[PATCH] bsps/shared/xqspipsu: Read correct status bits
Kinsey Moore kinsey.moore at oarcorp.com
Tue Mar 5 20:54:30 UTC 2024
When resetting the QSPI FIFOs, the driver was reading write-only bits of
a register for status information when it was actually in a different
register. This corrects the driver so that it reads the correct status
bits.
 bsps/shared/dev/spi/xqspipsu.c | 15 +++++++++++++++
 1 file changed, 15 insertions(+)
diff --git a/bsps/shared/dev/spi/xqspipsu.c b/bsps/shared/dev/spi/xqspipsu.c
index c77407bdf4..93d3fa4c98 100644
--- a/bsps/shared/dev/spi/xqspipsu.c
+++ b/bsps/shared/dev/spi/xqspipsu.c
@@ -278,6 +278,12 @@ void XQspiPsu_Abort(XQspiPsu *InstancePtr)
 	u32 IntrStatus, ConfigReg, FifoStatus;
 	u32 DelayCount = 0U;
+#ifdef __rtems__
+	u32 FifoStatusMask = XQSPIPSU_ISR_RXEMPTY_MASK;
+	FifoStatusMask |= XQSPIPSU_ISR_TXEMPTY_MASK;
+	FifoStatusMask |= XQSPIPSU_ISR_GENFIFOEMPTY_MASK;
+#endif
 	Xil_AssertVoid(InstancePtr != NULL);
 #ifdef DEBUG
 	xil_printf("\nXQspiPsu_Abort\r\n");
@@ -329,8 +335,13 @@ void XQspiPsu_Abort(XQspiPsu *InstancePtr)
 	FifoStatus = XQspiPsu_ReadReg(InstancePtr->Config.BaseAddress,
+#ifdef __rtems__
+					XQSPIPSU_ISR_OFFSET) & FifoStatusMask;
+	while(FifoStatus != FifoStatusMask) {
+#else
 					XQSPIPSU_FIFO_CTRL_OFFSET);
 	while(FifoStatus != 0U) {
+#endif
 		if (DelayCount == MAX_DELAY_CNT) {
 #ifdef DEBUG
 			xil_printf("Timeout error, FIFO reset failed.\r\n");
@@ -340,7 +351,11 @@ void XQspiPsu_Abort(XQspiPsu *InstancePtr)
 			usleep(1);
 			DelayCount++;
+#ifdef __rtems__
+#else
+#endif
2.39.2
