Getting started task done
Tue Mar 5 21:16:56 UTC 2024
PS: You may add yourself to the table at
https://devel.rtems.org/wiki/GSoC/2024#ContributorsProposals
On Tue, Mar 5, 2024 at 2:15 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Atharv Dubey,
> This is acceptable. However, could you please re-do this to create a
> *minimal* patch containing only a small change required to modify what
> the hello sample prints? The patch you sent includes many superfluous
> changes, including a lot of commented-out lines of code and excessive
> blank lines.
> Gedare
> On Tue, Mar 5, 2024 at 6:49 AM Atharv Dubey <atharvd440 at gmail.com> wrote:
> > Hello , I am Atharv Dubey a sophomore studying ECE at VJTI,Mumbai and here is my patch for
> > the getting started assignment
> > diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
> > new file mode 100644
> > index 0000000000..2f4029e8d8
> > --- /dev/null
> > +++ b/testsuites/samples/hello/init.c
> > @@ -0,0 +1,89 @@
> > +/* SPDX-License-Identifier: BSD-2-Clause */
> > + *  COPYRIGHT (c) 1989-2012.
> > + *  On-Line Applications Research Corporation (OAR).
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in the
> > + *    documentation and/or other materials provided with the distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +// #ifdef HAVE_CONFIG_H
> > +// #include "config.h"
> > +// #endif
> > +// #include <rtems.h>
> > +// #include <tmacros.h>
> > +// const char rtems_test_name[] = "HELLO WORLD";
> > +// static rtems_task Init(
> > +//   rtems_task_argument ignored
> > +//   rtems_print_printer_fprintf_putc(&rtems_test_printer);
> > +//   TEST_BEGIN();
> > +//   printf( "Hello from Atharv Dubey\n" );
> > +//   TEST_END();
> > +//   rtems_test_exit( 0 );
> > +// /* NOTICE: the clock driver is explicitly disabled */
> > +// #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> > +// #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> > +// #define CONFIGURE_MAXIMUM_TASKS            1
> > +// #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > +// #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> > +// #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> > +// #include <rtems/confdefs.h>
> > +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > +#define CONFIGURE_UNLIMITED_OBJECTS
> > +#define CONFIGURE_UNIFIED_WORK_AREAS
> > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > +#define CONFIGURE_INIT
> > +#include <rtems/confdefs.h>
> > +#include <rtems.h>
> > +#include <stdlib.h>
> > +#include <stdio.h>
> > +rtems_task Init(
> > +  rtems_task_argument ignored
> > +  printf( "\nHello World from Atharv Dubey !!!\n" );
> > +  exit( 0 );
