[PATCH] improved error checking in ticks per timeslice
zack leung zakthertemsdev at gmail.com
Wed Mar 6 02:51:43 UTC 2024
Hey i've replied with another patch :)
On Tue, 5 Mar 2024 at 10:42, Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Zack,
> It looks like there's been a little confusion here. Sebastian was
> requesting that you condense the pair of #ifs into a single #if with && and
> the defined check still coming first. It is mostly trivial in this
> instance, but virtually every other example in the related files is of a
> multi-conditional #if versus nested #ifs where possible. Technically, I
> think what you have is fine as the RTEMS coding conventions don't directly
> express a preference on split #ifs versus compound #ifs but it doesn't
> match the style of the surrounding code.
> Kinsey
> On Mon, Mar 4, 2024 at 7:39 PM zack leung <zakthertemsdev at gmail.com>
> wrote:
>> ping
>> On Tue, 27 Feb 2024 at 21:33, zack leung <zakthertemsdev at gmail.com>
>> wrote:
>>> joel said:
>>>    +#if CONFIGURE_TICKS_PER_TIMESLICE <= 0 &&
>>> >     defined(CONFIGURE_TICKS_PER_TIMESLICE)
>>> >     +  #error "CONFIGURE_TICKS_PER_TIMESLICE shall be greater than
>>> zero"
>>> >     +#endif
>>> > This is modifying the right file but I think it is safer to check that
>>> > it is defined
>>> > before checking its value.
>>> Yes, the defined() check should be first. - sebestian
>>> You said this in relation to joel's comment in my previous thread. You
>>> can check in either one.  The  previous one used the "and" statement.
>>> Zack
>>> On Tue, 27 Feb 2024 at 02:08, Sebastian Huber <
>>> sebastian.huber at embedded-brains.de> wrote:
>>>> On 19.02.24 03:13, zakthertemsdev at gmail.com wrote:
>>>> > +#if defined(CONFIGURE_TICKS_PER_TIMESLICE)
>>>> > +  #if CONFIGURE_TICKS_PER_TIMESLICE <= 0
>>>> > +    #error "CONFIGURE_TICKS_PER_TIMESLICE shall be greater than zero"
>>>> > +  #endif
>>>> > +#endif
>>>> This should be
>>>> #if defined(CONFIGURE_TICKS_PER_TIMESLICE) &&
>>>> from my point of view. Just check the style of the related header files
>>>> for a reference.
>>>> embedded brains GmbH & Co. KG
>>>> Herr Sebastian HUBER
>>>> Dornierstr. 4
>>>> 82178 Puchheim
>>>> Germany
>>>> email: sebastian.huber at embedded-brains.de
>>>> phone: +49-89-18 94 741 - 16
>>>> fax:   +49-89-18 94 741 - 08
>>>> Registergericht: Amtsgericht München
>>>> Registernummer: HRB 157899
>>>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>>>> Unsere Datenschutzerklärung finden Sie hier:
>>>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240305/72b5b560/attachment.htm>
