rtems-6.1-rc2 on Mac OSX Sonoma 14.4 (Apple M2) failed -> fixed
Heinz Junkes junkes at fhi-berlin.mpg.de
Tue Mar 12 03:09:21 UTC 2024
Hi
After updating Xcode and OSX to Sonoma 14.4 the Python libs 'disappeared’ ?
Upgrade/update python on homebrew and brew link python3 fixed it.
Heinz
> On 11. Mar 2024, at 16:27, Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
> Hi,
> I am trying to install rc2 on sonoma 14.4 (Apple M2) and unfortunately get
> error: config error: gdb-common-1.cfg:146: "gdb: python: library file not found: libpython3.11.*, please install”
> It looks like the error described in ticket #4631.
> Heinz
> (base) junkes at Zarquon rtems % ../source-builder/sb-set-builder --prefix=/Volumes/Epics/6_1_RC2/6.1-rc2 6/rtems-powerpc
> RTEMS Source Builder - Set Builder, 6.1-rc2
> Build Set: 6/rtems-powerpc
> Build Set: tools/rtems-default-tools.bset
> config: devel/dtc-1.6.1-1.cfg
> package: dtc-1.6.1-arm64-apple-darwin23.4.0-1
> building: dtc-1.6.1-arm64-apple-darwin23.4.0-1
> sizes: dtc-1.6.1-arm64-apple-darwin23.4.0-1: 3.057MB (installed: 704.209KB)
> cleaning: dtc-1.6.1-arm64-apple-darwin23.4.0-1
> reporting: devel/dtc-1.6.1-1.cfg -> dtc-1.6.1-arm64-apple-darwin23.4.0-1.txt
> reporting: devel/dtc-1.6.1-1.cfg -> dtc-1.6.1-arm64-apple-darwin23.4.0-1.xml
> config: devel/expat-2.5.0-1.cfg
> package: expat-2.5.0-arm64-apple-darwin23.4.0-1
> download: https://ftp.rtems.org/pub/rtems/releases/6/rc/6.1-rc2/sources/expat-2.5.0.tar.gz -> sources/expat-2.5.0.tar.gz
> downloading: sources/expat-2.5.0.tar.gz - 702.4kB of 702.4kB (100%)  building: expat-2.5.0-arm64-apple-darwin23.4.0-1
> sizes: expat-2.5.0-arm64-apple-darwin23.4.0-1: 7.704MB (installed: 905.753KB)
> cleaning: expat-2.5.0-arm64-apple-darwin23.4.0-1
> reporting: devel/expat-2.5.0-1.cfg -> expat-2.5.0-arm64-apple-darwin23.4.0-1.txt
> reporting: devel/expat-2.5.0-1.cfg -> expat-2.5.0-arm64-apple-darwin23.4.0-1.xml
> config: devel/gmp-6.3.0.cfg
> package: gmp-6.3.0-arm64-apple-darwin23.4.0-1
> download: https://ftp.rtems.org/pub/rtems/releases/6/rc/6.1-rc2/sources/gmp-6.3.0.tar.bz2 -> sources/gmp-6.3.0.tar.bz2
> downloading: sources/gmp-6.3.0.tar.bz2 - 2.5MB of 2.5MB (100%)    building: gmp-6.3.0-arm64-apple-darwin23.4.0-1
> sizes: gmp-6.3.0-arm64-apple-darwin23.4.0-1: 22.973MB (installed: 1.402MB)
> cleaning: gmp-6.3.0-arm64-apple-darwin23.4.0-1
> reporting: devel/gmp-6.3.0.cfg -> gmp-6.3.0-arm64-apple-darwin23.4.0-1.txt
> reporting: devel/gmp-6.3.0.cfg -> gmp-6.3.0-arm64-apple-darwin23.4.0-1.xml
> Build Set: textproc/gsed-internal.bset
> config: textproc/gsed.cfg
> package: gsed-4.9-arm64-apple-darwin23.4.0-1
> download: https://ftp.rtems.org/pub/rtems/releases/6/rc/6.1-rc2/sources/sed-4.9.tar.gz -> sources/sed-4.9.tar.gz
> downloading: sources/sed-4.9.tar.gz - 2.2MB of 2.2MB (100%)    building: gsed-4.9-arm64-apple-darwin23.4.0-1
> sizes: gsed-4.9-arm64-apple-darwin23.4.0-1: 19.157MB (installed: 0.000B)
> cleaning: gsed-4.9-arm64-apple-darwin23.4.0-1
> Build Set: Time 0:00:37.403237
> Build Set: print/texinfo-internal.bset
> config: print/texinfo.cfg
> package: texinfo-7.0.3-arm64-apple-darwin23.4.0-1
> download: https://ftp.rtems.org/pub/rtems/releases/6/rc/6.1-rc2/sources/texinfo-7.0.3.tar.gz -> sources/texinfo-7.0.3.tar.gz
> download: https://ftp.rtems.org/pub/rtems/releases/6/rc/6.1-rc2/sources/texinfo-7.0.3.tar.gz: error: HTTP Error 404: Not Found
> download: https://ftp.gnu.org/gnu/texinfo/texinfo-7.0.3.tar.gz -> sources/texinfo-7.0.3.tar.gz
> downloading: sources/texinfo-7.0.3.tar.gz - 10.3MB of 10.3MB (100%)   building: texinfo-7.0.3-arm64-apple-darwin23.4.0-1
> sizes: texinfo-7.0.3-arm64-apple-darwin23.4.0-1: 88.975MB (installed: 0.000B)
> cleaning: texinfo-7.0.3-arm64-apple-darwin23.4.0-1
> Build Set: Time 0:00:39.965456
> config: tools/rtems-gdb-13.2.cfg
> error: config error: gdb-common-1.cfg:146: "gdb: python: library file not found: libpython3.11.*, please install"
> Build FAILED
> Build Set: Time 0:02:10.561549
> Build Set: Time 0:02:10.563376
> Build FAILED
> Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
> Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
> Faradayweg 4-6        | VC: https://zoom.fhi.berlin/junkes
> D - 14195 Berlin        | E-Mail:        junkes at fhi-berlin.mpg.de
> devel mailing list
> devel at rtems.org
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240312/de48e8af/attachment-0001.bin>
