rtems-6.1-rc2 on Mac OSX Sonoma 14.4 (Apple M2) failed -> fixed
Heinz Junkes junkes at fhi-berlin.mpg.de
Tue Mar 12 09:06:03 UTC 2024
Hello Chris,
thanks for your mail. I have now installed the python as you described.
The source-builder process runs quite well.
Unfortunately, the gcc-13.2.0-newlib for powerpc cannot be built:
(py3.12) junkes at zarquon rtems % cat rsb-report-powerpc-rtems6-gcc-13.2.0-newlib-3cacedb-arm64-apple-darwin23.4.0-1.txt
RTEMS Tools Project - Source Builder Error Report
 Build: error: building powerpc-rtems6-gcc-13.2.0-newlib-3cacedb-arm64-apple-darwin23.4.0-1
 Command Line: ../source-builder/sb-set-builder --prefix=/Volumes/Epics/6_1_RC2/6.1-rc2 6/rtems-powerpc
 Python: 3.12.2 (v3.12.2:6abddd9f6a, Feb  6 2024, 17:02:06) [Clang 13.0.0 (clang-1300.0.29.30)]
 RSB: not a valid repo
 Darwin zarquon.rz-berlin.mpg.de 23.4.0 Darwin Kernel Version 23.4.0: Wed Feb 21 21:45:49 PST 2024; root:xnu-10063.101.15~2/RELEASE_ARM64_T6020 arm64
Tail of the build log:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/vector:321:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__format/formatter_bool.h:20:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__format/formatter_integral.h:32:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/locale:202:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:797:5: error: expected expression
    return std::use_facet<ctype<_CharT> >(__loc).is(ctype_base::space, __c);
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:798:2: error: expected ';' at end of declaration
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:803:21: error: too many arguments provided to function-like macro invocation
isprint(_CharT __c, const locale& __loc)
../../gcc-13.2.0/gcc/../include/safe-ctype.h:136:9: note: macro 'isprint' defined here
#define isprint(c) do_not_use_isprint_with_safe_ctype
In file included from ../../gcc-13.2.0/gcc/cp/module.cc:212:
In file included from ../../gcc-13.2.0/gcc/system.h:233:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:803:1: error: declaration conflicts with target of using declaration already in scope
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/_ctype.h:255:1: note: target of using declaration
isprint(int _c)
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/cctype:119:9: note: using declaration
using ::isprint _LIBCPP_USING_IF_EXISTS;
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:805:5: error: expected expression
    return std::use_facet<ctype<_CharT> >(__loc).is(ctype_base::print, __c);
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:806:2: error: expected ';' at end of declaration
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:811:21: error: too many arguments provided to function-like macro invocation
iscntrl(_CharT __c, const locale& __loc)
../../gcc-13.2.0/gcc/../include/safe-ctype.h:128:9: note: macro 'iscntrl' defined here
#define iscntrl(c) do_not_use_iscntrl_with_safe_ctype
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:811:1: error: declaration conflicts with target of using declaration already in scope
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/_ctype.h:230:1: note: target of using declaration
iscntrl(int _c)
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/cctype:115:9: note: using declaration
using ::iscntrl _LIBCPP_USING_IF_EXISTS;
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:813:5: error: expected expression
    return std::use_facet<ctype<_CharT> >(__loc).is(ctype_base::cntrl, __c);
fatal error: too many errors emitted, stopping now [-ferror-limit=]
In file included from ../../gcc-13.2.0/gcc/cp/method.cc:30:
../../gcc-13.2.0/gcc/cgraph.h:1687:1: warning: 'cgraph_edge' defined as a class here but previously declared as a struct; this is valid, but may result in linker errors under the Microsoft C++ ABI [-Wmismatched-tags]
class GTY((chain_next ("%h.next_caller"), chain_prev ("%h.prev_caller"),
../../gcc-13.2.0/gcc/cgraph.h:859:1: note: did you mean class here?
struct cgraph_edge;
class
../../gcc-13.2.0/gcc/coretypes.h:144:1: note: did you mean class here?
