Fwd: Build FreeBSD: FAILED 7/rtems-aarch64 on x86_64-freebsd13.2 (aarch64-rtems7-gdb-eb42bb1-x86_64-freebsd13.2-1)
Sun Mar 17 18:07:20 UTC 2024
GDB is failing to build on FreeBSD 13.
--joel
---------- Forwarded message ---------
From: OAR Tester for FreeBSD 13 <rtems-tester at oarcorp.com>
Date: Sun, Mar 17, 2024 at 12:15 PM
Subject: Build FreeBSD: FAILED 7/rtems-aarch64 on x86_64-freebsd13.2
To: <build at rtems.org>
RTEMS Source Builder - Set Builder, 6 (d24131ac781e)
Host: FreeBSD-13.2-RELEASE-p4-amd64-64bit-ELF
       FreeBSD VM-FreeBSD13.rtems.com 13.2-RELEASE-p4 FreeBSD
13.2-RELEASE-p4
       GENERIC amd64 amd64
Build Time: 0:14:42.879142
Output
Build Set: 7/rtems-aarch64
Build Set: tools/rtems-default-tools.bset
config: devel/dtc-1.6.1-1.cfg
package: dtc-1.6.1-x86_64-freebsd13.2-1
building: dtc-1.6.1-x86_64-freebsd13.2-1
sizes: dtc-1.6.1-x86_64-freebsd13.2-1: 4.208MB (installed: 1.114MB)
cleaning: dtc-1.6.1-x86_64-freebsd13.2-1
reporting: devel/dtc-1.6.1-1.cfg -> dtc-1.6.1-x86_64-freebsd13.2-1.txt
reporting: devel/dtc-1.6.1-1.cfg -> dtc-1.6.1-x86_64-freebsd13.2-1.xml
config: devel/expat-2.5.0-1.cfg
package: expat-2.5.0-x86_64-freebsd13.2-1
building: expat-2.5.0-x86_64-freebsd13.2-1
sizes: expat-2.5.0-x86_64-freebsd13.2-1: 10.879MB (installed: 1.667MB)
cleaning: expat-2.5.0-x86_64-freebsd13.2-1
reporting: devel/expat-2.5.0-1.cfg -> expat-2.5.0-x86_64-freebsd13.2-1.txt
reporting: devel/expat-2.5.0-1.cfg -> expat-2.5.0-x86_64-freebsd13.2-1.xml
config: devel/gmp-6.2.1.cfg
package: gmp-6.2.1-x86_64-freebsd13.2-1
building: gmp-6.2.1-x86_64-freebsd13.2-1
sizes: gmp-6.2.1-x86_64-freebsd13.2-1: 22.687MB (installed: 1.725MB)
cleaning: gmp-6.2.1-x86_64-freebsd13.2-1
reporting: devel/gmp-6.2.1.cfg -> gmp-6.2.1-x86_64-freebsd13.2-1.txt
reporting: devel/gmp-6.2.1.cfg -> gmp-6.2.1-x86_64-freebsd13.2-1.xml
Build Set: textproc/gsed-internal.bset
config: textproc/gsed.cfg
package: gsed-4.9-x86_64-freebsd13.2-1
building: gsed-4.9-x86_64-freebsd13.2-1
sizes: gsed-4.9-x86_64-freebsd13.2-1: 16.837MB (installed: 0.000B)
cleaning: gsed-4.9-x86_64-freebsd13.2-1
Build Set: Time 0:00:29.032045
Build Set: print/texinfo-internal.bset
config: print/texinfo.cfg
package: texinfo-7.0.3-x86_64-freebsd13.2-1
building: texinfo-7.0.3-x86_64-freebsd13.2-1
sizes: texinfo-7.0.3-x86_64-freebsd13.2-1: 89.233MB (installed: 0.000B)
cleaning: texinfo-7.0.3-x86_64-freebsd13.2-1
Build Set: Time 0:00:41.389695
config: tools/rtems-gdb-head.cfg
package: aarch64-rtems7-gdb-eb42bb1-x86_64-freebsd13.2-1
building: aarch64-rtems7-gdb-eb42bb1-x86_64-freebsd13.2-1
error: building aarch64-rtems7-gdb-eb42bb1-x86_64-freebsd13.2-1
Build FAILED
  See error report:
rsb-report-aarch64-rtems7-gdb-eb42bb1-x86_64-freebsd13.2-1.txt
  Note: In some cases the error appears only in
  the complete build log (see --log option)
config: tools/rtems-binutils-head.cfg
package: aarch64-rtems7-binutils-eb42bb1-x86_64-freebsd13.2-1
building: aarch64-rtems7-binutils-eb42bb1-x86_64-freebsd13.2-1
sizes: aarch64-rtems7-binutils-eb42bb1-x86_64-freebsd13.2-1: 781.231MB
(installed: 197.999MB)
cleaning: aarch64-rtems7-binutils-eb42bb1-x86_64-freebsd13.2-1
reporting: tools/rtems-binutils-head.cfg ->
