[PATCH 2/2] testsuites/dhrystone: Initialize before use
Kinsey Moore kinsey.moore at oarcorp.com
Fri Mar 1 15:28:03 UTC 2024
On Fri, Mar 1, 2024 at 8:40 AM Joel Sherrill <joel.sherrill at gmail.com>
wrote:
> On Fri, Mar 1, 2024 at 8:21 AM Kinsey Moore <kinsey.moore at oarcorp.com>
> wrote:
>> A very similar change was made in 2017 to resolve the same warning for a
>> different variable. The only real difference is that it is wrapped in
>> __rtems__ ifdefs. I can move this change to the #ifdef'd section if that's
>> preferable.
> Do not rearrange. Just add the __rtems__ conditional. The goal is to fix
> issues while minimizing differences.
I have posted a v2 that hides the change behind a __rtems__ conditional.
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240301/1be17965/attachment.htm>