struct cgraph_edge;
class
../../gcc-13.2.0/gcc/cgraph.h:2213:10: warning: struct 'cgraph_edge' was previously declared as a class; this is valid, but may result in linker errors under the Microsoft C++ ABI [-Wmismatched-tags]
  friend struct cgraph_edge;
../../gcc-13.2.0/gcc/cgraph.h:1688:16: note: previous use is here
           for_user)) cgraph_edge
../../gcc-13.2.0/gcc/cgraph.h:2213:10: note: did you mean class here?
         class
../../gcc-13.2.0/gcc/cgraph.h:2624:32: warning: struct 'cgraph_edge' was previously declared as a class; this is valid, but may result in linker errors under the Microsoft C++ ABI [-Wmismatched-tags]
void initialize_inline_failed (struct cgraph_edge *);
../../gcc-13.2.0/gcc/cgraph.h:2624:32: note: did you mean class here?
                               class
../../gcc-13.2.0/gcc/cgraph.h:2625:28: warning: struct 'cgraph_edge' was previously declared as a class; this is valid, but may result in linker errors under the Microsoft C++ ABI [-Wmismatched-tags]
bool speculation_useful_p (struct cgraph_edge *e, bool anticipate_inlining);
../../gcc-13.2.0/gcc/cgraph.h:2625:28: note: did you mean class here?
                           class
In file included from ../../gcc-13.2.0/gcc/cp/name-lookup.cc:24:
In file included from ../../gcc-13.2.0/gcc/coretypes.h:486:
In file included from ../../gcc-13.2.0/gcc/hash-table.h:636:
../../gcc-13.2.0/gcc/mem-stats.h:99:5: warning: 'sprintf' is deprecated: This function is provided for compatibility reasons only.  Due to security concerns inherent in the design of sprintf(3), it is highly recommended that you use snprintf(3) instead. [-Wdeprecated-declarations]
    sprintf (s, "%s:%i (%s)", get_trimmed_filename (),
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/stdio.h:180:1: note: 'sprintf' has been explicitly marked deprecated here
__deprecated_msg("This function is provided for compatibility reasons only.  Due to security concerns inherent in the design of sprintf(3), it is highly recommended that you use snprintf(3) instead.")
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/sys/cdefs.h:218:48: note: expanded from macro '__deprecated_msg'
        #define __deprecated_msg(_msg) __attribute__((__deprecated__(_msg)))
In file included from ../../gcc-13.2.0/gcc/cp/mapper-resolver.cc:29:
In file included from ../../gcc-13.2.0/gcc/system.h:227:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/map:2529:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/functional:526:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__functional/boyer_moore_searcher.h:27:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:550:5: error: '__abi_tag__' attribute only applies to structs, variables, functions, and namespaces
    _LIBCPP_INLINE_VISIBILITY
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__config:891:37: note: expanded from macro '_LIBCPP_INLINE_VISIBILITY'
#  define _LIBCPP_INLINE_VISIBILITY _LIBCPP_HIDE_FROM_ABI
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__config:870:26: note: expanded from macro '_LIBCPP_HIDE_FROM_ABI'
          __attribute__((__abi_tag__(_LIBCPP_TOSTRING(_LIBCPP_ODR_SIGNATURE))))
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:551:37: error: expected ';' at end of declaration list
    char_type toupper(char_type __c) const
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:557:48: error: too many arguments provided to function-like macro invocation
    const char_type* toupper(char_type* __low, const char_type* __high) const
../../gcc-13.2.0/gcc/../include/safe-ctype.h:146:9: note: macro 'toupper' defined here
#define toupper(c) do_not_use_toupper_with_safe_ctype
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:569:48: error: too many arguments provided to function-like macro invocation
    const char_type* tolower(char_type* __low, const char_type* __high) const
../../gcc-13.2.0/gcc/../include/safe-ctype.h:148:9: note: macro 'tolower' defined here
#define tolower(c) do_not_use_tolower_with_safe_ctype
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:660:5: error: '__abi_tag__' attribute only applies to structs, variables, functions, and namespaces
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:661:37: error: expected ';' at end of declaration list
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:667:48: error: too many arguments provided to function-like macro invocation
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:679:48: error: too many arguments provided to function-like macro invocation
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:795:21: error: too many arguments provided to function-like macro invocation
isspace(_CharT __c, const locale& __loc)
../../gcc-13.2.0/gcc/../include/safe-ctype.h:140:9: note: macro 'isspace' defined here
#define isspace(c) do_not_use_isspace_with_safe_ctype
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/__locale:795:1: error: declaration conflicts with target of using declaration already in scope
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/_ctype.h:267:1: note: target of using declaration
isspace(int _c)
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/cctype:121:9: note: using declaration
using ::isspace _LIBCPP_USING_IF_EXISTS;
isprint(int _c)
iscntrl(int _c)
12 warnings generated.