aarch64-rtems7-binutils-eb42bb1-x86_64-freebsd13.2-1.txt
aarch64-rtems7-binutils-eb42bb1-x86_64-freebsd13.2-1.xml
config: tools/rtems-gcc-head-newlib-head.cfg
package: aarch64-rtems7-gcc-41aacde-newlib-176b19f-x86_64-freebsd13.2-1
download:
https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/176b19f
-> sources/newlib-176b19f.tar.gz
building: aarch64-rtems7-gcc-41aacde-newlib-176b19f-x86_64-freebsd13.2-1
sizes: aarch64-rtems7-gcc-41aacde-newlib-176b19f-x86_64-freebsd13.2-1:
4.847GB (installed: 1.155GB)
cleaning: aarch64-rtems7-gcc-41aacde-newlib-176b19f-x86_64-freebsd13.2-1
reporting: tools/rtems-gcc-head-newlib-head.cfg ->
aarch64-rtems7-gcc-41aacde-newlib-176b19f-x86_64-freebsd13.2-1.txt
aarch64-rtems7-gcc-41aacde-newlib-176b19f-x86_64-freebsd13.2-1.xml
config: tools/rtems-tools-6.cfg
package: rtems-tools-12971a8-1
download:
https://git.rtems.org/rtems-tools/snapshot/rtems-tools-12971a8.tar.bz2 ->
sources/rtems-tools-12971a8.tar.bz2
building: rtems-tools-12971a8-1
sizes: rtems-tools-12971a8-1: 246.583MB (installed: 59.419MB)
cleaning: rtems-tools-12971a8-1
reporting: tools/rtems-tools-6.cfg -> rtems-tools-12971a8-1.txt
reporting: tools/rtems-tools-6.cfg -> rtems-tools-12971a8-1.xml
Build Sizes: usage: 6.258GB total: 2.686GB (sources: 1.275GB, patches:
30.537KB, installed 1.411GB)
Build Set: Time 0:14:42.822001
Mailing report: build at rtems.org
Report
RTEMS Tools Project <users at rtems.org> Sun Mar 17 12:00:31 2024
Report: devel/dtc-1.6.1-1.cfg
RTEMS Source Builder Repository Status
 Remotes:
[ remotes removed, contact sender for details ]
 Status:
  Clean
 Head:
  Commit: d24131ac781eeff8be5a4a5fd185d1be20176461
Build Set: (1) devel/dtc-1.6.1-1.cfg
Build Set: (2) devel/dtc-1.6.1-1.cfg
Package: dtc-1.6.1-x86_64-freebsd13.2-1
 Config: devel/dtc-1.6.1-1.cfg
 Summary:
  Device Tree Compiler v1.6.1 for target aarch64-rtems7 on host
x86_64-freebsd13.2
 URL:
  https://www.devicetree.org/
 Version:
  1.6.1
 Release:
  1
  Sources: 1
    1: https://www.kernel.org/pub/software/utils/dtc/dtc-1.6.1.tar.gz
       sha256:
38a6257f2c23cb9dfa1781ac4ad122d8358e1a22d33b2da0eb492c190644a376
  Patches: 1
    1:
https://devel.rtems.org/raw-attachment/ticket/4783/0001-checks.c-Ensure-argument-is-an-integer-v2.patch
       sha256:
dd83c10326188732ac26c1fd8dce70b796a7dde204b31c67cf4d04f29ed4dfef
 Preparation:
  build_top=$(pwd)
  %setup source dtc -q -n dtc-1.6.1
  %setup patch dtc -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
  cd dtc-1.6.1
  # Build and build flags means force build == host
  # gcc is not ready to be compiled with -std=gnu99
  LDFLAGS="${SB_HOST_LDFLAGS}"
  LIBS="${SB_HOST_LIBS}"
  CC=$(echo "/usr/bin/cc ${SB_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
  CXX=$(echo "/usr/bin/c++ ${SB_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
  CC_FOR_BUILD=${CC}
  CXX_FOR_BUILD=${CXX}
  export CC CXX CC_FOR_BUILD CXX_FOR_BUILD CFLAGS LDFLAGS LIBS
  gmake PREFIX=/home/tester/rtems-cron-7/tools/7 WARNINGS=
  cd ${build_top}
 Install:
  build_top=$(pwd)
  rm -rf $SB_BUILD_ROOT
  cd dtc-1.6.1
  gmake DESTDIR=$SB_BUILD_ROOT PREFIX=/home/tester/rtems-cron-7/tools/7
