currently not able to produce build images.
> Yes we should. I also wonder if base addresses and other values that get used
> should be prov
Ok, this is a separate issue. We could add all the BSP options contained
in bspopts.h also to the package config file. What about the CPU
options? What about options in BSP-specific configuration files?
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
