Multiple PowerPC BSPs Fail to BUIld
Mon Mar 11 07:04:16 UTC 2024
Hello Joel,
On 09.03.24 22:40, Joel Sherrill wrote:
> In looking at the build sweep log, I see what looks like
> motorola_powerpc and beatnik all have a common build failure that
> results in 53 configurations failing per
> https://lists.rtems.org/pipermail/build/2024-March/051698.html
> <https://lists.rtems.org/pipermail/build/2024-March/051698.html>
> This is one but there are a lot.
> debug powerpc/mvme2307 build:
>        configure: /home/tester/rtems-cron-6/rtems/waf configure\
>        --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
>        /rtems-cron-6/rtems --rtems-config=config-powerpc-mvme2307-debug.ini
>       error: home/tester/bsps/powerpc/include/bsp/irq_supp.h:87:65: error:
>              'rtems_irq_connect_data' {aka 'struct
>              __rtems_irq_connect_data__'} has no member named
>              'next_handler'
> Anyone care to fix that?
sorry for breaking the build. I fixed it. The problem is that
<rtems/irq.h> header file depends on the BSP-provided define
BSP_SHARED_HANDLER_SUPPORT. So, the include order matters.
Some powerpc BSPs have linker errors in the tests:
Waf: Leaving directory `/tmp/sh/b-rtems/powerpc/gwlcfm'
Build failed
  -> task in 'testsuites/fstests/fsjffs2empty01.exe' failed with exit
status 1 (run with -v to display more information)
  -> task in 'testsuites/fstests/jffs2nand_fsrdwr.exe' failed with exit
  -> task in 'testsuites/fstests/jffs2nand_fserror.exe' failed with exit
  -> task in 'testsuites/fstests/jffs2nand_fslink.exe' failed with exit
  -> task in 'testsuites/fstests/jffs2nand_fsscandir01.exe' failed with
exit status 1 (run with -v to display more information)
  -> task in 'testsuites/fstests/jffs2nand_fssymlink.exe' failed with
  -> task in 'testsuites/fstests/jffs2nand_fspermission.exe' failed with
  -> task in 'testsuites/fstests/jffs2nand_fspatheval.exe' failed with
  -> task in 'testsuites/fstests/jffs2nand_fstime.exe' failed with exit
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