WARNINGS= install
  cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sun Mar 17 12:00:32 2024
 Remotes:
 Status:
  Clean
 Head:
 Summary:
x86_64-freebsd13.2
 URL:
 Version:
  1.6.1
 Release:
  1
  Sources: 1
       sha256:
  Patches: 1
    1:
       sha256:
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
  cd dtc-1.6.1
  CC_FOR_BUILD=${CC}
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd dtc-1.6.1
WARNINGS= install
  cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sun Mar 17 12:00:40 2024
Report: devel/expat-2.5.0-1.cfg
 Remotes:
 Status:
  Clean
 Head:
Build Set: (1) devel/expat-2.5.0-1.cfg
Build Set: (2) devel/expat-2.5.0-1.cfg
Package: expat-2.5.0-x86_64-freebsd13.2-1
 Config: devel/expat-2.5.0-1.cfg
 Summary:
  Expat XML Parser v2.5.0 for target aarch64-rtems7 on host
x86_64-freebsd13.2
 URL:
  http://expat.sourceforge.net/
 Version:
  2.5.0
 Release:
  1
  Sources: 1
    1:
https://github.com/libexpat/libexpat/releases/download/R_2_5_0/expat-2.5.0.tar.gz
       sha512:
8f99pfr7R9zW4PDYkoJqum3nZQnISXvAA4LxEJq44qk9OWlD27UiFkVwRJk6Odc3KASK32UNjoPigYntx7eEAg==
  Patches: 0
 Preparation:
  build_top=$(pwd)
  %setup source expat -q -n expat-2.5.0
  %setup patch expat -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
  cd expat-2.5.0
  # Host and build flags, Cross build if host and build are different and
  # Cxc build if target is deifned and also different.
  # Note, gcc is not ready to be compiled with -std=gnu99 (this needs to be
checked).
  if test "x86_64-freebsd13.2" != "x86_64-freebsd13.2" ; then
    # Cross build
    CC=$(echo "x86_64-freebsd13.2-gcc" | sed -e 's,-std=gnu99 ,,')
    CXX=$(echo "x86_64-freebsd13.2-g++" | sed -e 's,-std=gnu99 ,,')
    CPPFLAGS="${SB_HOST_CPPFLAGS}"
    CFLAGS="${SB_HOST_CFLAGS}"
    CXXFLAGS="${SB_HOST_CXXFLAGS}"
    LDLIBS="${SB_HOST_LIBS}"
    # Host
    CPPFLAGS_FOR_HOST="${SB_HOST_CPPFLAGS}"
    CFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
    CXXFLAGS_FOR_HOST="${SB_HOST_CXXFLAGS}"
    LDFLAGS_FOR_HOST="${SB_HOST_LDFLAGS}"
    LDLIBS_FOR_HOST="${SB_HOST_LIBS}"
    CXXFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
    CC_FOR_HOST=$(echo "gcc ${SB_HOST_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
    CXX_FOR_HOST=$(echo "g++ ${SB_HOST_CXXFLAGS}" | sed -e 's,-std=gnu99
    # Build
    CFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
    CXXFLAGS_FOR_BUILD="${SB_BUILD_CXXFLAGS}"
    LDFLAGS_FOR_BUILD="${SB_BUILD_LDFLAGS}"
    LDLIBS_FOR_BUILD="${SB_BUILD_LIBS}"
    CXXFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
    CC_FOR_BUILD=$(echo "/usr/bin/cc ${SB_BUILD_CFLAGS}" | sed -e
's,-std=gnu99 ,,')
    CXX_FOR_BUILD=$(echo "/usr/bin/c++ ${SB_BUILD_CXXFLAGS}" | sed -e
's,-std=gnu99 ,,')
  else
    LDFLAGS="${SB_BUILD_LDFLAGS}"
    LDLIBS="${SB_BUILD_LIBS}"
    CC=$(echo "/usr/bin/cc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
    CXX=$(echo "/usr/bin/c++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99
    CC_FOR_BUILD=${CC}
  fi
  export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS LDLIBS
  export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST
CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LDLIBS_FOR_HOST LIBS_FOR_HOST
  export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD
LDFLAGS_FOR_BUILD LDLIBS_FOR_BUILS LIBS_FOR_BUILS
  ./configure  --build=x86_64-freebsd13.2 --host=x86_64-freebsd13.2
--verbose  --prefix=/home/tester/rtems-cron-7/tools/7
--bindir=/home/tester/rtems-cron-7/tools/7/bin
--exec-prefix=/home/tester/rtems-cron-7/tools/7
--includedir=/home/tester/rtems-cron-7/tools/7/include
--libdir=/home/tester/rtems-cron-7/tools/7/lib
--mandir=/home/tester/rtems-cron-7/tools/7/share/man
--infodir=/home/tester/rtems-cron-7/tools/7/share/info  --disable-shared
  gmake -j 8 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd expat-2.5.0
  gmake DESTDIR=$SB_BUILD_ROOT install
  cd ${build_top}
 Remotes:
 Status:
  Clean
 Head:
 Summary:
x86_64-freebsd13.2
 URL:
 Version:
  2.5.0
 Release:
  1
  Sources: 1
    1:
       sha512:
  Patches: 0
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
  cd expat-2.5.0
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  gmake -j 8 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd expat-2.5.0
  cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sun Mar 17 12:01:22 2024
Report: devel/gmp-6.2.1.cfg
 Remotes:
 Status:
  Clean
 Head:
Build Set: (1) devel/gmp-6.2.1.cfg
Build Set: (2) devel/gmp-6.2.1.cfg
Package: gmp-6.2.1-x86_64-freebsd13.2-1
 Config: devel/gmp-6.2.1.cfg
 Summary:
  The GNU Multiple Precision Arithmetic Library (GMP) v6.2.1 for target
aarch64-rtems7 on host x86_64-freebsd13.2
 URL:
  https://gmplib.org/
 Version:
  6.2.1
 Release:
  1
  Sources: 1
    1: https://gcc.gnu.org/pub/gcc/infrastructure/gmp-6.2.1.tar.bz2
       sha512:
iQQzSjvMXIluzsq8dc2p3sZC5AH7U5fEmSxPq+peliyc6L1E6OQjPDTlXIAQzCjbBUX191DL27XwCvU43HY76Q==
  Patches: 0
 Preparation:
  build_top=$(pwd)
  %setup source gmp -q -n gmp-6.2.1
  %setup patch gmp -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
  cd gmp-6.2.1
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  gmake -j 8 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd gmp-6.2.1
  cd ${build_top}
 Remotes:
 Status:
  Clean
 Head:
 Summary:
 URL:
  https://gmplib.org/
 Version:
  6.2.1
 Release:
  1
  Sources: 1
       sha512:
  Patches: 0
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
  cd gmp-6.2.1
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  gmake -j 8 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd gmp-6.2.1
  cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sun Mar 17 12:04:09 2024
Report: tools/rtems-binutils-head.cfg
 Remotes:
 Status:
  Clean
 Head:
Build Set: (1) tools/rtems-binutils-head.cfg
Build Set: (2) tools/rtems-binutils-head.cfg
Package: aarch64-rtems7-binutils-eb42bb1-x86_64-freebsd13.2-1
 Config: tools/rtems-binutils-head.cfg
 Summary:
  Binutils veb42bb1 for target aarch64-rtems7 on host x86_64-freebsd13.2
 URL:
  http://sources.redhat.com/binutils
 Version:
  eb42bb1
 Release:
  1
  Sources: 1
    1: --rsb-file=sourceware-mirror-binutils-gdb-eb42bb1.tar.gz
https://codeload.github.com/RTEMS/sourceware-mirror-binutils-gdb/tar.gz/eb42bb1
       No checksum
  Patches: 0
 Preparation:
  build_top=$(pwd)
