Getting started task done
Atharv Dubey atharvd440 at gmail.com
Tue Mar 5 19:19:44 UTC 2024
Hello , I am Atharv Dubey a sophomore studying ECE at VJTI,Mumbai and here
is my patch for
the getting started assignment
diff --git a/testsuites/samples/hello/init.c
b/testsuites/samples/hello/init.c
new file mode 100644
index 0000000000..2f4029e8d8
--- /dev/null
+++ b/testsuites/samples/hello/init.c
@@ -0,0 +1,89 @@
+ *  COPYRIGHT (c) 1989-2012.
+ *  On-Line Applications Research Corporation (OAR).
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
THE
+// #ifdef HAVE_CONFIG_H
+// #include "config.h"
+// #endif
+// #include <rtems.h>
+// #include <tmacros.h>
+// const char rtems_test_name[] = "HELLO WORLD";
+// static rtems_task Init(
+//   rtems_task_argument ignored
+//   rtems_print_printer_fprintf_putc(&rtems_test_printer);
+//   TEST_BEGIN();
+//   printf( "Hello from Atharv Dubey\n" );
+//   TEST_END();
+//   rtems_test_exit( 0 );
+// /* NOTICE: the clock driver is explicitly disabled */
+// #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+// #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+// #define CONFIGURE_MAXIMUM_TASKS            1
+// #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+// #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+// #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+// #include <rtems/confdefs.h>
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_UNLIMITED_OBJECTS
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
+#include <rtems.h>
+#include <stdlib.h>
+#include <stdio.h>
+rtems_task Init(
+  rtems_task_argument ignored
+  printf( "\nHello World from Atharv Dubey !!!\n" );
+  exit( 0 );
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240306/56b154aa/attachment-0001.htm>
Name: Screenshot from 2024-03-04 01-16-24.png
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240306/56b154aa/attachment-0001.png>