In file included from ../../gcc-13.2.0/gcc/cp/name-lookup.cc:25:
In file included from ../../gcc-13.2.0/gcc/cp/cp-tree.h:42:
In file included from ../../gcc-13.2.0/gcc/c-family/c-common.h:24:
../../gcc-13.2.0/gcc/../libcpp/include/cpplib.h:1543:1: warning: 'cpp_char_column_policy' defined as a struct here but previously declared as a class; this is valid, but may result in linker errors under the Microsoft C++ ABI [-Wmismatched-tags]
struct cpp_char_column_policy
../../gcc-13.2.0/gcc/input.h:67:1: note: did you mean struct here?
class cpp_char_column_policy;
struct
1 warning and 20 errors generated.
make[2]: *** [cp/mapper-resolver.o] Error 1
In file included from ../../gcc-13.2.0/gcc/cp/cp-tree.h:43:
In file included from ../../gcc-13.2.0/gcc/diagnostic.h:24:
../../gcc-13.2.0/gcc/pretty-print.h:437:3: warning: 'sprintf' is deprecated: This function is provided for compatibility reasons only.  Due to security concerns inherent in the design of sprintf(3), it is highly recommended that you use snprintf(3) instead. [-Wdeprecated-declarations]
  pp_scalar (pp, HOST_WIDE_INT_PRINT_DEC, i);
../../gcc-13.2.0/gcc/pretty-print.h:329:7: note: expanded from macro 'pp_scalar'
      sprintf (pp_buffer (PP)->digit_buffer, FORMAT, SCALAR); \
6 warnings generated.
4 warnings generated.
8 warnings generated.
make[2]: *** [cp/module.o] Error 1
11 warnings generated.
rm gcc.pod
make[2]: Leaving directory `/Volumes/Epics/6_1_RC2/rtems-source-builder-6.1-rc2/rtems/build/powerpc-rtems6-gcc-13.2.0-newlib-3cacedb-arm64-apple-darwin23.4.0-1/build/gcc'
make[1]: *** [all-gcc] Error 2
make[1]: Leaving directory `/Volumes/Epics/6_1_RC2/rtems-source-builder-6.1-rc2/rtems/build/powerpc-rtems6-gcc-13.2.0-newlib-3cacedb-arm64-apple-darwin23.4.0-1/build'
make: *** [all] Error 2
make: Leaving directory `/Volumes/Epics/6_1_RC2/rtems-source-builder-6.1-rc2/rtems/build/powerpc-rtems6-gcc-13.2.0-newlib-3cacedb-arm64-apple-darwin23.4.0-1/build'
shell cmd failed: /bin/sh -ex  /Volumes/Epics/6_1_RC2/rtems-source-builder-6.1-rc2/rtems/build/powerpc-rtems6-gcc-13.2.0-newlib-3cacedb-arm64-apple-darwin23.4.0-1/do-build
error: building powerpc-rtems6-gcc-13.2.0-newlib-3cacedb-arm64-apple-darwin23.4.0-1%        (py3.12) junkes at zarquon rtems %
> On 12. Mar 2024, at 06:55, Chris Johns <chrisj at rtems.org> wrote:
> [ Sorry, my email does not show your message ]
> Hi Heinz,
> I see you are using brew on your M machine which is fine. As an alternative I
> have documented using python.org:
> https://docs.rtems.org/branches/master/user/hosts/macos.html#python
> and a virtual environment.
> Chris
> On 12/3/2024 2:09 pm, Heinz Junkes wrote:
>> devel mailing list
>> devel at rtems.org
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240312/cfcec7bb/attachment-0001.bin>