  binutils_source=sourceware-mirror-binutils-gdb-eb42bb1
  source_dir_binutils=${binutils_source}
  %setup source binutils -q -n ${binutils_source}
  %setup patch binutils -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
    # Cross-build (Xc) if no target or the host and target match.
    # Canadian-cross (Cxc) if build, host and target are all different.
    if test -z "aarch64-rtems7" -o "x86_64-freebsd13.2" == "aarch64-rtems7"
; then
      build_dir="build-xc"
    else
      build_dir="build-cxc"
    fi
  else
    build_dir="build"
  fi
  mkdir -p ${build_dir}
  cd ${build_dir}
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  ../${source_dir_binutils}/configure  --build=x86_64-freebsd13.2
--host=x86_64-freebsd13.2  --target=aarch64-rtems7  --verbose
--disable-nls  --disable-gdb --disable-libdecnumber --disable-readline
--disable-sim  --enable-deterministic-archives  --enable-64-bit-bfd
--without-included-gettext  --disable-win32-registry  --disable-werror
--disable-warn-execstack --disable-warn-rwx-segments
  gmake -j 8 all
  cd ${build_top}
 Install:
  cd ${build_top}
  /bin/rm -rf $SB_BUILD_ROOT
  cd ${build_dir}
  /bin/rm -rf $SB_BUILD_ROOT/home/tester/rtems-cron-7/tools/7/share/info/
configure.info*
  /bin/rm -f $SB_BUILD_ROOT/home/tester/rtems-cron-7/tools/7/share/info/dir
  touch $SB_BUILD_ROOT/home/tester/rtems-cron-7/tools/7/share/info/dir
  mkdir -p $SB_BUILD_ROOT/home/tester/rtems-cron-7/tools/7/share/locale
  /bin/rm -f
${SB_BUILD_ROOT}/home/tester/rtems-cron-7/tools/7/lib/libiberty*
  if test ! -f
${SB_BUILD_ROOT}/home/tester/rtems-cron-7/tools/7/bin/aarch64-rtems7-dlltool;
then
  /bin/rm -f
${SB_BUILD_ROOT}/home/tester/rtems-cron-7/tools/7/share/man/man1/aarch64-rtems7-dlltool*
  fi
  if test ! -f
${SB_BUILD_ROOT}/home/tester/rtems-cron-7/tools/7/bin/aarch64-rtems7-nlmconv;
then
  /bin/rm -f
${SB_BUILD_ROOT}/home/tester/rtems-cron-7/tools/7/share/man/man1/aarch64-rtems7-nlmconv*
  fi
  if test ! -f
${SB_BUILD_ROOT}/home/tester/rtems-cron-7/tools/7/bin/aarch64-rtems7-windres;
then
  /bin/rm -f
${SB_BUILD_ROOT}/home/tester/rtems-cron-7/tools/7/share/man/man1/aarch64-rtems7-windres*
  fi
  if test ! -f
${SB_BUILD_ROOT}/home/tester/rtems-cron-7/tools/7/bin/aarch64-rtems7-windmc;
then
  /bin/rm -f
${SB_BUILD_ROOT}/home/tester/rtems-cron-7/tools/7/share/man/man1/aarch64-rtems7-windmc*
  fi
  cd ${build_top}
 Remotes:
 Status:
  Clean
 Head:
 Summary:
 URL:
 Version:
  eb42bb1
 Release:
  1
  Sources: 1
       No checksum
  Patches: 0
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
; then
    else
    fi
  else
    build_dir="build"
  fi
  cd ${build_dir}
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  gmake -j 8 all
  cd ${build_top}
 Install:
  cd ${build_top}
  cd ${build_dir}
configure.info*
  /bin/rm -f
  if test ! -f
then
  /bin/rm -f
  fi
  if test ! -f
then
  /bin/rm -f
  fi
  if test ! -f
then
  /bin/rm -f
  fi
  if test ! -f
then
  /bin/rm -f
  fi
  cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sun Mar 17 12:14:13 2024
Report: tools/rtems-gcc-head-newlib-head.cfg
 Remotes:
 Status:
  Clean
 Head:
Build Set: (1) tools/rtems-gcc-head-newlib-head.cfg
