Multiple PowerPC BSPs Fail to BUIld
Sat Mar 9 21:40:09 UTC 2024
Hi
In looking at the build sweep log, I see what looks like motorola_powerpc
and beatnik all have a common build failure that results in 53
configurations failing per
https://lists.rtems.org/pipermail/build/2024-March/051698.html
This is one but there are a lot.
debug powerpc/mvme2307 build:
      configure: /home/tester/rtems-cron-6/rtems/waf configure\
      --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
      /rtems-cron-6/rtems --rtems-config=config-powerpc-mvme2307-debug.ini
     error: home/tester/bsps/powerpc/include/bsp/irq_supp.h:87:65: error:
            'rtems_irq_connect_data' {aka 'struct
            __rtems_irq_connect_data__'} has no member named
            'next_handler'
Anyone care to fix that?
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240309/abab1220/attachment.htm>