Build Set: (2) tools/rtems-gcc-head-newlib-head.cfg
Package: aarch64-rtems7-gcc-41aacde-newlib-176b19f-x86_64-freebsd13.2-1
 Config: tools/rtems-gcc-head-newlib-head.cfg
 Summary:
  GCC v41aacde and Newlib v176b19f for target aarch64-rtems7 on host
x86_64-freebsd13.2
 URL:
  http://gcc.gnu.org/
 Version:
  41aacde
 Release:
  1
  Sources: 5
    1: --rsb-file=newlib-176b19f.tar.gz
       No checksum
    2: --rsb-file=gnu-mirror-gcc-41aacde.tar.gz
https://codeload.github.com/RTEMS/gnu-mirror-gcc/tar.gz/41aacde
       No checksum
    3: https://gcc.gnu.org/pub/gcc/infrastructure/isl-0.24.tar.bz2
       sha512:
qrO929qWuAHQ9W0oaflDFXqtUqb25qYXRe3XQCNMY1w4IxryC8PxoI1Bal6XOpDhgkkHjtjkri8dXeV2WHOOlQ==
    4: https://gcc.gnu.org/pub/gcc/infrastructure/mpc-1.2.1.tar.gz
       sha512:
Mnn4E6s39H/cyADkrF8wZBfQf1OVk8pxWHbkPgSJbh1bzsz7KI7ykIo/JLdgdH0NvQOSokubNBvD4SCC5cg27g==
    5: https://www.mpfr.org/mpfr-4.2.0/mpfr-4.2.0.tar.bz2
       sha512:
yyqTFLlONKTqSc4mGYAulCDJguVSWKS8Qj+AJ0BjJkaj1CDn/PNzsZYYOFuLK0Eqv6En6PRzBThjQkysIziTwA==
  Patches: 0
 Preparation:
  build_top=$(pwd)
  gcc_source=gnu-mirror-gcc-41aacde
  source_dir_gcc=${gcc_source}
  %setup source gcc -q -n ${gcc_source}
  %setup patch gcc -p1
  cd ${build_top}
  source_dir_newlib=sourceware-mirror-newlib-cygwin-176b19f
  %setup source newlib -q -D -n ${source_dir_newlib}
  %setup patch newlib -p1
  cd ${build_top}
  /bin/rm -f ${source_dir_gcc}/newlib
  ln -s $PWD/${source_dir_newlib}/newlib ${source_dir_gcc}/newlib
  source_dir_isl="isl-0.24"
  %setup source isl -q -D -n isl-0.24
  %setup patch isl -p1
  cd ${build_top}
  /bin/rm -f ${source_dir_gcc}/isl
  ln -s $PWD/${source_dir_isl} ${source_dir_gcc}/isl
  source_dir_mpc="mpc-1.2.1"
  %setup source mpc -q -D -n mpc-1.2.1
  %setup patch mpc -p1
  cd ${build_top}
  /bin/rm -f ${source_dir_gcc}/mpc
  ln -s $PWD/${source_dir_mpc} ${source_dir_gcc}/mpc
  source_dir_mpfr="mpfr-4.2.0"
  %setup source mpfr -q -D -n mpfr-4.2.0
  %setup patch mpfr -p1
  cd ${build_top}
  /bin/rm -f ${source_dir_gcc}/mpfr
  ln -s $PWD/${source_dir_mpfr} ${source_dir_gcc}/mpfr
  echo "RTEMS 7, RSB d24131ac781eeff8be5a4a5fd185d1be20176461, Newlib
176b19f" > ${source_dir_gcc}/gcc/DEV-PHASE
  cd ${source_dir_gcc}
  contrib/gcc_update --touch
  cd ${build_top}
 Build:
  build_top=$(pwd)
  export
PATH=/usr/home/tester/rtems-cron-7/rtems-source-builder/rtems/build/tmp/sb-1003-internal/bin:$PATH
; then
    else
    fi
  else
    build_dir="build"
  fi
  cd ${build_dir}
  languages="c"
  languages="$languages,c++"
  languages="$languages,lto"
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  ../${source_dir_gcc}/configure
--exec_prefix=/home/tester/rtems-cron-7/tools/7
--libexecdir=/home/tester/rtems-cron-7/tools/7/libexec
--datadir=/home/tester/rtems-cron-7/tools/7/share
--target=aarch64-rtems7  --disable-libstdcxx-pch  --with-gnu-as
--with-gnu-ld --verbose  --with-newlib  --disable-nls
--enable-version-specific-runtime-libs  --enable-newlib-io-c99-formats
--enable-newlib-reent-thread-local  --enable-newlib-iconv
--enable-newlib-iconv-encodings=big5,cp775,cp850,cp852,cp855,\
  cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,\
  iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,\
  iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,\
  iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,\
  ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,\
  utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,\
  win_1253,win_1254,win_1255,win_1256,win_1257,win_1258  --enable-threads
--disable-plugin    --enable-libgomp    --enable-languages="$languages"
  if test "%_host" != "%_build" ; then
  mkdir -p gcc/include
  cp ../${source_dir_gcc}/gcc/gsyslimits.h gcc/include/syslimits.h
  fi
  gmake -w -j 8 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd ${build_dir}
  cd ${build_top}
  /bin/rm -f
${SB_BUILD_ROOT}/home/tester/rtems-cron-7/tools/7/lib/libiberty.a
  /bin/rm -f
$SB_BUILD_ROOT/home/tester/rtems-cron-7/tools/7/bin/aarch64-rtems7-c++filt
  /bin/rm -f
$SB_BUILD_ROOT/home/tester/rtems-cron-7/tools/7/share/man/man3/*ffi*
  /bin/rm -rf ${source_dir_gcc}/newlib
  /bin/rm -rf ${source_dir_gcc}/mpfr
  /bin/rm -rf ${source_dir_gcc}/mpc
  /bin/rm -rf ${source_dir_gcc}/gmp
 Remotes:
 Status:
  Clean
 Head:
 Summary:
x86_64-freebsd13.2
 URL:
  http://gcc.gnu.org/
 Version:
  41aacde
 Release:
  1
  Sources: 5
       No checksum
       No checksum
       sha512:
       sha512:
       sha512:
  Patches: 0
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
  cd ${build_top}
  cd ${build_top}
  cd ${build_top}
  cd ${build_top}
  cd ${build_top}
 Build:
  build_top=$(pwd)
  export
; then
    else
    fi
  else
    build_dir="build"
  fi
  cd ${build_dir}
  languages="c"
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
  fi
  gmake -w -j 8 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd ${build_dir}
  cd ${build_top}
  /bin/rm -f
  /bin/rm -f
  /bin/rm -f
RTEMS Tools Project <users at rtems.org> Sun Mar 17 12:14:41 2024
Report: tools/rtems-tools-6.cfg
 Remotes:
 Status:
  Clean
 Head:
Build Set: (1) tools/rtems-tools-6.cfg
Build Set: (2) tools/rtems-tools-6.cfg
Package: rtems-tools-12971a8-1
 Config: tools/rtems-tools-6.cfg
 Summary:
  RTEMS Tools 12971a8 for host x86_64-freebsd13.2
 URL:
  http://www.rtems.org/
 Version:
  12971a8
 Release:
  1
  Sources: 1
    1:
       sha512:
SrjY0gweRgWHmqBYj0wFnu1LFkaeNeS05SD1dKVzz2kvs3UCZ6AM8DrLbVe0q4H14DZwmrE3mMgbutsVev0Oxg==
  Patches: 0
 Preparation:
  build_top=$(pwd)
  rtems_tools_source=rtems-tools-12971a8
  source_dir_rtems_tools=${rtems_tools_source}
  %setup source rtems-tools -q -n ${rtems_tools_source}
  %setup patch rtems-tools -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
  RT_HOST="--host=x86_64-freebsd13.2"
  else
  RT_HOST=
  fi
  cd ${source_dir_rtems_tools}
  ./waf distclean configure ${RT_HOST}
  ./waf
  cd ${build_top}
 Install:
  build_top=$(pwd)
  ./waf --destdir=$SB_BUILD_ROOT install
  cd ${build_top}
 Remotes:
 Status:
  Clean
 Head:
 Summary:
 URL:
 Version:
  12971a8
 Release:
  1
  Sources: 1
    1:
       sha512:
  Patches: 0
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
  else
  RT_HOST=
  fi
  ./waf
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd ${build_top}
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240317/bf03599a/attachment-0001.htm>
